Home › News › What's New › Upgrade Your Charge: PeterPower's New SOC GaN Module Chargers
About PeterPower
The first SOC power module company in the world
Shenzhen Peterpower Technology Co.,Ltd (used to be called Goodwin) was located in A building, Xuda industrial building, Fenghuang community, Fuyong street, Baoan district, Shenzhen. Now it has Shenzhen/Vietnam two production center, with more than 400 workers. It is a professional production factory with R&D, production, sales team. And it mainly engaged in PD chargers, GAN chargers, Wireless chargers, smart power socket and other electronic products. It is also the first company who use the SOC power module into the charger.Factory has passed ISO 9001/UL/MFI/BSCI/RBA/USB-IF certificates.
Peterpower always put the quality, delivery and competitive price in the first place. It implements strict quality control throughout the production process. All products were designed according to international standards.As a national high tech enterprise, it has a R&D team of 20 peoples. They focus on developing novel products, optimizing the product function and ID design to provide safe, quick and extremely personal experience in fierce market competition. Thus help us to earn the customers trust. Customer first is Peterpower’s tent. We make innovation-driven, response with high efficiency to help customer win more market, and sincerely welcome your cooperation.
World's First SOC GaN Module Fast Charger
Upgrade Your Charge: PeterPower's New SOC GaN Module Chargers-Chargerlab
First of all, it should be noted that all these chargers adopt the US standard plug by default, and there are multiple common plugs for other countries such as China, the United Kingdom, Australia, Japan and South Korea available.
PeterPower 30W PD SOC GaN Module Fast Charger
The 30W PD single USB-C SOC GaN module fast charger from Peterpower adopts a brand new "advanced technology". The internal circuit integrates IC, MOSFET, transformer, solid capacitors and Triode, making the module simpler. There are no SMD components on the back, which simplifies PCB design and greatly improves yield rate, up to 99.9%.
It has a cream white PC shell with the Apple style black PCB design, and there are recyclable logos and "30W" power markings printed on the surface.
The product supports OEM/ODM. Compared with traditional chargers, it has a quick delivery advantage of 10-15 days, and is expected to reduce customer inventory by 50%.
Specs Info:
Charging power: 30W
Input: AC 100-240V 50/60Hz 0.7A;
USB-C output: DC 5V3A, 9V3A,12V2.5A, 15V2A, 20V1.5A (30W MAX);
Dimensions: 57 x 41 x 31mm (2.24 x 1.61 x 1.22 inches)
Colors: White, Black
Certifications: CCC, ETL, FCC, CE, UKCA, KC, PSE, ROHS
PeterPower 30W PD 1A1C SOC GaN Module Fast Charger
The 30W PD 1A1C USB-C SOC GaN module fast charger from Peterpower adopts a brand new "advanced technology". The internal circuit integrates IC, MOSFET, transformer, solid capacitors and Triode, making the module simpler. There are no SMD components on the back, which simplifies PCB design and greatly improves yield rate, up to 99.9%.
Specs Info:
Charging power: 30W
USB-A output: 5.0V3A,9V2A/12V1.5A
USB-C output: 5V3A,9V3A,12V2.5A,15V2A,20V1.5A
PeterPower 45W PD SOC GaN Module Fast Charger
The 45W PD single USB-C SOC GaN module fast charger from Peterpower adopts a brand new "advanced technology". The internal circuit integrates IC, MOSFET, transformer, solid capacitors and Triode, making the module simpler. There are no SMD components on the back, which simplifies PCB design and greatly improves yield rate, up to 99.9%.
It has a cream white PC shell with the partially black PCB design, and there are recyclable logos and "45W" power markings printed on the surface.
Specs Info:
Charging power: 45W
USB-C output: 5V3A/9V3A/12V3A/15V3A/20V2.25A
PeterPower 45W PD 1A1C SOC GaN Module Fast Charger
The 45W PD 1A1C SOC GaN module fast charger from Peterpower adopts a brand new "advanced technology". The internal circuit integrates IC, MOSFET, transformer, solid capacitors and Triode, making the module simpler. There are no SMD components on the back, which simplifies PCB design and greatly improves yield rate, up to 99.9%.
Specs Info:
Charging power: 45W
USB-A output: 5V3A/9V3A/12V3A/15V3A/20V2.25A
USB-C output: 5V3A,9V2A,12V1.5A
USB-C + USB-A output: 30W + 12W max
PeterPower 45W PD Dual USB-C SOC GaN Module Fast Charger
The 45W PD Dual USB-C SOC GaN module fast charger from Peterpower adopts a brand new "advanced technology". The internal circuit integrates IC, MOSFET, transformer, solid capacitors and Triode, making the module simpler. There are no SMD components on the back, which simplifies PCB design and greatly improves yield rate, up to 99.9%.
Specs Info:
Charging power: 45W
Input: AC 100-240V 50/60Hz 1.5A
USB-C1 output: 5V3A,9V3A,12V3A,15V3A,20V2.25A
USB-C2 output: 5V3A,9V3A,12V3A,15V3A,20V2.25A
Daul USB-C output: 22.5W+22.5W
PeterPower 65W PD SOC GaN Module Fast Charger
The 65W PD SOC GaN module fast charger from Peterpower adopts a brand new "advanced technology". The internal circuit integrates IC, MOSFET, transformer, solid capacitors and Triode, making the module simpler. There are no SMD components on the back, which simplifies PCB design and greatly improves yield rate, up to 99.9%.
It has a cream white PC shell with the partially black PCB design, and there are recyclable logos and "65W" power markings printed on the surface.
Specs Info:
Charging power: 65W
Input: AC 100-240V 50/60Hz 1.8A
USB-C output: 5V/9V 3A,12V/15V 3A,20V 3.25A
Dimensions: 67.8 x 41 x 31mm (2.67 x 1.61 x 1.22 inches)
PeterPower 65W PD 1A1C SOC GaN Module Fast Charger
The 65W PD 1A1C SOC GaN module fast charger from Peterpower adopts a brand new "advanced technology". The internal circuit integrates IC, MOSFET, transformer, solid capacitors and Triode, making the module simpler. There are no SMD components on the back, which simplifies PCB design and greatly improves yield rate, up to 99.9%.
Specs Info:
Charging power: 65W
USB-A output: 5V/3A,9V/2A,12V/1.5A
USB-C+USB-A output: 5V3A
 PeterPower 65W PD Dual USB-C SOC GaN Module Fast Charger
The 65W PD Dual USB-C SOC GaN module fast charger from Peterpower adopts a brand new "advanced technology". The internal circuit integrates IC, MOSFET, transformer, solid capacitors and Triode, making the module simpler. There are no SMD components on the back, which simplifies PCB design and greatly improves yield rate, up to 99.9%.
Specs Info:
Charging power: 65W
USB-C1 output: 5V/9V 3A,12V/15V 3A,20V 3.25A
USB-C2 output: 5V/9V 3A,12V/15V 3A,20V 3.25A
PeterPower 65W PD 2C1A SOC GaN Module Fast Charger
The 65W PD 2C1A SOC GaN module fast charger from Peterpower adopts a brand new "advanced technology". The internal circuit integrates IC, MOSFET, transformer, solid capacitors and Triode, making the module simpler. There are no SMD components on the back, which simplifies PCB design and greatly improves yield rate, up to 99.9%.
Specs Info:
Charging power: 65W
USB-A1 output: 5V/3A,9V/2A,12V/1.5A
Dual USB-C output: 45W+20W=65W
USB-C1+USB-A1 output: 45W+18W=63W
USB-C2+USB-A1output: 5V/3A=15W
USB-C1+(USB-C2+USB-A1): 45W+15W=60W
1. PeterPower Launched Three Qi2 MPP Magnetic Wireless Charger
2. Leading the Industry | Peterpower Launched PD3.1 140W Power Strip
3. Groundbreaking Innovation | PeterPower Unveils the World's First PD67W Charger with SOC Power Module
Charger GaN Peterpower
Fully Charging Test of Samsung S24 Ultra with Samsung 65W Charger
Powering Up: Discovering the Newest PD3.1 Chargers at CES 2024
Same Price, New USB-C Port: Apple Launches Upgraded AirPods Pro 2
September 22, 2023
MOMAX Launched 67W 3-Port GaN Charger
April 28, 2023
Anker Releases SOLIX C300: A 300W Portable Power Station for Outdoor and Dorm Use
October 31, 2024
Anker Prime Thunderbolt 5 Docking Station: 14 Ports, Dual 8K Support, and 140W Power Delivery
June 13, 2025
