The power strip has been a must for every family, but also one of all power supply accessories with the slowest update.
This time, the leading power strip brand, Huntkey, launches a power strip with a new one-handed intelligent control plug, making the plug easier to remove, which is ahead of the curve of the industry.
The Huntkey SSH608C power strip with a one-handed intelligent control plug adopts a fire-resistant casing, a safety switch and six outlets.
The 46mm(1.81 inches) widely spaced outlets can support six devices simultaneously, with a maximum of 2500W/10A.
Inside the outlet, there is a copper strip without a welding spot, leading to a better structure and conductivity. The low temperature in high-power use will have a longer life span.
The bottom is equipped with six one-way screws, protecting children from dangers. Besides, there are two keyhole slots to mount to a wall.
The strain relief can prevent the cord from bending.
The cord is made of a 3x1.0mm² thick copper core, which has a better ability for large currents to pass and a lower heat to ensure safety.
Here comes the highlight of the Huntkey SSH608C -- the one-handed intelligent control plug. The appearance of this plug is more complex than the traditional plug.
The surface is printed with the Huntkey's logo, and the middle round area is where the magic happens.
The middle round area can be pressed.
After pressing the middle round area, the "cross" at the bottom of the plug protrudes, allowing easy removal from the outlet.
Unlike the traditional plug, Huntkey only needs you to hold the plug with one hand and press the middle. Then it will unplug automatically.
The Huntkey SSH608C power strip with a one-handed intelligent control plug adopts a fire-resistant casing, a safety switch and six outlets. The 46mm(1.81 inches) widely spaced outlets can support six devices simultaneously, with a maximum of 2500W/10A.
After pressing the middle round area of the plug, the "cross" at the bottom of the plug protrudes, allowing easy removal from the outlet, which avoids the risk of damaging the outlet. For the elderly and the disabled, it helps.
Then, ChargerLAB will test the Huntkey SSH608C with one hand to see how is it.
1. Teardown of Anker UK Power Strip With 18W USB-C
2. Charging without Charger | Teardown of UGREEN DIGINEST Power Strip With Dual 65W USB-C Ports
3. Teardown of ANZONTO 18W Socket Shelf (1A1C)
