Home › News › What's New › UGREEN Launches The New 45W Dual-port GaN Charger (Simultaneous Fast Charging for Dual iPhones)
Jeffrey
July 12, 2022
UGREEN Launches The New 45W Dual-port GaN Charger (Simultaneous Fast Charging for Dual iPhones)-Chargerlab
Recently, UGREEN launched a new dual-port GaN charger with a compact and portable size, which has a maximum output power of 45W, supporting 25W+20W fast charging for dual devices at the same time.
The charger's model is CD294. It adopts two colors, black and white, with different textures on the four sides and the matt front side.
There are two USB-C ports, either of which can support up to 45W fast charging output separately.
The single port supports five fixed PDOs of 5V3A / 9V3A / 12V3A / 15V3A / 20V2.25A and a PPS of 3.3-11V4.05A. The 15V and 20V high voltage can be better adapted to iPad, Macbook and other devices for fast charging, and the PPS can be used for Android phones to provide low-temperature but high-power fast charging.
The UGREEN 45W charger supports fast charging for iPhone 8-13 series, allowing the iPhone 13 mini to be powered approximately 60% in 30 minutes with built-in security measures for overnight charging without unplugging.
When the ports are charging two devices, the power distribution is intelligently adjusted to 25W + 20W, and both devices can enjoy PD fast charging.
With the GaN technology, the charger is more compact, with a size of 39 X 39 X 49 mm (1.53 X 1.53 X 1.92 inches). The volume is about 74.52cm³ (4.54 in³), and the power density is 0.6W/cm³.
It also supports 100-240V~50/60Hz and adopts foldable prongs.
The new UGREEN 45W dual-port GaN charger is available in two colors: black and white, with a compact size and foldable prongs supporting global voltage standards.
There are two USB-C ports, either of which can support up to 45W fast charging output separately. When the ports are charging two devices, the power distribution is intelligently adjusted to 25W + 20W, and both devices can enjoy PD fast charging.
1. UGREEN Launched The New 140W PD3.1 GaN Charger (3C1A)
2. Review of Asus Adol 100W GaN Charger
3. Review of UGREEN Nexode 3-in-1 65W GaN Charger
45W Fast charging GaN
Charging Review of Apple MacBook Pro 13” (M2, 2022)
The New TEGIC Block 02 Power Bank with Amazing Colors And Designs
Teardown of the Anker737 MagGo 3-in-1 Wireless Charger
Metabo Bets on Tabless Battery Tech for the Future of Power Tools
Xiaomi Jinshajiang Series Upgrades Its Slim Profile with ATL Battery Tech
AOHI Launches Compact 100W GaN+ AC Adapter with Multi-Device Fast Charging Capability
November 14, 2024
MFi Certified & Cordless | MOMAX Launched GOLINK Apple Watch Magnetic Wireless Charger
November 21, 2022
Power Up Anywhere: Introducing UGREEN's Latest Power Bank Innovations
January 14, 2024
UFCS Supported | Huntkey Launched 45W Dual Port GaN Charger
June 9, 2023
Jeffrey
