In today's world, almost every household is equipped with at least one portable power station. Traditional diesel generators have long fallen out of favor due to issues such as noise, environmental pollution, and more. Portable power stations are not only used in scenarios like picnics, camping, home emergencies, outdoor recreation, and long-distance travel but also play a crucial role in emergency rescue, fishing, sailing, outdoor lighting, and various other fields.
Currently, in the winter season, temperatures across the northern hemisphere have dropped significantly, increasing the frequency of power outages caused by snow disasters and other severe weather conditions. Therefore, whether it's dealing with adverse weather, power outages due to natural disasters, planning camping trips, or long-distance travel, having a high-capacity portable power station is essential.
This time, ChargerLAB has compiled several high-capacity portable power stations with capacities over 1000Wh available in the market, listed in no particular order.
Anker
Anker SOLIX F1200 Portable Power Station
Firstly, from a familiar brand, Anker, the SOLIX F1200 power station resembles a computer with its tech-inspired appearance. We reviewed this power station in a charging review two years ago. Its appearance is a blend of deep blue and gray accents. Weighing around 19.9 kg, it features portable handles designed according to human arm proportions for easy transport. The sides are designed with a bar-shaped grid to enhance heat dissipation during usage, allowing for prolonged use without risking overheating or accelerated component aging.
The ports are concentrated on the front panel. In terms of USB, it features 2 USB-C 4A ports, each labeled with 100W and 60W, while the AC port supports a maximum output power of 1500W. Each port has individual control buttons, and the screen in the middle displays real-time power levels. With a 1229Wh battery capacity, it can easily meet most outdoor power needs.
Jackery
Jackery Explorer 2000 Plus Portable Power Station
We've had a hands-on experience with the Jackery Explorer 2000 Plus, you can check it out here. Its casing is made of 94V-0 fire-resistant material, sporting Jackery's classic black and orange color scheme. The backside is protected by two large rubber plugs for the DC and AC input ports, along with a DC expansion port. The front panel hosts USB and AC ports. There are extensive heat dissipation vents on both sides with grid protection to minimize dust and debris entry.
The front center features an LCD screen displaying power levels and real-time charging and discharging data. It houses a 2042Wh battery capacity. The left side boasts a 12V10A 120W max output DC port with a dust cover and independent switch. The USB setup includes 2A2C ports catering to outdoor mobile device power needs, with the C port supporting up to 100W and the A port up to 18W. The AC port supports a maximum 3000W Max total output.
EcoFlow
EcoFlow DELTA 2 Max Portable Power Station
The EcoFlow DELTA 2 Max maintains the DELTA series' design with a grey-black V-0 fireproof casing and handles on both sides. The top features fan vents, while the back has two fan vents and two ports for additional battery connections to increase total capacity, catering to different user needs. It houses a built-in 2048Wh battery, providing a 220V pure sine wave output, rated output power of 2400W, and a surge of 4800W.
It features six AC outlets, two 100W USB-C outputs, two 12W outputs, two 18W fast-charging A ports, along with two DC outputs and a car outlet. It supports DC and solar panel charging, taking only 1.1 hours from the grid to charge up to 80%.
EcoFlow RIVER Pro Portable Power Station
Next up is EcoFlow's RIVER series. Its digital display integrated in the front allows easy viewing of real-time power, remaining charge, and usage time. Heat dissipation and inputs are situated on the sides, maintaining an appealing front. It features a 720Wh lithium-ion battery, which, though below 1000Wh, can reach up to 1440Wh with an extra battery link. With a rated output power of 600W, it can even power devices up to 1800W using the X-Boost mode.
In terms of configuration, it includes three USB-A, one 100W USB-C port, three AC outputs, and a car outlet. The fastest charging method is 660W AC, taking just an hour to reach 80% charge, while solar panels take 4 to 8 hours and the 12V car recharge takes 8 hours.
UGREEN
UGREEN PowerRoam 1200 Portable Power Station
The UGREEN PowerRoam 1200 adopts UGREEN's classic metal grey design. Its front LCD screen displays real-time power, remaining charge, and usage time. It houses a 1024Wh lithium iron phosphate battery as the energy reserve and supports four charging methods: grid, solar, car, and generator.
The front panel features a lighting lamp, LCD screen, car charging port, USB ports, DC ports, and a power switch. It has 2A2C, totaling four USB ports, with the USB-C port supporting up to PD 100W output, meeting fast-charging needs for smartphones, camera batteries, laptops, etc. The six AC output ports support a rated output power of 1200W, and in U-Turbo mode, it can power high-power devices like induction cookers and kettles.
UGREEN PowerRoam 2200 Portable Power Station
The PowerRoam 2200 is an upgraded version that uses a 94V-0 fire-resistant PC+ABS material for its casing. This material is fingerprint-resistant, durable, and heat-resistant. It features an integrated handle design, ergonomically designed on both sides to fit the force applied by the human body. With the addition of a trailer accessory, its form resembles that of a travel suitcase, allowing for different usage scenarios with an adjustable telescopic handle. The battery capacity is 2048Wh.
It features 2A4C, totaling six USB ports, supporting up to PD 3.1 140W high-power output. It caters to fast-charging needs for phones, gaming consoles, cameras, laptops, etc. The six AC output ports support a rated 2400W output power. In U-Turbo mode, it can power high-power appliances like induction cookers and kettles. It comes with Anderson output ports, DC output ports, car charging ports, and LED lighting for various emergency power situations during travel and camping.
BLUETTI
BLUETTI AC180 Portable Power Station
The BLUETTI AC180 adopts a 94V-0 fire-resistant shell, housing a 1152Wh lithium iron phosphate battery as the energy reserve. Its LCD color screen displays real-time power, remaining charge, and usage time. It supports grid and solar charging methods, ensuring uninterrupted power even outdoors. Through Bluetooth connectivity, it offers smart app control, unlocking more intelligent power usage features.
In terms of performance, it features 1C4A, totaling five USB ports and a top wireless charging area. The USB-C port supports a PD 100W output, catering to fast-charging needs from smartphones to thin-and-light laptops, Switch gaming consoles in TV mode. On the AC side, it has four AC output ports, supporting a continuous output power of 1800W, and boosting up to 2700W for higher needs. It can easily support resistive heating household appliances like induction cookers and kettles, ensuring convenience during outdoor emergencies.
CTECHI
CTECHI ST2000 Portable Power Station
The CTECHI ST2000 features a stylish and cool design, a black body with silver edge panels. The widened handles on the top sides facilitate movement, while side vents ensure airflow and prevent foreign objects from entering. A lighting feature is added to the back. The front panel includes a multifunctional LED screen displaying remaining power, input power, output power, and other parameters. It supports intelligent bidirectional inversion technology, requiring only 1.5 hours for a full charge.
In terms of performance, it has a rated output of 1800W, utilizing a lithium iron phosphate battery with a capacity of 2073Wh, making it a heavyweight contender among portable power stations. It features eight USB output ports (four 6A2C), with blue and white A ports supporting 24W and 12W output, and the C port supporting a maximum 60W output. Additionally, it comes with four DC output ports (XT60) and a car charging port, featuring multiple independent switches for safer power use.
ANFUOTE
ANFUOTE AFT1000 Portable Power Station
The ANFUOTE AFT1000 features an aluminum alloy shell, offering excellent smoothness and a futuristic aesthetic while boasting three colorful options: yellow, green, and silver. It houses a 1013Wh vehicle-grade battery cell, accompanied by an LCD screen on the top, displaying real-time power, remaining charge, and remaining usage. With various charging methods like grid, solar, and vehicle charging, it meets diverse outdoor power needs.
In terms of performance, the AFT 1000 features 2A2C, totaling four USB ports and a wireless charging area. Each port operates independently without interference. The C port supports a PD 100W output, while the A port provides a maximum of 18W. The two AC output ports support a rated output power of 1200W, increasing to about 2000W in elevated modes. Additionally, it includes DC output ports, a car charging port, LED lighting, and features like UPS, elevation technology, and bidirectional inversion technology, providing a better user experience for indoor emergencies or device charging.
PECRON
PECRON E1500 Pro Portable Power Station
The PECRON E1500 Pro showcases a black-grey design and a UL94-V0 fire-resistant alloy shell, enhancing safety. The front panel houses a high-definition LCD screen, providing users with real-time charging status and power levels.
On the front, it features 4A2C output ports, capable of a maximum 100W output, while three AC output ports reach a maximum combined power of 2000W. The AC input charging reaches up to 1200W. On the right side, it includes an XT60 DC output port and a car charging port. With a UL-certified 1450Wh lithium battery, the handles on both sides facilitate movement, while dual side vents ensure stable operation in high-temperature environments.
PECRON E1500 LFP Portable Power Station
The E1500 LFP utilizes a UL94-V0 fire-resistant alloy shell with eight orange anti-collision corners, weighing around 18 kg. The ergonomic handles on both ends facilitate user movement. It houses a 1536Wh UL-certified lithium iron phosphate battery, supporting outdoor cooking operations like boiling water or cooking. Equipped with U-balanceself flash charging technology and bidirectional inversion technology, it can self-charge rapidly in 1 hour and 42 minutes. It supports diverse charging methods like grid, solar panels, car charging, and generators, catering to various outdoor emergency scenarios.
In terms of ports, it features 2C4A, totaling six USB ports with a maximum output power of 100W, catering to smartphones, tablets, cameras, laptops, etc. Additionally, it includes 15W wireless charging, three 2200W AC output ports, one DC output port (XT60), one DC 12V output port (5525), and a car output port. With expandable battery capacity and UPS functionality, it can swiftly switch power within 8-20ms, suitable for emergency power needs for desktop computers and various sudden rescue situations in homes, outdoors, etc.
In the selection of portable power stations, battery capacity and power are primary factors to consider. The capacities of the portable power stations in this collection range from 720Wh to 3108Wh, with the majority falling within 1500Wh.
Regarding output power, portable power stations reaching 1000Wh generally employ pure sine wave output, alleviating concerns about damaging electrical appliances. Their rated output power is also mostly above 1000W, with some reaching 2200W. Additionally, many portable power stations support upconversion drive technology and cascading expansion technology, enabling them to simultaneously power higher-wattage devices.
In terms of ports, the differences between various portable power stations are quite apparent. Apart from common AC outlets and multiple USB-C/A ports, some feature wireless charging modules on the top. Many also have additional ports like car sockets and DC outputs.
Concerning battery cells, portable power stations on the market primarily use lithium-ion, lithium iron phosphate, or lithium polymer cells. Lithium-ion batteries offer high energy density, long cycle life, and low cost. Lithium iron phosphate cells are known for exceptional safety, an even longer cycle life, and strong temperature adaptability. Lithium polymer cells boast small size, lightweight, and high safety.
Functionality-wise, there's considerable variation among available portable power stations. Basic functions like power display, battery management, and charging protection are generally present. However, factors like support for driving higher-wattage appliances, parallel connection capability, bidirectional inverter fast charging, solar charging, app control, UPS/EPS functions, are additional considerations that need to be taken into account.
1. Up to 3000W Output | Review of VTOMAN FlashSpeed 1500 Power Station
2. Jackery Explorer 2000 Plus Steals the Show at Intersolar Europe 2023
3. Review of Jackery Explorer 2000 Plus LiFePO4 Portable Power Station (Video)
