Purchase Link: https://amzn.to/3W20Ygj
Originating from the Marvel X-Men franchise, the adamantium is the hardest metal on the planet, and it's known worldwide for Wolverine's iconic steel skeleton design. Inspired by this, Baseus designed the adaman2 power bank, which was recently launched on Amazon US. It follows the same high-quality design just like the adamantium and has improved performance specifications.
The Baseus adaman2 30W power bank adopts a multi-layer color plating process to create a unique metallic luster. The all-black body shows a tough texture. The lower left corner of the shell is marked with the word "30W" in glossy material, which means that it supports 30W fast charging output.
10000 mAh capacity provides:
● 1.8 iPhone 13 charges.
● 1.3 HUAWEI P50 charges.
● 1 iPad mini 6 charge.
● 0.8 MacBook Air charges.
On the upper right corner is a black transparent window with a teardrop-shaped appearance, with a hidden battery percentage display inside.
In terms of performance specifications, it is equipped with two USB-A and one USB-C port. USB-C supports 30W fast charge output and 18W fast charge input; USB-A1/A2 supports 22.5W fast charge output. It can charge up to three devices simultaneously (5V3A), while PD3.0, QC3.0, and other fast charging protocols are available.
The USB-C port can provide up to 30W PD fast charging output, which can meet the needs of any iPhone. It can charge the iPhone 13 Pro Max by 60% in 30 minutes. In addition to the commonly used 5V3A / 9V3A / 12V2.5A PDO, it also supports the 15V2A PDO, which is suitable for iPad, MacBook and other devices.
The size is 11.2 x 5.4 x 2.65cm (4.41 x 2.13 x 1.04 inches), weight at 206g (0.45 lb).
The Baseus adaman2 30W power bank has a capacity of 10000mAh, which is very light, it comes with one USB-C and two USB-C ports, supports 30W fast charge output, and has a battery percentage display. The new one is smaller and has higher output power than the previous generation. It is currently available on Amazon US.
1. Teardown of Baseus 100W Slim Laptop Power Bank (Blade Series)
2. Video | Review of Baseus 30W Dual-port Charger With Promo Code
3. Teardown of Baseus 160W Multi-port Car Charger (QC 5.0)
