Home › News › What's New › Ultra-thin Design | Baseus Blade Series 100W Power Bank Is Now on Amazon
Purchase Link: https://amzn.to/3eFmKWA
Those who often carry laptops out will bring a high-performance power bank to ensure long-term battery life. However, this kind of product is relatively big, and it's hard to put them into your bag. In 2021, Baseus released a 100W power bank from the Blade series with an ultra-thin design. It just fits the size of the bag and can be conveniently taken out.
Ultra-thin Design | Baseus Blade Series 100W Power Bank Is Now on Amazon-Chargerlab
Unlike the common "square bricks" in the market, this Baseus power bank adopts a flat design, and its thickness is only 18mm (0.7 inches). The front of the power bank is printed with 100W, and the twill texture surface can avoid the sticky feeling of the hand sweat and make you hold it more firmly. Four rubber pads at the bottom can also fix the power bank tightly.
As for specifications, it comes with dual USB-C ports and dual USB-A ports. Both USB-C ports support up to 100W output when charging a single device. And both USB-A ports support up to 30W output when charging a single device. When charging multiple devices, it can intelligently adjust to 65W + 30W, 45W + 30W + 18W, etc. And it can charge up to four devices at once. Both USB-C ports can support self-charging, and the charging power can be up to 65W, which can be fully charged in 90 minutes.
Both USB-C ports can support five fix PDOs of 5V3A / 9V3A / 12V3A / 15V3A / 20V5A. The complete PDO can make it more compatible with different devices, such as mobile phones, tablets, game consoles, and laptops. Its built-in battery capacity is 20000mAh / 74Wh, which can provide longer battery life for laptops. It can charge 36% of the 16 inches MacBook Pro in 30 minutes. So you can get back to work in no time.
A LED digital display on the front indicates the remaining battery level, charging power, and estimated charging and recharging time. The numbers are more intuitive than the four LED lights of ordinary power banks. So, customers can get the most critical information at a glance.
With the built-in 20000mAh battery, the Baseus 100W power bank from the Blade series can satisfy the power needs for all day. The flat design is completely different from other products in the market. We cannot find an alternative option with the same powerful performance (100W output and 65W input) and the same flat design. Those four USB ports (2C2A) can charge almost all your devices at once. The LED display is another eye-catching highlight, facilitating users to get the most critical information more intuitively.
It's now on Amazon, priced at US$99. If interested, you can click the link below to check more details about this product.
1. Teardown of Baseus 100W Slim Laptop Power Bank (Blade Series)
2. Video | Review of Baseus 30W Dual-port Charger With Promo Code
3. Teardown of Baseus 160W Multi-port Car Charger (QC 5.0)
100W Baseus
Xinspower Won the First 140W GaN UL62368 Certificate in Mainland China
Teardown of Anker 140W PD3.1 USB-C GaN Charger (717 Charger)
Orico Releases USB-C HDD and SSD docks with USB3.1 Gen2 and More
August 6, 2019
REMAX Launched 100W Sense Series GaN Charger
July 22, 2023
Samsung's Headphone Dongle Leaks Ahead of Note 10 Event
August 2, 2019
August 22, 2024
