As an indispensable part of life, power strips have attracted much attention for their quality and performance. Today, we will introduce to you a Huntkey Charge Station F20 with great features and advantages. Let’s follow the review of ChargeLAB and let’s take a look at how this power strip is different.
Product Unboxing
The appearance of Huntkey Charge Station F20 is designed in the shape of a cat's paw, which is cute and creative. Different from the "brick" sockets on the market, Charge Station F20 looks more simple with gray and white color matching. It is made of high flame-retardant PC material casing and is safer for home use. The surface of the shell is treated with a fine-grained frosting process and feels smooth.
The bottom of the front panel of Huntkey Charge Station F20 is the power switch button, with the Huntkey brand logo printed in the middle. The lightning protection indicator light and power-on indicator light are integrated below the button.
There are 3 USB output ports configured in the left area. USB-C supports PD20W. The USB socket is gold-plated, which makes the current transmission more stable and has a longer service life.
The three AC outlets can be adapted to various plugs, including standard plugs in different countries or regions, such as American, European, British, etc. In addition to the ground wire hole, there is a safety door inside the interface to reduce the risk of electric shock. You don’t have to worry about children accidentally plugging it in, and you can use electricity with confidence.
Huntkey Charge Station F20 also comes with a large velcro to meet the storage needs of users.
The relevant parameter information of the socket is also printed in the middle area of the bottom panel.
Model: SZN307C
Name: Power Strip (referred to as Huntkey Charge Station F20)
Technical parameters: MAX2500W-MAX10A, 100-250V~50/60Hz
Single port output: USB-Output: 5V⎓3A or 9V⎓2.22A or 12V⎓1.67A
USB-A1/A2 output: 5V⎓3A or 9V⎓2A or 12V⎓1.5A
Dual port output: USB-A1 + USB-A2 Output: 5V⎓3A (15W MAX)
USB-A1+USB-C output: 5V⎓1.5A+5V⎓1.5A (15W MAX)
USB-A2+USB-C output: 5V-1.5A+5V⎓1.5A (15W MAX)
Three-port output: USB-A1 + USB-A2 + USB-C output:
A1+A2: 5V=1.5A+C: 5V=1.5A (15W MAX)
Internal Structure
The AC wire core and copper bar inside the Huntkey Charge Station F20 are made of high-quality copper. Using sockets made of high-quality copper materials can improve conductivity, enhance safety, extend service life, reduce power loss, improve performance stability, adapt to different environments, reduce electromagnetic interference, improve aesthetics, support environmental protection, and meet high standards of electrical safety and performance requirements.
Scenes
When using Huntkey Charge Station F20 on the desktop, thanks to the wrap-around jack design and large spacing between the jacks, there is plenty of space between each hole and the plugs are not crowded. Users can better manage cables and plug and unplug. The desktop is more concise and organized. Even if all the jacks are fully plugged in, devices can be easily plugged in and out without interfering with each other.
The new design of Huntkey Charge Station F20 cleverly integrates the cat claw shape design with the surrounding large-spaced jack design, making the plugs no longer crowded. The configuration of the six-in-one multifunctional fast charging socket integrates desktop practicality and aesthetics, perfectly solving the problem of plugging and unplugging at the same time on the desktop, and comes with Velcro to prevent the cables from being messy.
In terms of performance, the USB-C port output supports up to 20W fast charging. In addition to smart devices such as mobile phones, headphones, and watches, it can also provide power to low-power desktop objects such as desk lamps and alarm clocks at the same time.
In terms of safety, it has built-in dual indicator lights, including overvoltage protection, overcurrent protection, overload protection, short circuit protection, undervoltage protection, surge protection, and over-temperature protection. The multiple protections allow users to use it with confidence.
If you need a power strip that is both beautiful and powerful, then this Charge Station F20 is undoubtedly one of your choices.
1. Huntkey Appeared at the Hong Kong Electronics Fair to Show Charging Solutions
2. UFCS Supported | Huntkey Launched 45W Dual Port GaN Charger
3. Huntkey Launches New SSH608C Power Strip with A One-handed Intelligent Control Plug
