Not every power bank can boast the hardcore performance of PD 3.1 140W bidirectional fast charging and dual-port blind insertion. AOHi, as one of the world’s leading innovative tech brands, has previously launched several power banks and chargers that support PD 3.1 fast charging. Now, it introduces the all-new 240W Future Starship Power Bank, featuring both cutting-edge design and top-tier charging capabilities.
AOHI The Future Starship 240W 27,600mAh LED Display Power Bank Now Available
This time, the AOHi 240W Future Starship Power Bank continues the signature futuristic design of the Starship series, with a striking black and yellow color contrast that enhances its high-tech look.
The power bank features a semi-transparent black casing and a built-in minimalist LED smart display, reminiscent of a Swiss timepiece. It clearly and accurately shows key charging metrics such as current, voltage, and power.
Additionally, the top panel of the device houses three USB ports: 2 USB-C and 1 USB-A. Both USB-C ports support PD 3.1 140W, with simultaneous charging and discharging functionality, making it an excellent option for desktop use as well.
In terms of charging performance, both USB-C1 and USB-C2 support PD 3.1 140W fast charging. When connected with a MagSafe 3 cable or other PD 3.1-compatible cables, the power bank can deliver a 140W fast charge to devices (with PD 3.1 support), ensuring strong and sustained performance.
Not only does the AOHi 240W Starship Power Bank provide peak charging capabilities, but it also houses a 27,600mAh high-density automotive-grade battery cell. This allows for around 1,000 full charge cycles. The compact battery design also contributes to its small, travel-friendly form factor, making it compliant with most airline regulations. It excels in capacity, safety, and portability.
According to official specifications, the AOHi 240W Future Starship Power Bank supports up to PD 3.1 140W bidirectional fast charging via USB-C, while the USB-A port supports up to 22.5W output. Combined, the three ports can deliver a maximum total output of 240W, enough to charge most high-power smartphones, tablets, and laptops on the market.
When it comes to high-end PD output, the AOHi 240W power bank is also compatible with PPS 100W fast charging and UFCS 63W universal fast charging protocols. It supports major brands like Huawei, Xiaomi, OPPO, Vivo, and Samsung, enabling faster and more efficient charging that rivals original chargers and power banks.
Despite its large capacity and high-power features, the AOHi 240W Starship Power Bank remains compact and easy to carry. It can be effortlessly stored, held in one hand, and is ideal for long-distance air travel.
In conclusion, the AOHi 240W Future Starship Power Bank stays true to the design ethos of the Starship series, featuring a futuristic tech aesthetic, PD 3.1 140W bidirectional fast charging, and an ultra-compact form factor. With a sustained 140W output, it continues to push the boundaries of innovation and delivers a surprisingly advanced tech experience to users.
1. AOHi Starship Pro: The World’s Most Powerful 10,000mAh Power Bank with 210W Output and 140W Fast Charging
2. AOHI Launches Compact 100W GaN+ AC Adapter with Multi-Device Fast Charging Capability
3. Hidden Magnetic Plug | Review of AOHi 65W Ultra-thin GaN+ Charger
