01/07/2025
V1.9.5 (Tester)
1. Fixed the issue where the tester may freeze during auto detection
2. Fixed the bug causing leakage on the CC2 pin
3. Fixed known bugs related to auto detection
How to Update
To update the firmware of ChargerLAB POWER-Z KM003C PD3.1 tester, you need to operate with the PC software.
If a firmware can be updated, there will be a prompt in the detailed operation interface of "Update Firmware." As the image above, the part in the red frame means that ChargerLAB has already launched the updated firmware at this time.
And if you don't see anthing in the detailed operation interface of "Update Firmware," you can always click the big + icon above it to update. You can find all the firmware files from Google Drive.
After that, click on the "Chip Icon" in the red frame to complete the update. That is easy, isn't it? Why not turn on your ChargerLAB POWER-Z KM003C and have a try?
Version History
Download PC software of KM003C / KM002C From Google Drive
You can also directly download PC software by clicking this link
11/12/2024
V1.9.3 (Tester)
1. Added Thunderbolt 5 cable identification
2. Added support for triggering certain UFCS proprietary protocols
10/25/2024
V1.9.2 (Tester)
1. Added SPR AVS for PD3.2 protocol
2. Fixed an issue in the previous version where the PDM command module was unable to trigger any fast charging protocols
09/13/2024
V1.9.0 (Tester)
07/18/2024
V1.8.9 (Tester)
1. Optimized the auto detection function after upgrading to V1.8.8
07/02/2024
V1.8.8 (Tester)
01/15/2024
V1.8.7 (Tester)
1. Fixed known bugs
01/15/2024
V1.8.6 (Tester)
3. Fixed other known bugs
11/3/2023
V1.8.5 (Tester)
10/08/2023
V1.8.4 (Tester)
1. Fixed known bugs
08/22/2023
V1.8.2 (Tester)
08/04/2023
V1.8.0 (Tester)
2. Protocol Trigger Module on PC | The New Update of POWER-Z KM003C/2C
3. E-Marker Chip Detection | The New Update of POWER-Z KM003C
