Home › News › What's New › ZIKE Unveils Magnetic Hard Drive: Perfect for iPhone 15 Series to Capture 4K 60Hz Video
  • 5
Ellen
August 8, 2024
The iPhone 15 series has upgraded to a USB-C port, with the iPhone 15 Pro and 15 Pro Max supporting USB 3.0. Additionally, the iPhone now supports external hard drives, offering more options for users. You can choose an external hard drive to solve the problem of insufficient memory, as it allows you to store videos, photos, music, and other files. ChargerLAB has learned that ZIKE has launched a hard drive specifically designed for the 15 series, which also supports magnetic attachment.
ZIKE Magnetic Hard Drive
ZIKE Unveils Magnetic Hard Drive: Perfect for iPhone 15 Series to Capture 4K 60Hz Video-Chargerlab
ZIKE’s new magnetic hard drive features in black, with the body made of aluminum alloy and PC material. It comes with a capacity of 256GB, with larger capacity versions available. Its read speed can be up to 60MB/s and the write speed is 120MB/s.
The back of the drive is silver-gray, with magnetic sides that can attach to the iPhone for convenient use. It supports USB 3.2 Gen1 with 5Gbps speed and is also compatible with USB 2.0, making it an essential external storage device for the iPhone 15 series.
The bottom of the product has a USB-C port, allowing the phone to charge simultaneously while using the hard drive. The hard drive comes with an "L-shaped" cable that attaches magnetically to the iPhone. The combined weight of the hard drive and cable is only about 17g (0.6 oz).
Thanks to its compact size, the ZIKE magnetic hard drive can be attached to the iPhone without adding significant weight, making it ideal for video recording or photography.
The surface of the hard drive includes a display that shows important information such as capacity, transfer rate, real-time power, and temperature. The external hard drive can charge the iPhone 15 Pro at a power of 27W.
Using the magnetic hard drive, you can set the iPhone camera to store files directly in the hard drive. Recorded 4K 60Hz ProRes HDR videos can be stored directly on the hard drive, making it very convenient. Videos stored on the hard drive can be easily transferred to a laptop for post-processing, increasing work efficiency.
The ZIKE magnetic hard drive features an ingenious design and compact size, perfectly compatible with the USB 3.0-supported iPhone 15 Pro Max. Its read speeds can be up to 160MB/s and write speed is 120MB/s. ProRes HDR videos can be directly stored on the magnetic hard drive. The ZIKE magnetic hard drive also includes a display for checking key information, making it an outstanding choice for a seamless user experience.
1. ACASIS Launches Multi-bay Thunderbolt 3 Hard Drive Hub, Which Supports RAID Arrays
2. First And Fastest | Review of ZikeDrive USB4 SSD Enclosure
3. Teardown of Seagate Firecuda Gaming Dock With 4TB External Hard Drive
ZIKE
Fully Charged in 29 Mins | Review of OPPO Find X7 Ultra
Charging Review of OPPO Find X7 Ultra
GaNInfinity Technology | Introducing the UGREEN Nexode Pro 65W 3-in-1 GaN Charger
February 23, 2024
ELECJET Launches the PowerPie, the World's First 20000mAh Bidirectional 45W PD PPS Fast Charging Power Bank
October 1, 2019
New Belkin Magnetic Power Bank: 15W Qi2 Charging & 10,000mAh Capacity
October 24, 2024
RICOMM Launched 370W PD3.1 Charging Station
September 30, 2023
Ellen
