Home › Teardowns › Power Banks & Stations › Teardown of IDMIX Q10 Pro 15W Magnetic Wireless Charging Power Bank with Stand
buy now
IDMIX has launched a magnetic wireless charging power bank, which comes with a built-in stand that can be used as an iPhone stand. The wireless power bank supports 15W wireless charging, with a USB-C port that supports 20W wired fast charging.
The portable wireless power bank, which has a built-in 10000mAh lithium battery, is easy to carry and feels good in hand. It also has an LED digital display to show the remaining power.
ChargerLAB will bring you the teardown of the IDMIX magnetic wireless power bank. So next, let's take a look at the internal components and structure.
Q10 Pro Magnetic Wireless Charging Power Bank Unboxing
Teardown of IDMIX Q10 Pro 15W Magnetic Wireless Charging Power Bank with Stand-Chargerlab
The IDMIX logo and selling point description are printed on the front of the box.
The packaging is printed with three usage scenarios: wireless charging; the stand is unfolded for portrait/portrait mode in wireless charging; 2 iPhones are wired and wirelessly charged at once.
The manufacturer info is printed on the back.
 I'll introduce it later below based on the product itself.
The packaging contains a power bank, USB-C cable, instruction manual, and warranty card.
The USB-C cable is a short dual USB-C type, which is convenient for daily take-out and use while charging.
The edges of this wireless power bank are rounded, which feels comfortable in hand.
The surface of the metal frame is sprayed with silver-gray metallic paint, making it exquisite and smooth to the touch. When the alloy stand is unfolded, the iPhone wireless power bank can be transformed into an iPhone stand, making it convenient for users to charge while watching videos, etc. The alloy stand ensures strength and durability. There is a power digital display in the upper left corner of the body.
There is a power button on the side of the device and a USB-C port on the other side.
The USB-C port supports 18W fast charging input and 20W fast charging output, which provides users with two options of wired charging and wireless charging, allowing users to use it as they want.
On the back of the device, the magnet ring area is convex and the coil area is concave, so that the phone will be not completely attached to the power bank when charging wireless, which helps dissipate heat. It is a very thoughtful design.
PRODUCT DETAILS
Product name: Magnetic wireless charging power bank
Model: Q10 Pro
Battery type: Lithium polymer battery
Battery capacity: 10000mAh/3.85V/38.5Wh
Rated capacity: 6160mAh (5V/2.4A)
USB-C input: 5V/3A, 9V/2A
USB-C output: 5V/2.4A, 9V/2.22A, 12V/1.5A
Wireless output: 5W/7.5W/10W/15W
Total output: 5V/2.4A
The product has passed IEC certification.
The length of the power bank is about 109mm (4.29 inches).
The width is about 71mm (2.80 inches).
And the thickness is about 19mm (0.75 inches).
You can intuitively feel the size of the product in your hand.
The weight is about 217g (0.48 lb).
Take the Apple iPhone 14 Pro Max as an example. When charged wirelessly, the power bank will not block the rear camera, allowing users to play or take pictures while charging.
Magnetic attraction is very strong.
When charging starts, a prompt to start charging will pop up.
The ChargerLAB POWER-Z KM003C shows that the USB-C port supports FCP, AFC, QC3.0/4+, SFCP, PD3.0, PPS, DCP, and SAM 2A charging protocols.
It has three fixed PODs of: 5V3A, 9V2.22A, and 12V1.67A, as well as two sets of PPS voltage levels: 5-5.9V3A and 5-11V2A.
Now that we’ve finished unboxing this power bank, it’s time to take it apart and examine its internal components and structure.
Remove the case along the seams of the shell, which is fixed by buckles.
The cover plate has a window for LED digital power display.
An overview of the inside. The top is the PCBA module and the bottom is the battery pack. The battery pack is pasted with red tape for insulation.
The internal PCBA module, where the battery and wireless charging coil are soldered and connected.
The PCBA module is fixed with screws.
Unscrew the fixing screws, take out the battery and PCBA module, and the wireless charging coil is stick inside the case.
Take out the wireless charging coil. The coil is wound with Litz wire to reduce the thickness.
A magnet is fixed inside the casing.
The bracket is pasted with tape for insulation.
Take out the small magnet inside the casing.
Two batteries are connected in parallel. The battery thickness is 6.7mm, width is 60mm, length is 76mm, voltage equalization is 3.85V, and the power is 19.25Wh.
The wireless charging coil is attached to the other side of the battery.
A close-up of the wireless charging coil, which is wound with Litz wire.
The front view of the PCBA module shows the power button, battery protection chip, filter capacitor, master control chip and alloy inductor. On the right side is the USB-C socket.
The boost circuit, CBB resonant capacitor, wireless charging controller, integrated power stage chip and segment LED display are soldered on the back of the PCBA module.
The master control chip of the power bank adopts iSmartWare SW6201. This is a highly integrated multi-protocol two-way fast charging power bank dedicated all-in-one chip that supports fast charging of any A+A+B+C port. It integrates 5A high-efficiency switch charging, 18W high-efficiency synchronous boost output, supports PPS, PD, QC, AFC, FCP, SCP, PE, SFCP and other fast charging protocols.
The 2.2μH alloy inductor is reinforced with potting compound on both sides.
Close-up of segment LED display for power indicator.
The plastic sheet inside the USB-C socket is black.
The IDMIX Q10 Pro 15W Magnetic Wireless Charging Power Bank has a built-in high-quality battery cell, with curved edges, a mini body that feels good in hand, and its compact design makes on-the-go charging easy.
Additionally, the portable power bank can charge for 2 phones wirelessly and wired at once. It has 20W PD wired fast charging, making it compatible with Apple and Android phones. This power bank has passed CE and UL certifications.
buy now
1. Power Bank & Charger Combined | Anker 511 Pro Power Bank Experience
2. Review of IDMIX 4-in-1 10000mAh Power Bank with Built-in Cables
3. Trendy & Cool | IDMIX Launched 65W GaN Power Adapter Socket
IDMIX magnetic Wireless Charging
How Fast Is Infinix Note30 Pro Charged? - ChargerLAB Compatibility 100
Ultimate Power: Navigating These High-Capacity Portable Power Stations
Teardown of Apple iPhone 11 Pro Max Smart Battery Case
August 5, 2021
Teardown of EcoFlow RAPID 170W 25000mAh Power Bank (EF-HB-002)
September 28, 2025
March 20, 2026
Teardown of Huawei SuperPower 100W 12000mAh Power Bank (P0020)
October 3, 2025
