Home › News › What's New › Transformers Inside | Anker Launched 65W GaNPrime 733 Power Bank
$99.99 on Amazon US
In addition to their sleek appearance, electronic products can also be given a new lease of life through co-branding partnerships that make fans go wild. Anker, which has previously collaborated with well-known IPs such as "Pokemon," "One Piece," and "SpongeBob SquarePants," has recently teamed up with "Transformers" to release the Anker 65W GaNPrime 733 Power Bank, which combines performance, functionality, and aesthetics to create a stunning product.
Transformers Inside | Anker Launched 65W GaNPrime 733 Power Bank-Chargerlab
Adorned with a black and red energy block design, the Anker 65W GaNPrime 733 Power Bank features the iconic Autobot emblem on its side and the Decepticon logo on its front, giving it a futuristic look. The power bank is coated with skin-friendly PU paint that enhances its durability and scratch resistance.
The Anker 65W GaNPrime 733 Power Bank is a versatile charging accessory that features a two-in-one design, with a built-in lithium-ion battery and AC/DC power adapter. When plugged into a power outlet at home, it becomes a 65W high-performance wall charger. When taken on-the-go, it transforms into a 10000mAh power bank that provides extra battery life for electronic devices.
The Anker 65W GaNPrime 733 Power Bank boasts three ports, including two USB-C and one USB-A, that support fast charging protocols such as PD3.0, PPS, QC, SCP, and FCP. The folding plug design offers universal compatibility with a 100-240V input voltage range, and a long-lasting battery with a capacity of 10000mAh can charge an iPhone 13 more than twice or an iPad mini6 1.3 times, satisfying daily travel needs.
Based on the GaNPrime multi-port fast charging system, the Anker 65W GaNPrime 733 Power Bank integrates innovative stacked technology, gallium nitride technology, ActiveShield 2.0 for intelligent temperature monitoring technology, and PowerIQ 3.0 charging technology to create a smaller, more powerful, and safer product.
When used as a charger, both USB-C1/C2 ports support 65W fast charging output, that means you can get the maximum charging speed from either port, making them suitable for high-power devices such as laptops. The USB-A port supports 22.5W output. When charging multiple devices simultaneously, the Anker 65W GaNPrime 733 Power Bank can fast charge two devices at 45W plus 20W or three devices at 45W plus 5V3A.
When used as a power bank, the Anker 65W GaNPrime 733 Power Bank relies on its built-in 10000mAh battery to provide power. Both USB-C1/C2 ports support 30W fast charging output, which is sufficient to charge mainstream electronic products such as the iPhone 14. The USB-A port supports 22.5W output. When using all three ports, the maximum output is 5V3A, which can charge up to three devices simultaneously.
The Anker 65W GaNPrime 733 Power Bank is a co-branded product that incorporates multiple elements of the sci-fi design of "Transformers." With its long-lasting battery cells and AC/DC charging module, it provides a versatile dual-mode charging function, including a 65W charger mode and a 30W power bank mode, that caters to the needs of both home and travel use. Equipped with two USB-C and one USB-A ports, it supports charging multiple devices and has a wide voltage range of 100-240V, making it the perfect travel companion that combines the functions of a charger and power bank within one device, while also helping to save space and weight in your luggage. Whether you're at home or on-the-go, the Anker 65W GaNPrime 733 Power Bank is the perfect choice for all your electronic devices.
Right now, the Anker 65W GaNPrime 733 Power Bank Transformers Edition is priced at $99.99 on Amazon US, you can click the button at the beginning or the end of the article to get one.
$99.99 on Amazon US
1. Powerful & Versatile | Anker Launched 11-in-1 USB-C Docking Station
2. Teardown of Anker 30W USB-C GaN 511 Charger (Nano 3)
3. Teardown of Anker 140W PD3.1 Power Bank (737 Power Bank)
65W ANKER GaN GaNPrime
MOMAX Launched 67W 3-Port GaN Charger
Computer Case With 60W Fast Charging: Meet the ROG Hyperion GR701
Microchip’s dsPIC33FJ64GS606, Setting a New Standard for AI Server Power Control
Demystifying CRPS, 1U, and 2U
Tesla Launches Qi Wireless Phone Charger for Model 3
June 11, 2019
ACASIS Launches Multi-bay Thunderbolt 3 Hard Drive Hub, Which Supports RAID Arrays
April 30, 2021
Goal Zero Releases Lightweight Power Station Yeti 200X with AC Outlet and USB-C PD
October 22, 2019
April 9, 2026
