Home › News › What's New › DUKA Launched EG-1 Hot Glue Gun with USB-C Port
The USB-C port now fully covers mainstream digital devices such as mobile phones, tablets, and laptops, and this also happens to electronic products such as portable digital oscilloscopes, electronic blood pressure monitors, and electric toothbrushes.
Recently, ChargerLAB discovered that the EG1 hot glue gun launched by DUKA also adopts a USB-C port, which improves the convenience of use.
DUKA Launched EG-1 Hot Glue Gun with USB-C Port-Chargerlab
The DUKA EG1 hot glue gun has a modern and simple design. The gun gray body has a matte surface, which is stain-resistant, scratch-resistant, and non-slip. Its ergonomic T-shaped handle allows you to turn on the machine and apply glue with one hand. It also has a built-in battery capacity of 2500mAh.
As can be seen from the official disassembly diagram, there are heating core, glue feeding gear, single cylindrical lithium-ion battery cell, control panel, and other components inside. The extended heating core speeds up the heating, and the heating temperature is 150 °C (302 ℉). It works with 7 mm glue sticks.
The simple design significantly reduces the weight, which is only 157g (5.54 oz). It will automatically shut down if there is no operation for 3 minutes to avoid consuming power. The innovative glue overflow design can avoid burns and sticky items.
DUKA EG1 hot glue gun adopts a USB-C port. It can charged by phone chargers and power banks. You can even use the reverse charging function of your mobile phone or laptop to charge it temporarily.
The DUKA EG1 hot glue gun adopts a simple design, a cylindrical lithium-ion battery cell, and a USB-C port. The use of USB-C brings it better compatibility. For users, it also saves the trouble of finding original chargers and is more convenient.
It can do things such as photo frame pasting, gift wrapping, toy assembly, DIY greeting cards, craft making, object repair, etc.
DUKA hot glue gun USB-C
Turbo Mode Enabled | Check out These Eleven Power Banks for Your ROG Ally
Lenovo Legion Go Charging Test - ChargerLAB Compatibility 100
CIBF 2026 Roundup: 167 Battery Powerhouses Converge
2026 AlpSolarr Energy Storage Product Catalog
2026 EVE Energy Consumer Battery Product Catalog
Teardown of HP 65W Dual USB-C GaN Power Adapter
February 1, 2023
15
Immersive Unboxing of Tesla Wireless Portable Charger
October 16, 2024
Nomad's Latest USB Cables are Made of Actual Kevlar
July 17, 2019
Qi2-Certified Products Surpass 500 Models!
September 5, 2024
