On April 14th, SHARGE, a geek brand focusing on high-performance personalized fast charging, officially co-branded with the flim "Wandering Earth II" to launch the SHARGE Internet hostkey power bank. The film received many positive reviews in China. On May 10th, SHARGE once again released high-level creative design, and launched the second officially authorized peripheral for the film "Wandering Earth II" - the MOSS 40W charger.
Product Introduction
MOSS is an intelligent computer that firmly performs its mission in the film "Wandering Earth II". The charger created by the SHARGE perfectly reproduces the MOSS's details from the film, with a sci-fi mechanical feel. The "MOSS eye" on the front also has a built-in red indicator light, which is really vivid!
This 40W charger adopts a split design, consisting of two parts: the MOSS intelligent host computer (charger itself) and an exclusive bracket. It can be assembled and disassembled through the side shaft. It will be displayed as a model after merging and the charger can also be used separately.
The input adopts a foldable prongs design, which can be hidden inside the case for more portability when carrying out. Due to its structure, after inserting into the adapters, it supports the three mainstream socket forms of European, British, and Australian standards. The input supports a wide voltage range of 100-240V~50/60Hz. There is no need to worry about compatibility between the power grid and socket form when traveling cross countries and regions.
Two ports are at the bottom to make the appearance more restored. The 40W USB-C fast charging output port supports 5V3A/9V3A/12V3A/15V2.6A/20V2A PDOs, and a set of 3.3-11V3A PPS. There is also an 18W USB-A fast charging output port. The charger can be compatible with all mainstream electronic devices and different cables.
The maximum 40W output can fully meet the fast-charging needs of iPhones, iPads, laptops, and wireless headphones. At the same time, it has a PPS and fast charging protocols such as QC, FCP, and SCP, making it very compatible with Android phones. When charging dual devices, the output power is intelligently adjusted to 20W+18W, allowing both devices to enjoy fast charging simultaneously.
The MOSS 40W charger adopts a split design. The appearance is very restored. The charger can be used separately or merged as a collection of the film. The foldable prongs support transfer to different adapters and wide range voltage input for travel across countries and regions. The 1A1C dual output design supports 40W PD output and 20W+18W dual device simultaneous fast charging, making it compatible with all mainstream electronic devices.
The MOSS 40W charger is currently available on the official website of SHARGE. SHARGE collaborated with the film "The Wandering Earth II" to present the supercomputer MOSS as a charger product to fans, especially players who like fast charging devices. This is great news for both parties.
1. A U-Disk Alternative? | SHARGE Portable SSD Enclosure With Active Cooling Fan
2. Shargeek Retro 67 Charger: Fast, Stylish, and Innovative Charging Solution for All Your Devices
3. Teardown of SHARGE / STORM 2 100W Transparent Super Power Bank
