MIX-DESIGN Semiconductor has introduced the SimpleTOP MSG6800-07 Series, a cutting-edge single-chip solution for AC-DC fast charging systems. With its highly integrated digital intelligent architecture, the MSG6800-07 platform supports fast charging protocols such as PD3.1, UFCS, QC2.0/3.0, MTK-PE+, SCP, FCP, and more.
This new platform leverages SimpleGaN® technology, embedding a 700V GaN device, a 12-bit ADC and DAC, and enhanced primary-secondary isolation. The design enables multi-level accurate voltage and current control, optimized EMI reduction, and a streamlined component count for easy integration.
Targeting PD and Quick Charge applications like smartphone adapters, the MSG6800-07 offers output power ranging from 22W to 66W across different models, providing flexible power solutions with high efficiency and thermal performance.
Key Specifications of SimpleTOP MSG6800-07 Series:
- Integration: High-performance 700V GaN device, 12-bit ADC & DAC.
- Primary-Secondary Isolation:>5000VAC insulation strength.
- Built-in DSP Core: Optimizes fast charging protocols.
- Power Output Range:
- MSG6800: 22W (Adapter), 25W (Open Frame)
- MSG6801: 30W (Adapter), 35W (Open Frame)
- MSG6803: 36W (Adapter), 40W (Open Frame)
- MSG6805: 50W (Adapter), 55W (Open Frame)
- MSG6807: 66W Max (Open Frame)
- Protocol Support: PD3.0/PPS, UFCS, QC2.0/3.0/3.0+, SCP, FCP, MTK-PE+, AFC, APLEE2.4A, etc.
- Applications: PD and Quick Charge AC/DC adapters for smartphones, tablets, and other portable devices.
Stay tuned for more developments on this innovative platform!
