Home › News › What's New › UGREEN Launches 65W GaN Charger, Slim Design Perfect for Travel
Ellen
July 19, 2024
The rapid development of GaN technology has revitalized the fast-charging industry. Recently, UGREEN introduced the 65W GaN Charger that is shaped like a biscuit. It breaks traditional design with its slimmer profile, making it an excellent travel companion.
UGREEN 65W GaN Charger
UGREEN Launches 65W GaN Charger, Slim Design Perfect for Travel-Chargerlab
The UGREEN 65W GaN Charger comes in a deep gray metallic. The matte surface feels smooth and resists fingerprints. The edges are curved for a comfortable grip. There is a reflective strip around the ports, creating a slight recess in the port area to protect them from wear. The front of the charger features the "UGREEN" in the top left corner and "65W" in the base right corner.
The charger is only 14.5mm (0.57 inches) thick and weighs just 122g (4.3 oz). It has a foldable plug design, making it easy to store and perfect for travel. You can easily slip it into a pocket or any small space, making it an ideal fast-charging companion for trips.
The charger has two USB-C ports and one USB-A port, all supporting fast charging. It supports multiple protocols, including PD3.0/2.0, QC4+/3.0/2.0, SCP, FCP, UFCS, AFC, and Apple 5V/2.4A. With USB-C Smart Charging technology, it intelligently recognizes devices and distributes output power It is suitable for fast-charging phones, tablets, laptops, Switch, earphones, and drones.
The USB-C1 port can support output of 65W Max. The USB-C2 port can support output of 30W Max. The USB-A port can support output of 22.5W Max. When using USB-C1 and USB-C2 ports simultaneously, it can provide a charging power of 45W + 20W. When using USB-C1 and USB-A ports simultaneously, it can provide a charging power of 45W + 18W. When using USB-C2 and USB-A ports simultaneously, it can provide a charging power of 15W. When using all three ports simultaneously, it can provide a charging power of 45W + 15W.
The UGREEN 65W GaN Charger uses the latest GaN IC, offering better performance and an efficiency of up to 93%. Its AirPyra technology reduces the size of main components, creating an ultra-thin design that fits into tight spaces. The ThermalGuard technology improves heat dissipation, supports real-time temperature monitoring, and provides better temperature control.
Compared to the previous generation, the UGREEN 65W GaN Charger is 56% smaller. It is much smaller than Apple's original charger, with only half the thickness. It also provides multiple protections, such as short-circuit, static, over-temperature, over-voltage, and over-current protections, ensuring a safe charging experience.
UGREEN focuses on innovation and practicality in product design. The new 65W GaN Charger features an ultra-thin design, making it a great choice for users who value portability. With three fast-charging ports, it can charge phones, tablets, and laptops all at once. The UGREEN charger excels in charging speed, portability, heat dissipation, and build quality, making it an ideal charging companion for travel and business trips.
1. GaN & PD3.1 | Teardown of UGREEN Nexode 300W 5-in-1 Charger
2. GaNInfinity Technology | Introducing the UGREEN Nexode Pro 65W 3-in-1 GaN Charger
3. The USB-C1 Port of UGREEN Nexode 300W 5-in-1 Charger - ChargerLAB Compatibility 100
65W GaN UGREEN
Charging Compatibility Test of REDMAGIC 9S Pro+
WiFi6E Standard | Lenovo Launched ThinkBook Wireless Dock at CES2023
March 4, 2023
Best-Selling USB Cables on Amazon Japan in May 2023
June 24, 2023
The Reasons Behind the Nintendo Switch Bricking Situation
August 5, 2019
Navitas GaN IC Is Found in Apple 140W PD3.1 Fast Charger
February 15, 2022
Ellen
