Home › News › What's New › Revolutionary Safety Upgrade丨Baseus Released PowerCombo Digital Power Strip 65W
Jeffrey
September 1, 2022
To meet the need for fast charging and make the power strip looks different, Baseus decided to launch a fast charging power strip to bring some changes.
Revolutionary Safety Upgrade丨Baseus Released PowerCombo Digital Power Strip 65W-Chargerlab
Baseus recently released its PowerCombo Digital Power Strip 65W, designed to help users charge more efficiently. It has made a huge upgrade on safety measures as well.
Baseus has achieved a revolutionary safety upgrade on the power strip. They used smart control technology on the power strip, a planted-in digital circuit offering a real-time monitor of all the circuits for situations like overload, over-voltage, under-voltage, over-current, short circuit and more.
And for the AC part, they use a master chip to precisely monitor the circuits in real-time. It will automatically cut off the power if anything abnormal occurs. And to let users better understand an active safety measure, they have designed three different statuses for the indicator, instantly telling you if it's safe or not.
And for the socket layout, they have abandoned the traditional flat-type layout and adopted a vertical-type design to avoid plugs interfering, which saves space and looks tidy.
There is a touch control button to replace the traditional mechanical press button, and the power strip is also spark-proof for much fewer possible electric shocks, safe and reliable.
It adopts the fifth-gen of GaN technology (GaN5) with a 10% increase in power density and efficiency up to 92.3% compared to the last generation. In addition, it is much smaller and lightweight, with a higher chip integration and energy conversion rate and better control for charging temperature.
To make it even more convenient for our users, it uses a 0.8m-long patented retractable cable. You can easily pull out the cable at any length you want (within 0.8m), and after you are done using the cable, it can be easily retracted back in.
It supports fast charging three devices at the same time, such as phones, tablets and laptops, and the fast charging protocols covered are PD, QC SCP, FCP, AFC, PE+ and more.
To meet the need for fast charging and make the power strip looks different, Baseus decided to launch a fast charging power strip to bring some changes. It is the PowerCombo Digital Power Strip 65W, designed to help users charge more efficiently. It has made a huge upgrade on safety measures as well.
1. Adorable Capsule丨Anker Launches New 615 USB Power Strip (GaNPrime 65W)
2. Huntkey Launches New SSH608C Power Strip with A One-handed Intelligent Control Plug
3. Up to 2400W丨 Baseus Launched 600W Portable Power Station with Digital Display (Parallel Operation)
65W Baseus Fast charging GaN
How to use the ChargerLAB POWER-Z KM002C PD3.1 tester to check fast charging protocols of devices?
Charging Compatibility Test of Acer Swift 3
Huawei's Surprise Launch: Mate 60 Series Hits the Shelves
September 3, 2023
Upgrade Your Charge: PeterPower's New SOC GaN Module Chargers
March 12, 2024
9498mAh Battery Capacity | Deep Delve into Apple Vision Pro Battery
March 3, 2024
LKTOP Launches Battery Handle for DJI Osmo Pocket 3
March 14, 2025
Jeffrey
