Home › Reviews › Power Banks & Stations › Review of EHOM EP600 Portable Power Station
  • 4
LONCIN Universal Power Limited by Share Ltd (Shanghai Stock Code: 603766) was founded in 1993. It is a large private enterprise engaged in motorcycle, motorcycle engine, and general power machine production. Its products are sold in more than 100 countries and regions. With the improvement of environmental protection concepts, it has also begun to dabble in outdoor power stations.
ChargerLAB has previously tested the portable power station EP1650 of EHOM. It performed well in terms of charging, discharging, and functionality. This time, we got another portable power station EP600 also from EHOM. Its battery capacity is 512Wh. The rated output power is 600W. It also adopts the LFP battery and bidirectional inverter. It features SpurFlux technology and it can charge ten devices at the same time.
Next, let's do some tests to see how it performs.
Review of EHOM EP600 Portable Power Station-Chargerlab
The box of the EHOM EP600 Portable Power Station is green and white. The logo of EHOM is printed on the top of the front. And there are several selling points printed on the bottom.
Some specs info are printed on this side. Model is EP600-2. The battery capacity is 512Wh. The rated output power is 600W. The net weight is 7.8kg (17.2 pounds). The size of it is 261 x 163 x 301 mm (10.27 x 6.41 x 11.85 inches). The type of battery cell is LFP.
The box contains the power station, an AC power cord, a car charger, and some documents.
It is equipped with Esturdy technology. It supports IPX3 protection and supports drops from a height of 1.2 meters. The one-piece shell is made of fire-retardant material. The built-in high-quality components, battery management system, and LFP batteries can ensure reliability for outdoor use.
There is an LED light on the front of the power station that can adjust the brightness. The LED light can be controlled by the APP or the independent button on the left side. It also has bright light and SOS modes. The "EHOM" is printed below the light.
There is a wireless charging area in the middle of the top of the outdoor power station. The wireless charging power can be up to 15W. There are two handles on the top, which are ergonomically designed.
There are anti-slip mats at the four corners of the bottom to prevent sliding. The specs info are also pasted in the middle of the bottom. Model is EP600-2. The battery capacity is 512Wh (25.6V/20Ah). It can support AC input of 220~240V 50/60Hz 10A Max 600W Max. The DC input can be up to 11~30V 160W Max. The AC output is 230V 50/60Hz 2.6A 600W (1200W Surge). The car charger can support a charging power of up to 12.6V/10A 126W. The output power of a single DC5521 port is 36W, and the total output of two ports is 72W. The output power of a single USB-C port is 100W, and the total output of two ports is 200W. The output power of a single USB-A port is 18W, and the total output of two ports is 36W. The wireless charging power is 5/7.5/10/15W. The battery tape is LFP.
There is a TrueSight anti-glare display, a car charger output module, and a USB output module on the side.
The TrueSight anti-glare display can show the remaining power, input and output power, and available time. The difference between actual power and displayed power does not exceed 3W, and the error control is excellent. The brightness of the display can be adjusted from 0 to 100% by the APP. There is a main switch and a Bluetooth button below the display.
On the right side of the display is the DC output module, from top to bottom are the car charger port, two DC5521 output ports, two USB-C ports, and two USB-A ports. Each port is protected by a dust-proof rubber plug. There is also a switch for the DC output module below. The car charger supports 12V 10A 120W maximum output power, and the DC5521 output port supports 36W. Both the USB-C ports and USB-A ports are independent, and a single port supports output of 100W and 18W respectively.
The AC output module is on the upper side of the other side. There are two European AC outlets here. It supports a rated voltage of 230V and a rated output power of 600W. It can drive devices with a power rating of 1600W through SpurFlux technology.
There is a plastic cover under the AC output module. There is a DC input port, AC input port, overload protector, and grounding port inside the cover. It supports input of 220-240V 50/60Hz.
There is a buckle at the bottom of two sides of it.
After separating the buckle, you can open the multi-functional storage box at the bottom. It can store AC and DC charging cables, or place some tools or medicines to deal with emergencies.
It also supports ColdFusion technology. The built-in high-speed fan and the fluid mechanics design with independent intellectual property rights allow the cooling air to flow through and cover the heat source as fully as possible, and then through dynamic fan control, quickly remove the heat to achieve temperature control, prevent safety hazards or shorten the life of components.
This is a schematic diagram of the fluid dynamics simulation of the EP600 air duct provided by EHOM.
The length of it is about 26 cm (10.24 inches).
The width is about 16 cm (6.3 inches).
The height is about 30 cm (11.81 inches).
And the weight is about 8 kg (17.64 pounds).
It can be easily lifted with one hand, and the handle feels good.
The EP600 is also available in a variety of colors to meet the different needs of consumers. The tough design reflects the durability of it. The metal handle on the top and the storage box at the bottom reflects the understanding and respect for user experience.
Protocol Test
Next, we will test the protocols supported by the USB-A and USB-C ports.
The ChargerLAB POWER-Z KM003C shows the USB-C port can support FCP, SCP, AFC, QC3.0, QC5, SFCP, PD3.0, PPS, DCP, and Apple 2.4A charging protocols.
And it has five fixed PDOs of 5V3A, 9V3A, 12V3A, 15V3A, and 20V5A, and a set of PPS, which is 3.3-21V5A.
The ChargerLAB POWER-Z KM003C shows the USB-A port can support FCP, SCP, AFC, QC3.0, SFCP, DCP, and Apple 2.4A charging protocols.
Next, let's see the charging compatibility of the USB-C and USB-A.
Use any USB-C port to charge the Huawei MateBook X Pro, ChargerLAB POWER-Z KM003C shows the power is about 19.99V 4.89A 97.84W.
From this chart, it can be seen that the voltage of most phones can reach about 9V, and most game consoles and tablets can reach about 15V. All laptops tested can reach about 20V.
We have compiled the test results into a bar chart. The highest charging power is 97.84W of the Huawei MateBook X Pro. The charging power of phones remains in the ranges of 15W, 18W, and 27W. Some devices that support the PPS protocol can reach a voltage of about 78V. It has no compatibility issues and can provide fast charging for most devices.
Use any USB-A port to charge the iQOO 12 Pro, ChargerLAB POWER-Z KM003C shows the power is about 9.11V 1.91A 17.43W.
From this chart, it can be seen that the voltage of most phones can reach about 9V, and a small number of phones reach about 5V.
We have compiled the test results into a bar chart. The highest charging power is 17.43W of the iQOO 12 Pro. The charging power of other phones remains in the ranges of 10W, 15W, and 28W. It has no compatibility issues and can provide fast charging for most phones.
Control by App
Search the EHOM's app in the app store and connect the power station via Bluetooth. Then, you can control the power station through the application.
The upper part of the main page of the application shows the remaining battery capacity. Below are the outputs of each port and their switch sliders.
After entering the settings, you can make advanced settings such as charging power and standby time. It also supports OTA (Over-the-Air Technology).
Real-World Usage
Its two European standard AC outlets both support an output power of 600W. The AC outlet can easily supply power to high-power electrical appliances such as electric kettles, frying pans, etc.
It features SpurFlux technology. It can drive high-power electrical appliances with a rated power of up to 1600W. When the rated power of the electrical appliances is greater than its rated power, it can automatically reduce the output voltage to reduce the load to prevent it from being overloaded.
The display shows the output power is 797W at this time.
It is also equipped with a car port that supports a maximum output of 126W, which can power devices such as a car refrigerator.
The display shows that the output power is 50W at this time, which meets the power requirements.
It has a wireless charging panel, a car port, two DC5521 ports, two independent USB-A ports, two independent USB-C ports, and two European AC outlets. It can connect up to 10 devices at the same time for power supply. So we connected a coffee machine, an electric frying pan, a car refrigerator, and many more devices during testing.
At this time, all six devices can run normally. And the display shows the output power is 615W. The bottom of the display also shows the working status of the ports. In addition, it also has the EPS function. When it is connected to the power grid with a power cord while powering the device, the bypass mode will be triggered and the power grid will directly power the appliance. When the power grid fails, it can switch to power supply mode within 15ms.
Noise Test
It supports the QuiteQuiet technology. The noise when working is lower than the similar products. The fan speed can be adjusted according to the load to control the noise.
Measured at a distance of 1 meter at 50% load, the noise is 32dB. When fully loaded and measured at a distance of 1 meter, the noise is 38dB. The fan speed at 50% load is significantly lower than that at full load.
When working at full load, that is, the output power is 600W, and the noise meter shows a noise of 50.8dB at a distance of about 0.25 meters. Its noise control performance is excellent.
Charging Test
Input Ways
In addition to multiple output ways, it can also support multiple input ways.
First, it can be charged by the wall outlet. Using the included high-power power cord, the maximum input power can reach about 600W. It can be charged to 80% in 40 minutes and fully charged in about 78 minutes.
It also can be charged by the car charger. When the input is 12V 8A, the power is about 75W.
Still charging through the car charger, when the input is 24V 8A, the power is about 162W.
It can support an input power of up to 160W by solar panel.
It supports the NitroGo fast-charging technology. We charge it with the original high-power power cord and record the data with the PA300 power meter.
We plot the data into a curve to see how fast it can be charged. It can be charged to 50% in 29 mins, 80% in 46 mins, and 100% in 1 hour and 20 mins. The charging speed is the same as what it claims.
Discharging Test
Let it continue to output at 550W until the power is exhausted, and record the data. The test results are as follows.
It can be seen that when the power bank continues to output for 23 mins, the remaining power is 50%. After 37 mins of output, the remaining power is 20%. And the remaining power is exhausted at 46 mins.
It uses ColdFusion technology to ensure temperature control. This allows the product to be charged immediately after being fully discharged without overheating.
After the power is exhausted, immediately use the original high-power power cord to charge it. At this time, the input power is 469W.
The EHOM EP600 Portable Power Station adopts a CAE-optimized one-piece flame-retardant shell. It has a built-in LFP battery with a capacity of 512Wh. It has a rated output power of 600W. It is measured that in SpurFlux mode, it can drive high-power appliances such as electric kettles with a rated power of about 1600W. It can meet the electricity needs of charging, refrigeration, boiling water, etc. during outdoor camping. The TrueSight anti-glare display can show the remaining power, input and output power, working status of the ports, and available time. And you can control it by the APP. After entering the settings, you can make advanced settings such as charging power and standby time. It also supports OTA (Over-the-Air Technology).
It has a wireless charging panel, a car port, two DC5521 ports, two independent USB-A ports, two independent USB-C ports, and two European AC outlets. The USB-C port supports a charging power of up to 100W, which can meet the fast charging needs of phones, game consoles, tablets, and laptops. It can connect up to 10 devices at the same time for power supply, meeting various power needs.
It supports multiple input ways that can be charged by mains electricity, solar energy, car chargers, and other input ways. It supports a maximum input of 600W and can be fully charged in 1.3 hours. When outdoors, you can choose to charge it with a solar panel, with a maximum power of 160W. You can also charge it with your car charger. Its multiple charging ways can cope with different scenarios. It is equipped with ColdFusion technology, and its unique design allows cooling air to quickly take away heat to avoid overheating. It also adjusts the fan speed based on the load. It can also be charged immediately after fully released, which reduces the restless waiting. After testing, its noise control performance is excellent. It also has the EPS function, and the switching time is ≤15ms.
Overall, the EHOM EP600 Portable Power Station has a tough and exquisite appearance, giving people a sense of power and reliability. The weight is only about 8kg. While reducing weight, it also supports multiple input and output methods, making it suitable for outdoor camping or energy storage at home. It supports IPX3 protection and supports drops from a height of 1.2 meters, making it suitable for outdoor environments. It has also passed UN38.3, CE, Rohs, Reach, and other certifications. In addition, the storage box at the bottom of the power station is also a rare design among similar products. It can store AC and DC charging cables, or place some tools or medicines to deal with emergencies.
1. Review of EHOM EP1650 Portable Power Station
2. Up to 3000W Output | Review of VTOMAN FlashSpeed 1500 Power Station
3. Review of Jackery Explorer 2000 Plus LiFePO4 Portable Power Station
600W EHOM
ChargerLAB at Computex 2024 (Dr. Lisa Su & More)
Review of The Boring Lamp 3-in-1 Smart Lamp
March 16, 2026
Review of AOHi Starship 40000mAh 140W Power Bank
June 3, 2025
Realme 10000mAh 18W PD Fast Charge Power Bank (RMA137) Review
September 27, 2019
March 19, 2026
