Home › News › What's New › New MOMAX 100W 6-Port Wireless Desktop GaN Charger Supports Simultaneous Charging of 7 Devices
  • 3
Jeffrey
August 4, 2022
Although multi-port chargers are more and more popular these days, they still can't meet the needs of some heavy users. Recently, MOMAX released the Q.PLUG BOX 100W 6-Port desktop GaN charger with Wireless Charging, supporting simultaneous charging of seven devices.
New MOMAX 100W 6-Port Wireless Desktop GaN Charger Supports Simultaneous Charging of 7 Devices-Chargerlab
The white MOMAX Q.PLUG BOX desktop GaN charger, printed with the words GaN and 100W, is equipped with four USB-C and two USB-A ports, supporting up to 100W fast charging output and up to 15W wireless charging. It can charge up to seven devices simultaneously.
Either USB-C1/C2 can support up to 100W PD output separately. USB-C3/A1 share one output, both can get 30W fast charging output when used alone, and USB-C4/A2 share the other output and can also get 30W fast charging output when used alone.
This desktop GaN charger adopts the GaN technology to improve the conversion efficiency with a smaller size. Its size is about 120 * 85 * 28 mm (4.72 X 3.34 X 1.1 inches). As a multi-port charger, it is equivalent to seven single-port chargers, charging up to seven devices simultaneously, making your desktop neater.
The desktop GaN charger can be easily extended to the desktop to provide a more intuitive and convenient way for users to plug, unplug and place devices.
It has a wireless charging panel at the top, supporting Qi wireless charging with a maximum output power of 15W. Just place your QI-enabled devices on the panel and charge instantly.
The charger is made of fire-retardant material and has built-in load, short-circuit, overvoltage, over-current, over-temperature and other protections, with the 3C, FCC and other certifications.
The MOMAX Q.PLUG BOX 100W 6-Port desktop GaN charger with Wireless Charging has four USB-C ports, two USB-A ports and a wireless charging panel, supporting up to 100W fast charging output and up to 15W wireless charging. It can charge up to seven devices simultaneously.
Here comes its detailed specification.
Input: 100-240V ~50/60Hz (2.5A Max)
Total output: 100W
USB-C1/C2 output: 5V/9V/12V/15V=3A, 20V=5A (100W max.)
USB-C3/C4 output: 5V/9V=3A, 12V=2.5A, 15V=2A, 20V=1.5A (30W max.)
USB-A1/A2 output: 4.5V=5A, 5V=4.5A, 9V=3A, 12V=2.5A, 20V=1.5A (30W max.)
Wireless output: 5W/7.5W/10W/15W
USB-C1+USBC2/C3/C4/A1/A2 output: PD65W+30W
USB-C1+wireless output: PD65+15W
USB-C1+USB-C2+USBC3/C4/A1/A2: PD30+PD30+30W
USB-C2+USBC3/C4/A1/A2+wireless output: PD30W+30W+15W
USB-C1+USB-C2+USB-C3+USB-C4/A1/A2 output: PD20W+PD20W+PD20W+20W
USB-C1+USB-C2+USB-C3&C4+USB-A1&A2+ wireless output: PD20W+PD20W+20W+20W+15W (95W max.)
1. MOMAX Launches New 3-in-1 Wireless Desktop Charger Stand
2. Review of MOMAX Airbox Charging Station(A Foldable Power Bank)
3. UGREEN Launches The New Nexode 200W GaN Desktop Charger (4C2A)
100W Fast charging GaN MOMAX USB-C Wireless Charger
Teardown of Anker 120W GaN Charger (GaNPrime 737)
How to use the ChargerLAB POWER-Z KM002C PD3.1 tester to test the C2C cable?
20W Wired Fast Charging | Baseus Launched 10000mAh Magnetic Power Bank
January 18, 2023
HP Unveils New 96W USB-C Charger with Foldable Prongs for Enhanced Portability
October 23, 2024
PD3.1 Support | Lenovo Launched Legion C140 GaN Adapter
April 2, 2023
9
Google Requires New Android Devices with USB-C to be Fully Compatible with USB-PD
October 8, 2019
Jeffrey
