Thanks to the widespread adoption of the USB4 40Gbps full-feature port, most Ultrabooks now have the capability to connect to high-speed external peripherals. On the other hand, the handheld gaming PC market, fueled by high-efficiency processors, has gradually matured. In 2023, a confluence of various factors ignited the market for high-speed external peripherals such as eGPU enclosures and SSD enclosures.
In response to this market trend, OneXPlayer, under the umbrella of ONE-NETBOOK, has entered the realm of high-speed external peripherals by introducing the ONEXGPU. It features a 40Gbps USB4 full-feature port, combining the functionalities of a USB hub, eGPU enclosure, and SSD enclosure, while also supporting one-cable connection for 100W PD reverse power delivery.
The ONEXGPU boasts a compact design, measuring only 196 x 120 x 32mm, with an ultra-thin body weighing just 869g. Whether for on-the-go use or at home, users can enjoy powerful external GPU capabilities.
The top of the shell features fan ventilation holes, with all ports and buttons conveniently placed on the sides, accompanied by RGB lighting for a gaming atmosphere.
Essentially a multifunctional hub, let's delve into its port composition. It includes two USB-A 3.2 ports, an RJ45 Gigabit Ethernet port, two DP video ports, two HDMI video ports, an Oculink PCIe 4.0x4 graphics card direct connection port, a USB-C USB4 40Gbps full-feature port, and a DC 330W power input port.
On the inside, the ONEXGPU houses an AMD Radeon RX7600M XT graphics card, which can connect to the corresponding devices through the USB4 universal port or the Oculink PCIe direct connection port. This GPU utilizes a 6nm process RDNA3.0 architecture, achieving a TimeSpy score of 10542, closely comparable to the scores of the RTX 4060 mobile version.
To ensure stable and thorough release of graphics card performance, it employs a VC thermal plate with a heatsink, efficiently dissipating heat through a turbo fan.
The ONEXGPU is compatible with desktops, laptops, handheld gaming PCs, mini PCs, and other devices. It provides robust external GPU computing power support for portable and mini devices, significantly enhancing gaming performance. Additionally, it offers powerful graphics processing performance for creative work such as video rendering and image processing, greatly improving work efficiency.
In addition to its robust graphics card capabilities, the ONEXGPU can also serve as the device's external storage center. Opening the magnetic back cover at the bottom reveals a PCIe 3.0 M.2 expansion slot, allowing for the installation of a solid-state drive to expand the device's storage.
For power input, it comes with a standard 20V16.5A power adapter, supplying power through the DC port on the device, with a maximum power of 330W. Leveraging the USB-C reverse power delivery feature, the ONEXGPU can provide USB PD fast charging to handheld gaming PCs, laptops, and other devices through the same USB-C cable, with a maximum power of 100W.
Benefiting from its universal USB-C port, the ONEXGPU stands out for its excellent compatibility with a wide range of devices. The use of this standard interface enhances its adaptability to various computing setups, offering users a hassle-free and streamlined connection experience.
Furthermore, the ONEXGPU perfectly complements OneXPlayer's handheld gaming console. The harmonious integration of the ONEXGPU with the OneXPlayer device ensures a tailored and optimized gaming experience. This synergy between the external GPU and the gaming console underscores the commitment to providing users with a seamless and high-performance gaming ecosystem.
Currently, this product has successfully concluded its crowdfunding phase on Indiegogo and is now officially available for pre-order on the OneXPlayer online store. With a starting price of $680, shipments are set to commence on March 15, 2024. If you are intrigued and wish to make a purchase, you can click on the link provided within the article to place your order.
1. How Fast ASUS ROG Ally (Z1 Extreme) Is Charged? - ChargerLAB Compatibility 100
2. HDMI Supported | Review of ASUS ROG 65W Charger Dock For ROG Ally
3. SSD Inside the GPU? Introducing the ASUS Concept Graphics Card With Integrated M.2 Slot
