Belkin, a leader in innovative charging solutions, has unveiled its latest Magnetic Power Bank, designed to provide up to 15W fast charging for Qi2-enabled devices, including iPhones and other compatible products. The power bank, with a 10,000mAh capacity, is packed with features to enhance user convenience and efficiency.
One of the highlights is the Qi2 wireless charging technology, which features built-in magnets for perfect alignment with MagSafe-compatible devices. This ensures a stable and efficient charging experience every time. The device offers an additional 35 hours of battery life, making it an ideal companion for users on the go.
The compact and portable design ensures that the power bank doesn’t block the camera when attached to a device. It also includes an integrated kickstand that keeps the phone upright, allowing for hands-free use during charging. Another standout feature is pass-through power, enabling the power bank to double as a standard wall charger while simultaneously powering your devices.
In addition to wireless charging, the power bank supports multiple devices with its USB-C port, and it comes with a USB-C to USB-C cable to get users started right out of the box. For iPhone users, the power bank supports StandBy mode, letting you customize your iPhone’s display when docked.
Further enhancing its appeal, this power bank is compatible with MagSafe and other cases up to 3mm thick. Built with overcharge protection, it ensures a safe charging experience. It’s also crafted from post-consumer recycled plastic (excluding the cable) and comes in 100% plastic-free packaging, reflecting Belkin’s commitment to sustainability.
Belkin’s new power bank is more than just a charging accessory – it's a cutting-edge, eco-friendly solution designed for the modern user.
Specifications:
- Wireless charging output: Up to 15W fast charging with Qi2 for compatible iPhones and other Qi2-enabled devices
- Qi2 technology: Magnets for perfect alignment
- Battery capacity: 10,000mAh, providing 35 hours of additional battery life
- Design: Compact and portable, doesn’t block camera view
- Kickstand: Integrated for keeping devices upright while in use
- Pass-through power: Can be used as a standard wall charger
- Ports: USB-C; includes USB-C to USB-C cable
- StandBy mode support: For customizing iPhone display while charging
- Case compatibility: Works with MagSafe and other cases up to 3mm thick
- Safety features: Overcharge protection
