Home › Reviews › Power Banks & Stations › Review of Soodatek 20W Magnetic Wireless Power Bank
Ever since the iPhone 12 series, people have loved MagSafe wireless charging for its portability and convenience. ChargerLAB has previously covered several wireless power banks; today, we bring you the Soodatek 20W Magnetic Wireless Power Bank, which is compatible with iPhone 12-14 series phones and boasts a sleek minimalist design. Let's see how it performs.
Unboxing
Review of Soodatek 20W Magnetic Wireless Power Bank-Chargerlab
The packaging of the Soodatek 20W Magnetic Wireless Power Bank features a pure white background and neon font style, with the brand name "Soodatek" at the top, along with instructions for PD 20W charging. On the front, there is a depiction of the power bank's appearance and its main selling points: USB-C Port, Safety On Flying, Fast Charge For iPhone 12 Series, with a battery capacity of 5000mAh.
On the back of the box, you will find product specifications, barcodes, and instruction manuals. The model number is S-PB-50, with a battery capacity of 5000mAh made of ABS material. The input and output of USB-C are both 5V3A, 9V2.22A, 12V1.67A, and the total output when wirelessly charged and using the Type-C port is 20W.
Upon opening the package, you will find all the accessories, including the power bank, a product manual, and a USB-C to USB-C cable.
The Soodatek 20W Magnetic Wireless Power Bank is made of environmentally friendly ABS material, treated with anodic oxidation process, and has a metallic feel. The gray and white magnetic part on the front is similar to the MagSafe charging label on Apple's official phone case. There are no other markings, keeping its design extremely minimalist.
Regarding ports, from left to right on the bottom, there are five LED battery indicator lights, a USB-C port, and an orange power button.
The leftmost bar-shaped LED indicator light is for wireless charging, flashing blue during wireless charging. The other four are white battery indicator lights.
The Soodatek 20W Magnetic Wireless Power Bank has important information engraved on the back that matches the packaging box.
Additionally, a USB-C to USB-C charging cable is included, held in place with a black wire tie.
The cable has a standard ABS material for the connector.
The length of the cable is about 30cm (11.81 inches), it is perfect for travel use.
And the length of the Soodatek 20W Magnetic Wireless Power Bank is about 98mm (3.86 inches).
The width is about 64mm (2.47 inches).
And the thickness is about 17mm (0.67 inches).
Finally. the weight is about 140g (4.94 oz)
Compatibility
The Soodatek 20W Magnetic Wireless Power Bank works seamlessly with the iPhone 13 mini, fitting snugly against the edges without obstructing the camera module.
The good news is that it's also compatible with the iPhone 14 series, allowing for uninterrupted usage of its camera module.
This includes the larger camera module found in the iPhone 14 Pro, which poses no obstruction to this power bank. Even the larger iPhone 14 Pro Max is fully adaptable to this power bank.
Protocol Test
To enhance the user's fast charging experience, matching output devices to specific protocols optimizes performance.
The POWER-Z KM003C test results show support for a wide range of fast charging protocols such as FCP, AFC, QC3.0, QC4+, PD 3.0, and PPS through its USB-C port.
As for the PDO info, the USB-C port comes with three fixed PDOs of 5V2.4A, 9V2.22A, 12V1.67A, and a PPS of 3.3-11V 2A, which is slightly different from the specs info.
Test
Let's take a closer look at the user experience of the Soodatek 20W Magnetic Wireless Power Bank. ChargerLAB provides comprehensive details on the charger's compatibility with various devices, and its charging efficiency.
The compatibility test phase can clearly show the charging situation of the Soodatek 20W Magnetic Wireless Power Bank for various types of devices. ChargerLAB will use dozens of devices to test with the power bank to present real testing data to the readers.
Charging an iPhone 14, the charging power measured by the POWER-Z KM003C tester is 9.22V 1.85A 17.07W.
For a Xiaomi 11, the measured charging power is 8.42V 2.58A 21.69W.
When summarizing the data in a table, it can be seen that most devices support charging at 9V2A.
When presented in a bar chart, it is clear that the power of the power bank charging various devices is between 10-22W, and the highest power is when charging a Xiaomi 11, which is 21.69W.
To simulate the daily use of the power bank by users, ChargerLAB tested the charging and discharging process of the power bank. Apple's 35W charger was used to charge it, and the specific test data are as follows.
After being connected to the power supply, the voltage level is 9V, and the power is stable at around 12W for the first 1 hour and 13 minutes. Then, the power gradually decreases until the power bank is fully charged, which takes about 2 hours and 17 minutes.
When presented in a curve chart, it can be visually seen that it takes 51 minutes for the Apple 35W charger to charge the Soodatek 20W Magnetic Wireless Power Bank to 50%, 1 hour and 23 minutes to charge it to 80%, and 2 hours and 17 minutes to fully charge it.
Conversion Efficiency Test
Conversion efficiency is an important factor in measuring the quality of a power bank. The efficiency of the power bank is different when outputting at different voltage levels. The higher the output efficiency, the higher the conversion rate, and the less heat generated. This time also tested the output efficiency of this power bank at different output voltage levels.
Firstly, let the power bank continuously output at a power of 5V2.4A 12W until the battery is depleted, which ended in 1 hour and 02 minutes. The actual discharged battery energy was about 12.4107Wh, so the efficiency of the power bank when outputting at 5V2.4A 12W is about 12.4107/18=68.95%.
Next, let the power bank continuously output at a power of 9V2.22A 20W until the battery is depleted. During the process, it automatically switches to the 5V, and cannot continuously output at 9V 2.22A 20W.
Finally, let the power bank continuously output at a power of 12V1.67A 20W until the battery is depleted. During the process, it automatically switches to the 5V, and cannot continuously output at 12V 1.67A 20W.
The Soodatek 20W Magnetic Wireless Power Bank comes in a gray-white color and boasts a design similar to the MagSafe charging logo found on official Apple phone cases. This device has been tested and proven compatible with iPhone models featuring magnetic charging capabilities. Additionally, the wireless power bank packs a built-in battery capacity of 5000mAh and has a thickness of approximately 17mm (0.67 inches).
It supports both a 20W USB-C output and a maximum wireless output power of 15W. Tested with numerous mainstream smartphones and tablets on the market, it exhibits excellent compatibility and supports fast charging protocols such as PD, QC, and FCP. Regardless of whether you use iOS or Android devices, it can satisfy your charging requirements. When tested with an Apple 35W charger via the USB-C port, the power bank can be fully charge in just 2 hours and 17 minutes.
All things considered, the Soodatek 20W Magnetic Wireless Power Bank is an excellent device for your iPhone during outdoor travel. Its various output modes can intelligently adjust during long-term use and can sustain output for over an hour, ensuring that your phone's battery life remains guaranteed.
1. Foldable Kickstand | Teardown of Baseus 20W MagSafe Wireless Power Bank
2. 20W Wired Fast Charging | Baseus Launched 10000mAh Magnetic Power Bank
3. Teardown of Baseus 20W 10000mAh MagSafe Wireless Power Bank (For iPhone 14/13/12)
20W magnetic soodatek Wireless Charging
Navitas Launches into High-Power Markets with GeneSiC SiCPAK Modules
EcoFlow BLADE: A Revolutionary Smart Robotic Lawn Mower Debuts at CES 2023
iQOO Neo 6 | 80W Flash Charge (0-100%)
June 1, 2022
20W | Review of Durex 10000mAh Magnetic Power Bank
July 6, 2024
OPPO SuperVOOC 50W Power Bank Teardown Review: Pikachu Power!
June 24, 2019
How to Choose a Convenient Multi-Port Charger for Everyday Use?
February 18, 2023
