Home › News › What's New › Transparent | MOMAX Launched Dual Magnetic Wireless Charging Stand
Remember the good old days when Apple was way ahead of its competitors in product innovation? Such as the iMac G3 with its beautiful translucent plastics compared to other ordinary companies like HP and IBM. Well, today MOMAX has brought us a new dual magnetic wireless charging stand for the new iPhone 14 series, with two magnetic wireless transparent charging areas just like the classic iMac G3!
Transparent | MOMAX Launched Dual Magnetic Wireless Charging Stand-Chargerlab
The Dual Magnetic Wireless Charging Stand is designed with a double transparent magnetic wireless charging module. The base and the top of the pole are equipped with magnetic wireless charging areas, respectively, which are supported by aluminum alloy poles. The surface of the module is covered by 9H tempered glass, which brings a stylish design to the wireless charging equipment and is full of futuristic.
The magnetic wireless charging module adopts 17 N52 Nd-Fe-B strong magnets to form a magnetic ring, which matches the MagSafe magnetic component on the back of iPhone 14, 13, and 12 series, providing 5200gs solid magnetic attraction. When approached, it can be automatically docked. It can provide 15W peak output when charging a single device and 7.5W + 7.5W when charging two devices.
It has a rotating shaft and supports ±20 degrees stepless adjustment. The total adjustment range of 40 degrees is easily aligned with the human eye's perspective. Thanks to the module's vertical and horizontal magnetic attraction mode, it's super easy to chat or watch TV while charging.
It supports up to 8mm(0.31 inches) charging reaction range, the wireless magnetic charge above the pole can be used with or without a magnetic case, and the wireless charger at the bottom supports charging with a standard case. It can charge two iPhones simultaneously or one iPhone and one AirPods, which is suitable for wireless charging of multiple devices.
AirPods 3 / AirPods Pro2 has a MagSafe Magnetic wireless charging module. The charging stand not only supports magnetic wireless charging of mobile phones but also magnetic wireless charging of AirPods 3 / AirPods Pro 2 wireless headphones so that earphones can also enjoy the convenience of MagSafe.
The base comes with a LED light that fully indicates the charging status-breathing while charging, off while finishing charging, and rapid flashing when something goes wrong. The bottom is equipped with an anti-slip silicone pad, which will not slide and shift when placed on the desktop, and is convenient to remove and install.
The Dual Magnetic Wireless Charging Stand follows the MOMAX transparent family design style, made of aluminum alloy and tempered glass, two independent magnetic wireless charging modules, the magnetic wireless charging area on top of the pole supports ±20 degrees stepless adjustment, it can be placed vertically or horizontally, which is convenient for playing mobile phones while charging. It can be charged when placed on the base. It can provide a maximum of 15W wireless transmission power when charging a single device and supports dual-area 7.5W + 7.5W wireless charging at the same time.
1. 10000mAh Power Bank丨 MOMAX Released Upgraded Magnetic Wireless Battery Pack with Stand
2. New MOMAX 100W 6-Port Wireless Desktop GaN Charger Supports Simultaneous Charging of 7 Devices
3. Review of MOMAX Airbox Charging Station(A Foldable Power Bank)
Apple MOMAX Wireless Charging
Apple Watch Ultra vs Series 8 vs SE 2 - Charging Review?
Teardown of BMW Wireless Charging Module (For BMW 5 Series)
August 22, 2024
The New AlphaESS BLACKBEE 2000 Portable Power Station Is Coming Soon
July 26, 2022
Cypress Extends USB-C Leadership with Fully Integrated USB-C Charger Solution for Power Adapter OEMs
May 28, 2019
Apple released 35W dual USB-C charger at WWDC22
June 10, 2022
