Home › News › What's New › EcoFlow Launched GLACIER Portable Refrigerator & WAVE 2 Portable Air Conditioner
$999 on Amazon US
$1,299 on Amazon US
Summer is just around the corner, and for outdoor enthusiasts, it's a mixed bag of emotions. While they get to embrace nature, they also have to endure the heat, making them long for air conditioning and cold drinks. That's where EcoFlow comes in. The company has recently launched two products specifically designed to cater to the hot summer weather - the EcoFlow GLACIER Portable Refrigerator and the EcoFlow WAVE 2 Portable Air Conditioner. These products enable outdoor enthusiasts to fully enjoy their summertime activities.
EcoFlow Launched GLACIER Portable Refrigerator & WAVE 2 Portable Air Conditioner-Chargerlab
The EcoFlow GLACIER Portable Refrigerator uses a compression cooling principle, providing superior cooling performance compared to similar products that use electronic cooling chips, and it can cooling at the optimum speed when empty, rapidly refrigerated from 86°F (30°C) to 32°F (0°C) in around 15 minutes. In addition to its refrigeration function, it also has a separate ice-making area with a powerful 120W compressor, which can efficiently produce 18 ice cubes in just 12 minutes. You can surely count on it to add some excitement to your journey and quench your thirst with some ice-cold sodas.
Its internal structure is square and neat, with a maximum capacity of 38L (40 qt), which can hold 60 cans of 330ml soda. It has single/dual-zone fridge-freezer capabilities, with the fridge mode ranging between 32°F (0°C)-50°F (10°C) and the freezer ranging between -13°F (-25°C)-32°F (0°C). As for how it can achieve that? Well, it has a removable divider that can separate the refrigerator into two zones with independent temperature control, allowing for flexible loading of different quantities of fruits, fresh food, cold drinks, ice cream, and other items.
The EcoFlow GLACIER Portable Refrigerator supports multiple power supply methods, including 100-240V 180W AC input, 12/24V car charging input, 11-60V 240W solar charging input, and 100W battery pack input. The battery pack uses a plug-and-play structure and has a capacity of 298Wh. When operating in Eco energy-saving mode, the refrigerator can be used for up to 40 hours on battery power alone. The built-in battery also has a 100W USB-C universal port, which can not only power the refrigerator but also serve as a fast-charging power bank for other consumer electronics.
The WAVE 2 Portable Air Conditioner is EcoFlow's second-generation outdoor portable air conditioner. Compared to its predecessor, it has increased cooling power up to 1500W and increased cooling capacity by 25%. Additionally, it has added a heating function with a power of 1800W, and it can heat or cool down by 18℉ (10°C) in just 5 minutes after start-up. The EcoFlow WAVE 2 is also equipped with advanced software algorithms, offering multiple modes and app control. It operates quietly (44 dB) in Sleep mode and can run for up to 8 hours in Eco mode.
Its built-in motor pumps condensation water to the condenser for efficient cooling and does not require manual drainage under normal conditions. It comes with two exhaust ducts and supports various layouts such as single duct, double duct, and direct airflow for flexible use in different scenarios. It supports cooling, heating, and ventilation functions and has three power modes: Max, Eco, and Sleep. Whether it's for rapid cooling/heating or comfortable sleeping, users can easily control it.
The EcoFlow WAVE 2 Portable Air Conditioner can be paired with an optional smart add-on battery base with a large capacity battery pack of 1159Wh, providing up to 8 hours of continuous operation. You can also add on a DELTA 2/DELTA Max and extend run times to a record-breaking 14hrs - that's 28% more efficient than other power stations. And of course, you can top up at home via a wall outlet too. The intelligent battery base has an 18W USB-A port and a 100W USB-C output port, which can fast charge other electronic products.
In conclusion, the EcoFlow GLACIER Portable Refrigerator is a wonderful solution for outdoor activities during summer. Its superior cooling performance, combined with its compact size, makes it ideal for camping, tailgating parties, and other outdoor events. The refrigerator's separate ice-making area, flexible loading options, and different power supply methods give it significant advantages over other portable refrigerators. Furthermore, its 298Wh battery pack, complete with a 100W USB-C universal port, allows it to double as a fast-charging power bank for other electronics, making it an excellent multi-purpose device.
The EcoFlow WAVE 2 Portable Air Conditioner is an outstanding product designed specifically for outdoor activities during summer. Its increased cooling power, added heating function, and flexibility of use make it a top contender in the portable air conditioner market. Paired with an optional smart add-on battery base, the air conditioner can run for even longer periods. Furthermore, the battery base's USB-C output port and USB-A port enable it to be used as a charging device for other electronic products, adding to its versatility. Overall, the EcoFlow WAVE 2 Portable Air Conditioner is an exceptional product that can provide a refreshing and comfortable experience for outdoor enthusiasts during the hot summer months.
The EcoFlow GLACIER Portable Refrigerator starts at $999 on Amazon US, while the EcoFlow WAVE 2 Portable Air Conditioner starts at $1,299 on Amazon US, you can click the buttons at the beginning or the end of the article to take a look.
$999 on Amazon US
$1,299 on Amazon US
1. EcoFlow BLADE: A Revolutionary Smart Robotic Lawn Mower Debuts at CES 2023
2. EcoFlow Launched 1800W DELTA 2 Portable Power Station
3. The New EcoFlow RIVER Mini Portable Power Station Makes Travel Easier
EcoFlow refrigerator
Apple iPhone 15 Support 15W Wireless Charging Without MagSafe
Teardown of Lenovo 65W Mini GaN Charger (BG65)
Unboxing of UGREEN 4-Outlet Extension Cord Power Strip
April 21, 2023
aigo Launches China’s First USB Flash Drive with a Read Speed of 440MB/s, Taking Flash Drives to the Next Level
August 12, 2024
IOGEAR Releases New USB-C KVM Solution
August 15, 2019
Perfect for iPhone Fast Charging: UGREEN Launches Qi2 2-in-1 Wireless Charger
July 15, 2024
