Recently, EcoFlow officially released DELTA 2, the second generation portable power station of the EcoFlow DELTA series, with comprehensive upgrades in all aspects.
It adopts the same design as the DELTA lineup, with a gray and black shell and handles on both sides, an AC port on the left, USB fast charging module on the right, and a fan outlet on the top.
It supports up to 1800W rated output and can power 2400W appliances under certain conditions. It is equipped with four AC power sockets, which are sufficient to cope with common power supply scenarios.
It has a battery capacity of 1 kWh, equal to 1024Wh. It also supports power expansion, which can be connected to the secondary battery to expand the capacity to a maximum of 3 kWh, meeting the need for ultra-long battery life.
It adopts an adapter-free fast charging solution, which can charge 80% in as fast as 50 minutes and 100% in just 80 minutes.
To ensure the safety and longevity of the battery, it adopts the lithium iron phosphate battery with a cycle life of more than 3000 cycles.
It's equipped with six USB ports (2C4A). Two USB-C ports support 100W PD fast charging output, which can provide 100W PD for devices such as cell phones, tablets and even laptops, so you can enjoy high-power fast charging directly without bringing a charger.
The new EcoFlow DELTA 2 portable power station adopts the same design as the DELTA lineup, with a gray and black shell and handles on both sides, an AC port on the left, USB fast charging module on the right, and a fan outlet on the top.
And it supports up to 1800W rated output and can power 2400W appliances under certain conditions. It is equipped with four AC power sockets, which are sufficient to cope with common power supply scenarios.
1. First Look of New Anker 767 Portable Power Station (GaNPrime PowerHouse 2048Wh)
2. The New EcoFlow RIVER Mini Portable Power Station Makes Travel Easier
3. The New AlphaESS BLACKBEE 2000 Portable Power Station Is Coming Soon
