Home › News › What's New › HAGiBiS Launched 240W LED Display USB 4 Cable with PD3.1
The charging cable can be divided into large current cables, high-speed cables, and full-featured cables according to the function. Among them, full-featured cables such as Thunderbolt 3, Thunderbolt 4, and USB 4 can support high-current charging and high data transmission speed.
Recently, HAGiBiS launched an LED Display USB 4 Cable with liquid silicone. It supports PD3.1 and integrates a power meter. Let’s take a look at the details of this cable.
HAGiBiS Launched 240W LED Display USB 4 Cable with PD3.1-Chargerlab
The cable is in green and black. It's a dual USB-C cable, which is compatible with most electronic products. Both ends of the cable are wrapped in aluminum alloy cases, and one end integrates a power meter for users to view the charging data.
Many users want to check the status during charging. The LED display on this cable allows users to check the charging status including current, voltage, and power conveniently.
Different from other cables, it is made of liquid silicone. The material makes it skin-friendly, cannot be burned by fire, and not easy to knot. The length is 1m (3 ft), a regular length.
This cable Integrates an E-marker chip.  It is compatible with the PD3.1 and backward compatible with PD3.0/2.0. It supports charging speeds of up to 48V 5A 240W. And it is also compatible with 140/100/60W power devices.
The transfer speed of it can be up to 40Gbps. It can support high-performance devices such as SSD enclosures and GPU enclosures. It also supports DisplayPort protocol and can connect your laptop to an 8K@60Hz external monitor.
The built-in power meter can help you get the real-time charging status directly. It is made of liquid silicone, making it skin-friendly, cannot be burned by fire, and not easy to knot.
It supports the PD3.1 and backward PD3.0/2.0. The charging power can be up to 240W, and the transfer speed can be up to 40Gbps. It also supports DisplayPort protocol to connect your devices to an 8K@60Hz external monitor.
The HAGiBiS LED Display USB 4 Cable is currently available on their official website.
1. Teardown of Apple 240W USB-C Charge Cable (A2794)
2. Review of Baseus 240W USB-C Fast Charging Cable
3. Review of LG 240W USB4 Cable with Full Pin Design
140W HAGiBiS PD3.1 USB4
OnePlus 12: The Flagship Killer That's Back
Teardown of DELL 495W Platinum Server Power Supply (D495E-S0)
Teardown of MECHREVO 140W USB-C GaN Power Adapter (AY140AA-1C-CH)
Teardown of Meituan 7000mAh 22.5W Shared Power Bank (MT-D-7BDY0)
Teardown of GreatWall 550W 80 PLUS Platinum SiC Server Power Supply (GW-CRPS550)
Teardown of Belkin 15W Auto‑Tracking Stand Pro with DockKit (MMA008)
EcoFlow Introduces 800W Alternator Charger: Enhance RV Power Capacity Up to 7.2kWh
August 16, 2024
ACASIS Launches 5 Bay External Array 2.5/3.5 Inch USB to SATA HDD RAID Case for Versatile Applications
July 29, 2024
Matching with MacBook Air 2022丨New Apple MagSafe 3 Cable Adopts Four Colors
July 22, 2022
Twice the Convenience: Baseus Qpow 2 Power Bank Equipped with Two Integrated Cables
July 31, 2023
