Home › Guides › How to Buy › iPhone 15-Ready: Choosing the Perfect MagSafe Power Bank
  • 3
Since the introduction of the new generation MagSafe wireless charging system with the iPhone 12 series, there has been a steady stream of magnetic-related accessories such as magnetic chargers, magnetic power banks, magnetic protective cases, magnetic cardholders, and more. Among them, the magnetic power bank is a boon for heavy smartphone users who often forget to charge or carry charging cables. It eliminates the need for cables, providing direct magnetic charging for iPhone 12-15 series. Currently, magnetic power banks on the market differ significantly in terms of appearance, battery capacity, expandability, and practicality, offering users more choices.
Below, we introduce several third-party MagSafe-compatible power banks available for the iPhone 15 series. The ranking is not in any particular order and is sorted alphabetically.
Product Introduction
Anker
Anker 622 Magnetic Battery (MagGo)
The new MagGo power bank from Anker retains its classic style, with a redesigned layout for the USB-C port and indicator lights. It features a "notch" design on the edges for easy opening, making it convenient for users to open the stand for use. It comes in three colors: Interstellar Gray, Marble White, and Morning Mist Blue.
iPhone 15-Ready: Choosing the Perfect MagSafe Power Bank-Chargerlab
With a built-in 5000mAh battery and a single USB-C port, it supports charging the power bank itself and can also provide output through a cable for charging your phone. The power bank has a built-in magnetic wireless charging feature, allowing it to attach to the back of an iPhone for wireless charging. It features a patented stand design that can be opened to serve as a phone stand, supporting both vertical and horizontal orientations.
PURCHASE
Baseus
Baseus 20W Magnetic Power Bank 10000mAh
The Baseus 20W Magnetic Power Bank is made with a non-slip silicone material on the surface to provide a comfortable grip without scratching the phone. It offers four color options. It includes magnetic components that automatically align and securely attach to the back of an iPhone, activating wireless charging without the need to wake the power bank.
In terms of battery life, it features a 10000mAh battery, alleviating battery anxiety. It also integrates a USB-C bidirectional fast charging port on the side, providing up to 20W PD fast charging when there's a need for rapid replenishment.
PURCHASE
Benks
Benks MagClap On-Go Power Bank 10000mAh
The Benks MagClap On-Go Power Bank 10000mAh features a sleek white exterior with a matte finish and fingerprint resistance. The back is made of silicone material, providing a good grip and preventing the phone from slipping.
With a built-in 10000mAh battery, it supports magnetic wireless charging and can attach to the back of an iPhone for convenient wireless charging. The power bank has both USB-C and USB-A ports, supporting 20W wired output and 15W wireless charging, with good fast charging compatibility. It also has a side-mounted battery indicator for easy monitoring of the battery level.
PURCHASE
Benks MagClap On-Go Power Bank 5000mAh
Although the name is similar to the previous one, this model differs significantly. It shares the same appearance as the Apple MagSafe power bank but is much lighter, weighing only 122.9g. It comes in three colors: black, white, and blue.
The Apple MagSafe power bank provides 5W of wireless charging power to the iPhone 12-15 series, while this Benks model offers 7.5W of wireless charging and 12W of wired charging. They offer a similar magnetic charging experience, but the Benks model is available at less than a quarter of the Apple one. It only has one USB-C port, so that's something to keep in mind.
PURCHASE
IDMIX
IDMIX Q10 Pro 10000mAh Magnetic Power Bank
The IDMIX Q10 Pro power bank features a sleek and rounded design, with a white PC fireproof material on the front and a matte finish. The sides are made of metal and include a foldable stand, ensuring strength and durability while enhancing the user experience. When the stand is unfolded, it becomes a magnetic wireless charger, supporting both horizontal and vertical phone placement for convenient use while charging.
With a compact 10000mAh battery, a smooth feel, and magnetic attachment for wireless charging on the phone's back, the power bank offers 20W PD fast charging and excellent compatibility with both wired and wireless fast charging for Apple and Android devices. It also displays the battery percentage, providing precise information on the remaining charge.
PURCHASE
JOYROOM
JOYROOM 20W Magnetic Power Bank with Ring Holder 10000mAh
The JOYROOM power bank features a black PC material exterior with rounded corners. Its standout feature is the built-in collapsible ring holder. The wireless charging area has a slight elevation, creating a gap between the phone and the power bank, which helps with heat dissipation. Additionally, the magnetic area has adhesive pads to protect the phone from scratches and increase stability.
JOYROOM's magnetic power bank has a capacity of 10000mAh, combining both endurance and portability. It supports 15W wireless charging and 20W fast wired charging, meeting the needs of modern users. The ring holder can be used to secure the phone while charging and also functions as a stand, turning the power bank into a wireless charging stand for an improved video-watching experience.
PURCHASE
Mcdodo
Mcdodo 5000mAh Stand Magnet Power Bank
The Mcdodo power bank comes in white with a skin-friendly texture, offering a delicate touch. It features the Mcdodo logo on the front and a matte stand in gray, providing an exquisite appearance. There's a round button on the front that, when pressed, illuminates four indicator lights to display the current battery level.
With a built-in 5000mAh capacity battery and a single USB-C port, it supports 20W output and 18W input, with a maximum 15W wireless charging power, making it suitable for fast wireless charging for Android devices as well. The power bank cleverly integrates the stand into the frame, combining elegance and practicality, serving as both a power bank and a phone stand for on-the-go convenience.
PURCHASE
MOMAX
MOMAX Q.Mag Power 9 Magnetic Power Bank
The MOMAX Q.Mag Power 9 Magnetic Power Bank features a PC fireproof material exterior with a matte finish and fingerprint resistance. It includes a foldable leather-like stand on the back with the MOMAX logo. When unfolded, the stand transforms the magnetic power bank into a vertical wireless charger, allowing users to charge their phones while enjoying content or messaging. It comes in gray, purple, and blue.
With a built-in 5000mAh battery, this power bank supports magnetic charging on the back of Apple phones, 15W wireless fast charging, and 20W fast wired charging, making it highly compatible with common smartphones. The addition of a phone stand on the back allows for both horizontal and vertical phone placement, significantly enhancing usability.
PURCHASE
MOMAX Q.Mag Power 11 Magnetic Power Bank
The MOMAX Q.Mag Power 11 Magnetic Power Bank features a transparent punk-style shell design with a skin-like texture leather and a PU stand. The front has a full transparent tempered glass design, making the PCB visible and showcasing a futuristic mechanical technology aesthetic with a metallic magnetic module reflecting alloy luster.
With a 10000mAh battery capacity, it supports 20W PD fast charging through the USB-C port and a maximum of 15W wireless output power, catering to both iOS and Android users' charging needs while maintaining an attractive appearance. The stand is highly functional, allowing for horizontal charging with no screen obstruction. When paired with a MagSafe case, the magnetic force is further enhanced.
PURCHASE
MOMAX Q.Mag X 5000mAh Wireless Battery Pack
The MOMAX Q.Mag X 5000mAh Wireless Battery Pack features a sleek design with a full aluminum alloy body and an embedded glass panel. The metal surface has a matte finish, giving it an exquisite look. The embedded glass panel is designed to be smooth and elegant, enhancing the overall comfort and minimalist aesthetic. Additionally, this power bank boasts an incredibly slim profile at just 8.3mm, making it comparable to the iPhone 15 Pro Max in terms of thickness.
It comes with a built-in 5000mAh battery and supports multiple power outputs through its USB-C port, as well as a maximum wireless output of 15W. Whether you're in the iOS or Android camp, this power bank provides an ideal charging power for outdoor activities. It combines high efficiency, low-temperature fast charging, and excellent charging compatibility, offering users a superior outdoor charging experience.
PURCHASE
MOMAX Q.Mag X 10000mAh Wireless Battery Pack
This is essentially an upgraded version of the previous model, maintaining the full aluminum alloy body and embedded glass panel design that gives it both a premium feel and an elegant appearance. Despite its ultra-slim 13mm profile, it packs a substantial 10000mAh battery, ensuring worry-free power backup for users on the go.
It supports PD 20W wired output and a maximum wireless output of 15W. In compatibility tests, it has demonstrated excellent charging performance with mainstream mobile devices, providing a superior charging experience for users with devices from both phone ecosystems. Its compact design makes it easy to carry during travel and is more than capable of handling the iPhone 15 series with ease.
PURCHASE
MOMAX Q.MAG Minimal 5000mAh Magnetic Battery Pack
The MOMAX Q.MAG Minimal 5000mAh Magnetic Battery Pack features a fire-resistant PC shell with a matte sandblasted surface for a delicate touch. Its compact design makes it suitable for air travel and on-the-go use.
With a built-in 5000mAh battery, it offers multiple power outputs through its USB-C port and a maximum wireless output of 15W. Its overall performance, including physical compatibility and charging compatibility, remains outstanding. It continues MOMAX's pursuit of high-performance power banks, combining high efficiency conversion rates, PD fast charging, and portability to provide users with an excellent outdoor charging experience, even when facing the iPhone 15 series.
PURCHASE
mophie
mophie Snap+ Juice Pack Mini Power Bank
This power bank features mophie's fabric-covered design, offering a comfortable and scratch-resistant experience when held. Its compact and flat design allows it to seamlessly attach to the back of your phone. With a 5000mAh battery capacity, it supports both MagSafe wireless charging and USB-C wired charging, providing 7.5W wireless output and 12W wired output.
It perfectly adapts to the MagSafe wireless charging of iPhone 12-15 series, attaching securely to the back of your phone with a simple touch. Weighing around 136g, it's similar in weight to an iPhone 13 mini and provides ample battery backup for daily commuters. It easily fits in your bag and can serve as a secondary battery for your iPhone.
PURCHASE
mophie Powerstation Wireless Stand with MagSafe
This power bank features a skin-like material for an improved overall feel. It houses a 10000mAh battery and supports 20W dual-way wired charging and wireless charging, perfectly compatible with the MagSafe charging of iPhone 12-15 series. The package also includes magnetic stickers and positioning rulers to allow non-MagSafe phone models to enjoy magnetic wireless charging.
Apart from serving as a MagSafe wireless charger, this product comes with a stand feature, making it convenient for video calls and watching short videos while your phone charges wirelessly on your desk. In addition to MagSafe wireless charging and the stand function, mophie has equipped it with a third feature: a built-in screw hole at the bottom, suitable for attaching to a tripod for recording videos, outdoor live streaming, and other scenarios.
PURCHASE
SUIDDY
SUIDDY 15W Magsafe Power Bank
This power bank is extremely slim and has a metal and plastic construction. The metal shell has a matte edge and corner design with LED indicator lights on the edges, emitting a bright white light. The plastic shell area covered with skin-friendly material corresponds to the internal magnetic layout, making it easy for users to align their devices.
With a capacity of 5000mAh and a thickness of only 9mm, it is exceptionally thin, making it easy to carry and attach to the back of your phone for wireless charging. It features a dual-direction USB-C port, supporting 18W fast charging output, as well as compatibility with QC and other fast charging protocols. The power bank can seamlessly attach to the back of your phone without obstructing the camera, allowing users to charge and take photos simultaneously.
PURCHASE
UGREEN
UGREEN Foldable Kickstand Magnetic Battery | 10000mAh
The UGREEN Foldable Kickstand Magnetic Battery | 10000mAh is a versatile power bank designed for iPhones. It has nine strong magnets forming a magnetic ring, making it compatible with the iPhone MagSafe charging system. It automatically aligns and attaches for charging when placed near the device. With a battery capacity of 10000mAh, it provides an extended battery life.
It offers both magnetic wireless and wired charging options, with a maximum 15W magnetic wireless charging capability, supporting 7.5W for iPhones. On the wired charging front, it provides 1A1C dual fast charging ports, with USB-C supporting 20W PD bi-directional fast charging and USB-A supporting 22.5W multi-protocol fast charging output. Besides charging your phone, it can also be used as a stand. The power bank has a retractable support rod on its body, allowing it to be tilted for more convenient charging while using your device.
PURCHASE
ZMI
ZMI 5000mAh MagSafe Power Bank
The ZMI 5000mAh MagSafe Power Bank features a front panel with a faux leather texture, offering a comfortable grip and a premium feel. Its gray-white branding resembles the MagSafe charging symbol found on official Apple phone cases.
With a built-in 5000mAh battery and a super-slim thickness of 12.3mm, it doesn't require any buttons; it simply attaches to your phone for wireless charging, making it extremely convenient for both use and carrying. The power bank has a single USB-C port, supporting 20W fast charging input. It charges itself quickly and simultaneously charges your phone wirelessly, serving as a wireless charging pad.
PURCHASE
Thanks to Apple's influence, there are many options and brands available for MagSafe power banks, each with its unique style, portability, charging power, and functionality.
In terms of portability, lighter 5000mAh MagSafe power banks are suitable for emergency charging needs. For heavy smartphone users, a 10000mAh power bank may provide a greater sense of security.
Regarding appearance, some MagSafe power banks mimic Apple MagSafe Battery Pack design, while others have their own distinctive features. Of course, the choice here depends on personal preferences.
Regarding charging power, whether you have an iPhone 15 series or an earlier model, MagSafe power banks typically offer wireless charging power ranging from 5W to 7.5W. The main differences between the products mentioned lie in their wired charging capabilities, with options like 12W, 20W, and even support for Huawei's 22.5W SCP fast charging.
Lastly, there are some additional features in the 17 MagSafe power banks mentioned. Besides the magnetic charging function, some come with built-in stands. For example, JOYROOM's magnetic ring design allows the phone to pass through and stay securely in place, while mophie's fast-charging power bank has a threaded hole that supports tripod usage, maximizing functionality.
1. ChargerLAB's Ultimate Cable Selection Guide for Everyone
2. The Era of High-Power Charging | A PD3.1 Cable Buying Guide
3. How to Choose the Right USB-C to USB-C Cable
iPhone 15 MagSafe
Teardown of CUKTECH No.15 150W & 20000mAh Power Bank (PB200P)
Teardown of TEGIC CRYSTAL 35W GaN Charger (crystal 35)
Exploring These Magnetic Phone Coolers for iPhone 15 Series
October 19, 2023
October 17, 2023
Discount Applies | Introducing Corsair 60W PD USB-C Cable
January 11, 2024
Get Ready for Gaming | Introducing Five SD Cards for Your Steam Deck
December 25, 2023
