If you wanna buy the tester of POWER-Z, you can visit our Amazon store: Click here
As the first 200W charger designed for mobile phone, the iQOO 200W GaN Charger can fully charge the iQOO 10 Pro within 10 mins. Pretty impressive.
The size is slightly larger than the iQOO 120W GaN charger, but the power density is significantly improved.
It can support 200W ultra-fast charging for iQOO 10 Pro. But for other PD devices, the output can only be up to 65W.
Fuse: WalterFuse (3.15A 250V)
Safety X2 Capacitor: CARLI (0.33μF)
Bridge Rectifier: Pingwei GBL610 (6A 1000V)
PFC Controller: ON Semiconductor NCP1623
GaN IC for PFC boost: Navitas NV6136A (170mΩ, 700V)
PFC Boost Rectifier: ES3JBF (600V, 3A)
Electrolytic Capacitor: AiSHi (420V 82μF)
Master Controller: Dialog iW9802
Auxiliary MOSFET: Semipower SW7N65D (650V, 1.1Ω)
Power Supply Capacitor: TEAPO (10µF 100V)
SMD Y Capacitor: TRX TBY2331KB, TRX TBY2101KB
Optocoupler: COSMO 1019
Synchronous Rectifier Controller: MPS MP6908A
Synchronous Rectifier: Vergiga VSP003N10HS-G (100V, 3.8mΩ)
Protocol Chip: Richtek
Output VBUS MOSFET: Vergiga VS3698AE (30V, 3mΩ)
1. iQOO 10 Pro | 200W Flash Charge (0-100%)
2. Charging Compatibility Test of iQOO 10 Pro
3. Which One Is Faster? iQOO 9 Pro or iQOO 8 Pro
