Have you noticed that the cable that comes with your power bank is usually a few inches long, but your phone's cable is about 3 feet long? That's because the power bank is basically unusable during the charging process, and the short cable makes a lot more sense. However, the charger that comes with the Apple Watch, similar to the power bank, has a very long cable, making it a bad choice when carrying around.
MOMAX has developed the GOLINK Apple Watch magnetic wireless charger to solve this problem. It's small and easy to carry, thanks to the cordless design. It adopts the original Apple certification module, which can deliver good security and compatibility.
It adopts a compact, portable design made from a white PC shell and a white silicone strap. The entire charger is only the size of a keychain, which can be easily put into your pocket or backpack.
It is made of Apple's original magnetic wireless charging module and has passed the Apple "Made For Apple Watch" certification. It has a strong attraction, high compatibility with watchOS, consistent with the original quality, and is guaranteed to charge safely.
Based on the universality of the USB-C port, in addition to using standard PD chargers and PD power banks for power supply, it can also obtain power through the OTG function on notebooks, tablets, and even mobile phones.
The charger supports all Apple Watch series, including the newly released Apple Watch Series 8, Apple Watch Ultra, and Apple Watch SE. It also supports wireless charging for AirPods Pro 2.
It is mainly made of PC material for enhanced protection and has a silicone strap at the bottom worked as a dust cover.
The MOMAX GOLINK Apple Watch magnetic wireless charger adopts a compact and portable design concept, and the USB-C port design can draw power from PD chargers and mainstream digital products with USB-C ports. The original Apple certification module is compatible with all Apple Watch series and AirPods Pro2.
Check out www.momax.net for more information about MOMAX.
1. 10000mAh Power Bank丨 MOMAX Released Upgraded Magnetic Wireless Battery Pack with Stand
2. Transparent | MOMAX Launched Dual Magnetic Wireless Charging Stand
3. Review of MOMAX Airbox Charging Station(A Foldable Power Bank)
