Home › News › What's New › The New Magnetic Magic Case Charger Folds, Holds And Charges 3 Devices
Jeffrey
August 25, 2022
A reproduction article from Kickstarter
Magic Case, which aims to create a safe, compact, fast, and pretty charger, believes that a better charging experience is long overdue for everyone. They are passionate about making a difference and hope that their project will change how people think about charging their devices. They launched crowdfunding for the "Magic Case Charger" on Kickstarter. It's a magnetic charger that can fold, hold and charge three devices.
The New Magnetic Magic Case Charger Folds, Holds And Charges 3 Devices-Chargerlab
Convenience
The charger adopts magnetic materials to make it easy to mix and match with iOS and Android devices, and it's compact so that you can save space and take it on the go. Therefore, you no longer need to tote around a gazillion chargers and cables for all your devices, for the charger uses magnets instead of cables.
You don't have to worry about slipping and dropping when charging your devices because it adheres to them with magnets.
Compatibility
The charger is compatible with both iOS and Android devices and can charge up to three devices at the same time. There's no need for batteries or cables, so you can simultaneously charge all your Samsung phones, Apple AirPods, and iPhones. No extra plugs, cables, or switches are needed.
Safety
It's worth noting some wireless chargers don't take any measures to protect against electromagnetic radiation. Additionally, many chargers on the market are constructed with shoddy hardware, which could be harmful to you and your family.
Safety is of the utmost importance to this Magic Case charger. It uses professional-grade magnetic isolation sheets that are already built in to prevent radiation inside. Additionally, it has been integrated into the Apple Ecosystem to maintain battery health, unlike other non-Apple brand chargers that are incompatible with iOS.
Magic Case, launched crowdfunding for the "Magic Case Charger" on Kickstarter. It's a magnetic charger that can fold, hold and charge three devices. The charger adopts magnetic materials to make it easy to mix and match with iOS and Android devices, and it's compact so that you can save space and take it on the go. And you don't have to worry about slipping and dropping when charging your devices because it adheres to them with magnets.
Hyper Crowdfunds for Its HyperDrive Thunderbolt 4 Power Hub with 4 Thunderbolt Ports
Charger Fast charging ios magnetic Wireless Charger
Charging Review of Apple MacBook Air 2022 With M2 Chip
Charging Compatibility Test of Xiaomi 12S Pro
Small but powerful丨mophie launched a speedport 45 2-port GaN wall charger (45W)
August 31, 2022
GaN Tech Became Huge Trends for Chargers at Global Sources Mobile Electronics Show
October 20, 2019
T-Shaped & MFi Certified | Native Union Launched 2-in-1 Belt Cable
March 23, 2023
Lightweight Portability: Unveiling the SHARGE 5,000mAh Flow Mini Power Bank
January 3, 2024
Jeffrey
