Home › Reviews › Power Banks & Stations › Review of EHOM EP1650 Portable Power Station
ChargerLAB this time got a portable power station from EHOM, which can charge nine devices at the same time. The battery capacity is 1024Wh. It can support an output power of up to 1650W. It also features SpurFlux technology to protect it from overload. Next, we will do some tests to see how it performs.
Review of EHOM EP1650 Portable Power Station-Chargerlab
The box of the EHOM EP1650 Portable Power Station is gray and white. The logo of EHOM is printed on the top of the front. And there are several selling points printed on the bottom.
Its info about ports is printed on this side. It is equipped with three AC outlets, two USB-C ports, three USB-A ports, and a car port. The USB-C can output up to 20V 5A, and the total output power of two USB-C ports is 200W. The USB-A can output up to 12V 1.5A, and the total output power of three USB-A ports is 54W. The car port can support an input of 12V 8A 96W.
The box contains the power station, an AC power cord, a car charger, and some documents.
It has a matte one-piece shell that supports drops from a height of 1 meter. The front of it is equipped with an LCD, a car port, five USB ports, three European AC outlets, a light, and a power button.
The LCD can display the remaining power, input and output power, and available time.
It is equipped with high-speed cooling fans on both sides. Paired with ventilation, it can protect safety and extend the lifespan.
There is a hidden cover on the back. There are also some specs info pasted here.
Model is EP1650-3. The battery capacity is 1024Wh. The AC input can support 220~240V 50Hz 10A 1200W. The DC input can support 11~55V 400W. The AC output can support 230V 50Hz 7.2A 1650W. The battery type is LFP.
There are two hidden handles on both sides of the top, which are ergonomically designed.
There are rubber pads at the four corners of the bottom to prevent sliding.
The length of it is about 33 cm (12.99 inches).
The width is about 26 cm (10.24 inches).
The height is about 27 cm (10.63 inches).
And the weight is about 13.7 kg (30.2 pounds).
In addition to the main power button, it has two independent power buttons for the AC and DC output. It is equipped with two USB-C ports and three USB-A ports. Each USB-C port can support an output of 100W, and each USB-A port can support an output of 18W.
The car port has a rubber dust plug for protection. It can support an output of up to 12V 8A 96W, meeting the needs of most car electrical appliances.
There are three European AC outlets. The outlet can support up to 230V 1650W.
There is an AC input socket, an overload protector, and a DC input socket inside the hidden cover. The AC socket has three prongs. The power station can support AC input of 220~240V 50Hz.
Protocol Test
We tested the protocols supported by the USB-A and USB-C ports.
The ChargerLAB POWER-Z KM003C shows the USB-C port can support FCP, SCP, AFC, QC3.0, QC5, SFCP, PD3.0, PPS, DCP, and Apple 2.4A charging protocols.
And it has five fixed PDOs of 5V3A, 9V3A, 12V3A, 15V3A, and 20V5A, and a set of PPS, which is 3.3-21V3A.
The ChargerLAB POWER-Z KM003C shows the USB-A port can supply SCP, AFC, QC3.0, VOOC, MTK, DCP, and Apple 2.4A charging protocols.
Next, let's see the charging compatibility of the USB-C.
Use any USB-C port to charge the Meizu 21, ChargerLAB POWER-Z KM003C shows the power is about 17.87V 2.99A 53.37W. The PPS protocol is triggered.
From this chart, it can be seen that the voltage of most phones can reach about 9V, and most game consoles and tablets can reach about 15V. Some phones that support the PPS protocol can reach a voltage of about 18V. All laptops tested can reach about 20V.
We have compiled the test results into a bar chart. The highest charging power is 92.08W of the 16-inch MacBook Pro M1 Max. The power of the Meizu 21 and the nubia Z30 Pro is 53.37W and 51.33W, respectively. The charging power of other devices remains in the ranges of 15W, 18W, and 27W. It has no compatibility issues and can provide fast charging for most devices.
Control by App
Search the EHOM's app in the app store and connect the power station via Bluetooth. Then, you can control the power station through the application.
The upper part of the main page of the application shows the remaining battery capacity. Below are the outputs of each port and their switch sliders.
After entering the settings, you can make advanced settings such as charging power and standby time. It also supports OTA (Over-the-Air Technology).
SpurFlux Technology
It features SpurFlux technology. When the rated power of the electrical appliances is greater than its rated power, it can automatically reduce the output voltage to reduce the load to prevent it from being overloaded.
We used an induction cooker with a rated power of 2400W during the test. Due to SpurFlux technology, the output power was 1710W.
Real-World Usage
AC outlet output
The AC outlet can support a power of up to 1650W. It can meet the power needs of high-power appliances such as kettles, electric frying pans, and induction cookers.
It also has the trickle output mode which can power CPAP machines.
Car Port Output
Its car port can support an output of up to 96W that can power the car refrigerator.
It can be seen that the power at this time is about 51W, which can meet the power supply needs.
USB Output
The power station is equipped with two USB-C and three USB-A ports. The USB-C and USB-A ports have independent power supply designs. When powering five devices at the same time, the output power will not be affected by other ports.
It can be seen that the power at this time is about 185W.
Total Output
It has a car port, five USB ports, and three European AC outlets. It can connect up to 9 devices at the same time for power supply. So we connected a coffee machine, an electric frying pan, a CPAP machine, a car refrigerator, and five other devices to the power station during testing.
It can be seen that the power at this time is about 1792W. The three icons in the lower left corner correspond to USB-C, USB-A, and the car port.
Noise Test
It supports the QuiteQuiet technology. The noise when working is lower than the similar products.
When the output power is about 825W, that is, 50% load, the noise meter shows a noise of 36.5dB at a distance of about 1 meter.
When working at full load, that is, the output power is 1650W, and the noise meter shows a noise of 40.3dB at a distance of about 1 meter. Its noise control performance is excellent.
Charging Test
Input Ways
In addition to multiple output ways, it can also support multiple input ways.
First, it can be charged by the wall outlet. Using the included high-power power cord, the maximum input power can reach about 1159W.
It also can be charged by the car charger. When the input is 24V 4A, the power is about 105W. When the current increases to 8A, the power is about 192W.
Still charging through the car charger, when the input is 12V 4A, the power is about 49W. When the current increases to 8A, the power is about 96W.
It can support an input power of up to 400W by solar panel. It can be fully charged in 3.3 hours at the fastest.
It supports the NitroGo fast-charging technology that can be charged under 220V AC, and the power can be up to 1200W. We charge it with the original high-power power cord and record the data with the PA300 power meter.
We plot the data into a curve to see how fast it can be charged. It can be charged to 50% in 28 mins, 80% in 45 mins, and 100% in 1 hour and 13 mins.
Discharging Test
Let it continue to output at 1600W until the power is exhausted, and record the data. The test results are as follows.
It can be seen that when the power bank continues to output for 14 mins, the remaining power is 50%. After 20 mins of output, the remaining power is 30%. And the remaining power is exhausted at 28 mins.
After the power is exhausted, immediately use the original high-power power cord to charge it. The test results are as follows.
At this time, the input power is displayed as 307W.
The EHOM EP1650 Portable Power Station adopts a matte one-piece shell. The battery capacity is 1024Wh. And it can support an output power of up to 1650W. When camping or traveling, it can meet the electricity needs of charging, cooking, etc. The LCD can display the remaining power, input and output power, and available time.
It is equipped with two USB-C and three USB-A ports. Each port can be output independently and does not affect each other. The USB-C port supports an output power of up to 100W that can fast charge phones, game consoles, tablets, laptops, and other devices. The European AC outlet can provide a power of 1650W. Under the SpurFlux mode, it can drive high-power appliances that are above the rated power. It supports up to 400W solar input.
In addition to being suitable for outdoor camping, it can also be used at home to deal with emergencies. The power under SpurFlux technology can meet the needs of most devices. The noise during charging and load will not disturb you. It can also be charged immediately after fully released, which reduces the restless waiting. What's more, it can be controlled by the independent APP.
1. Up to 3000W Output | Review of VTOMAN FlashSpeed 1500 Power Station
2. Review of Jackery Explorer 2000 Plus LiFePO4 Portable Power Station
3. Anker 757 1500W Portable Power Station (PowerHouse 1229Wh)
1650W EHOM
Powerful Performance | Review of EHOM EP1650 Portable Power Station
Charging Compatibility Test of iQOO Z9 Turbo
OPPO SuperVOOC 50W Power Bank Teardown Review: Pikachu Power!
June 24, 2019
Review of Soodatek 20W Magnetic Wireless Power Bank
May 16, 2023
Review of Baseus 140W PD3.1 Power Bank (2C1A)
October 26, 2023
10
August 23, 2023
