Home › News › HDMI Port | Baseus launched 67W GaN5 Desktop Charger
$54.99 on Amazon US
With the advancement of technology, notebooks, especially business notebooks, have become smaller and smaller, and they are equipped with as few connectors as possible, sometimes only USB-C ports. Therefore, high-power chargers and docking stations become essential when traveling for business, and it is very messy.
Recently, Baseus launched the 67W GaN5 Desktop Charger with HDMI port on Amazon US, which combines a high-power charger and an HDMI hub into one ultimate device.
HDMI Port | Baseus launched 67W GaN5 Desktop Charger-Chargerlab
It adopts a rectangular design with an ice blue indicator light on top of the USB module. And it comes with a 1.5m non-detachable power cord, which makes it easy to extend the power from the wall outlet to the desktop. Thanks to the Baseus GaN5 technology, the overall size is only 96 x 46 x 38mm (3.78 x 1.81 x 1.50 inches), and the power density is 0.4W/cm³.
It has two USB-C, one USB-A and one HDMI ports in total. Among them, USB-C1/C2 supports 67W high-power PD fast charging, USB-C2 can be used for video signal input, and USB-A is used for devices like mouse and keyboard.
Since the maximum power for those two USB-C ports is the same, you can use either port to get the maximum 65W output. It also has five fixed PDOs of 5V3A, 9V3A, 12V3A, 15V3A, 20V3.35A, which can provide fast charging for a variety of electronic devices. When two devices use USB-C1 and USB-C2 ports at the same time, the power is 45W and 20W, respectively.
As for the USB ports, an electronic device such as a laptop can expand its USB-C into one USB-A and one HDMI port through the USB-C2 port. The expanded USB-A port is mainly used to connect common peripherals such as mouse and keyboard receivers, USB flash drives, printers, scanners, etc.
While connected to the charging port of the notebook, it can project the screen to a large display through the HDMI video port, supporting up to 4K@30Hz.
Wanna charge your steam deck and project it to your big TV when running out of battery? You got it!
For user convenience, it comes with a USB4 USB-C to USB-C cable. The cable length is 1m (3.3 ft) and supports 40Gbps data transmission, 100W power transmission and 4K video transmission. What's more, this USB4 cable is priced at $11.99 on UGREEN's official website, which is a good deal.
The Baseus 67W GaN5 desktop charger brings you a charging experience you've never had before. Combines 67W GaN fast charger and HDMI hub into one design,satisfying your charging, screen casting and port expanding needs at once.
$54.99 on Amazon US
1. Teardown of Baseus 100W Slim Laptop Power Bank (Blade Series)
2. Teardown of Anker UK Power Strip With 18W USB-C
3. Charging without Charger | Teardown of UGREEN DIGINEST Power Strip With Dual 65W USB-C Ports
67W Baseus power strip
Teardown of Enphase IQ7+ Microinverter (For Solar Energy)
Teardown of Baseus 67W GaN5 Charging Station (With HDMI Port)
SouthChip Unveils SC8808: A Robust High-Voltage Buck-Boost Controller for Advanced Battery Management
December 2, 2024
Infineon Launched a High-Voltage MCU With USB-C PD and Buck-Boost Charging Controller
May 9, 2023
Deep Dive of Charging Compatibility of the AMC 240W GaN Charger
May 21, 2026
Diodes Announces 20Gbps Universal High-Speed Crossbar Switch
September 19, 2019
