You can buy it on Oneplus official website: Click here.
Hi, guys. Today, we will tear down the Oneplus Warp Charge 65W power adapter, which is firstly appeared on the OnePlus 8T, and then the OnePlus 9 Pro.
Except for the 65W Warp Charge, it also supports PD and PPS fast charging to be compatible with more devices.
The 6.5A cable is required if you wanna charge your Oneplus phone.
Safety X Capacitor: STE
Electronics Electrolytic Capacitors: AiSHi
Master Control Chip: ON NCP1342
Primary Switch MOSFET: ST STF13N65M2
Optocoupler: Everlight EL1019
Secondary Synchronous Rectifier Controller: ON NCP4306
Secondary Synchronous Rectification MOSFE: AOS
Schottky Diodes: PS10100LT
Output VBUS Switch MOSFET: AOS AON7400A
