Home › News › What's New › Phenomenal Device | BLUETTI New Power Station Reached Ten Million Dollars on Indiegogo
Phenomenal Device | BLUETTI New Power Station Reached Ten Million Dollars on Indiegogo-Chargerlab
Recently, indiegogo — a well-known crowdfunding website, shows that BLUETTI AC500 & B300S - home backup power station crowdfunding project was officially launched on September 2, with a set target amount of 10,000 US dollars. Until the end of the project on October 29, the total amount reached $11.7 million US dollars, and the number of people participating in the project was 4,632, which is a thousand times the target amount.
This is the third crowdfunding initiated by BLUETTI. In August 2020, the AC200 - most versatile solar power station raised $6.73 million US dollars, with more than 7,000 participants; in May 2021, EP500 & EP500Pro - the new era of Home backup power raised $4.3 million US dollars, with more than 1,000 people participating in the project. And this time, it was a million-dollar achievement.
In addition, according to our statistics on the Amazon US portable power stations best sales list, the BLUETTI Portable Power Station EB3A entered the top three, and it is also the most powerful among them, which shows that BLUETTI is very popular in the market.
AC500 is equipped with 16 outputs for almost 99% of devices. Now, you can get rid of the messy adapters. In terms of AC, in addition to three 120V/20A regular AC ports, 120V/30A L14-30 and 120V/30A TT-30, the 120V/50A NEMA 14-50R, with 5000W power, is specially designed for campers, DIYers, RV travelers, etc.
On the DC side, it is equipped with four USB-A and two USB-C ports, which supports 100W USB-C PD fast charging; there are also 24V10A car outlet and 12V30A RV port. Two wireless charging modules are on the top, each supporting 15W; on the far right are the input and battery connection ports.
Compared to all-in-one units, the modular design significantly shrinks the overall size and weight without losing flexibility. AC500 is 100% modular and can accept up to 6×B300S (3,072Wh each) expansion battery packs, which are made of lithium iron phosphate batteries, adding up to an overall capacity of 18,432Wh – Power your whole family's basic needs for DAYS either in daily use or power outages!
The “Split Phase Bonding Function” lets you combine two AC500 units (with at least 2*B300S or B300) for a massive 10KW output power if integrated into your home grid.
And if you get twelve B300S battery packs, the overall capacity after expansion is 36864Wh!
Waiting for recharging is never a pleasure. With the wall outlet and solar panels plugged in, the AC500 system supports up to 8,000W impressive input rate (5,000W AC charging + 3,000W solar charging), and it can be charged to 80% in 50 minutes. Get the system recharged before you pack up for the camping, and your power will be ready when you are.
Waking up a power station in icy cold winters may be time-consuming. Yet the intelligent Temperature Adaptive Function enables B300S to better heat up the battery and ensure it can work as usual.
Whether you want to control the AC500 system at close range or from a distance, we got you covered. Monitor and control your power usage from anywhere with the BLUETTI app for features like checking input/output specs, customizing power consumption, firmware upgrade, or managing the most-used tasks directly from the touchscreen, keeping everything under control.
The BLUETTI AC500 & B300S - home backup power station features high capacity and high performance compared to standard outdoor power supplies. It is aimed at professional users and directly against the Tesla powerwall. According to the needs of each individual user, the modular design can be composed of different power and capacity specifications, which are very flexible.
Judging from the results of ten million dollars in this crowdfunding project, European and American users still have high purchasing power for high-end off-grid power stations, and BLUETTI's reputation among consumers continues to rise.
Check out www.bluettipower.eu for more information about BLUETTI.
1. Teardown of Yoobao 300W 72000mAh Portable Power Station (EN300WLPD)
2. Up to 2400W丨 Baseus Launched 600W Portable Power Station with Digital Display (Parallel Operation)
3. EcoFlow Launched 1800W DELTA 2 Portable Power Station
BLUETTI Power Station
Teardown of Apple Watch Ultra Woven Charging Cable
Charging Compatibility Test of Xiaomi 210W GaN Charger (For Redmi Note 12 Discovery Edition)
Anker Announces New Lineup of Products and Firmware Upgradability for Chargers at OnBoard 2019
October 24, 2019
IKEA Launches VARMFRONT Power Bank for Portable Charging Needs
October 31, 2024
Charge On the Go: IKEA Launches Compact SJÖSS 45W USB-C AC Adapter with Dual Device Fast Charging
November 9, 2024
Goal Zero Releases Lightweight Power Station Yeti 200X with AC Outlet and USB-C PD
October 22, 2019
