Home › News › Haycide Launched 20000mAh 155W Transparent Power Bank
PURCHASE
Today, ChargerLAB will introduce the 155W transparent power bank from Haycide. This power bank is similar to the SHARGE STORM 2 100W Transparent Super Power Bank, which we had took apart two years before.
Haycide Launched 20000mAh 155W Transparent Power Bank-Chargerlab
Product Introduction
The long-shaped power bank adopts a transparent design, and the internal PCB and components can be seen through the casing, which is geeky.
The display on the front of the power bank can show input and output voltage, current, power, remaining battery percentage, temperature, etc.
They're four 5000mAh 21700 batteries from LG are inside the power bank. The total capacity is 20000mAh, and it can be carried on the plane.
This power bank can charge the iPhone, iPad, and MacBook about 7 times, 2.5 times, and 1.5 times, respectively.
It has a 2C1A design and can charge three devices at the same time. The USB-C1, USB-C2, and USB-A can support 100W, 55W, and 18W output power when used alone. Dual USB-C port can output a maximum power of 155W. And the maximum output is 130W with three output ports.
The power bank supports PD3.0, PPS, QC3.0, AFC, FCP, SCP, PE1.1, PE2.0, and SFCP protocols.
It can support up to 100W fast charging input.
The battery protection chip is from Sinowealth and can protect it from high temperature, low temperature, etc. Model is SH366006.
The power bank has a transparent casing that allows you to see the internal components, and the display on the front of it can show specs. It also has a large battery capacity of 20000mAh and a total output power of 155W.
If you like its geeky look and need a power bank of large capacity, the Haycide 20000mAh 155W Transparent Power Bank may be a good choice for you!
PURCHASE
1. Teardown of SHARGE / STORM 2 100W Transparent Super Power Bank
2. Teardown of CUKTECH No.15 150W & 20000mAh Power Bank (PB200P)
3. Review of Baseus 140W PD3.1 Power Bank (2C1A)
155W 20000mAh Haycide Power Bank
Exclusive 20% Off Deal: Haycide 155W 20000mAh Transparent Power Bank
Hidden Magnetic Plug | Review of AOHi 65W Ultra-thin GaN+ Charger
Supporting PCIe Gen4, Data Rates Up to 16GT/s, Parade Technologies Launches OCuLink Interface Demo
October 4, 2024
CATL Expected to Increase Production Capacity to 137 GWh in 2022
June 18, 2019
Huntkey Appeared at the Hong Kong Electronics Fair to Show Charging Solutions
April 23, 2024
November 13, 2025
