Home › Guides › Deals › Discount is HERE | ChargerLAB POWER-Z AK001 Now Supports iPhone 15 Series
PURCHASE
Several months ago, we released the ChargerLAB POWER-Z AK001 240W USB-C cable for $29.99. But at that time, the iPhone still adopted the Lightning port, so it cannot be used. One of the biggest selling points of the iPhone 15 series is the USB-C port. It makes charging easier and can do more. As the most powerful test cable, AK001, of course, is a perfect match for the iPhone 15 series. Today, let's see how to test the real-time fast charging power of the iPhone 15 series with AK001.
Discount is HERE | ChargerLAB POWER-Z AK001 Now Supports iPhone 15 Series-Chargerlab
It's fixed with a Velcro cable tie. The outer layer of this test cable is made of black TPE.
Since it only supports USB 2.0, it does not adopt a full-pin design.
The most obvious difference of this cable is the digital display. You can even see the PCB through the translucent matte case.
The 0.96-inch color display shows real-time charging current, voltage and power.
It's only equipped with a single button on the back.
You can press it to switch between the main menu, USB detection menu, LOGO page, and off-screen.
The maximum voltage supported by AK001 is 50V and the maximum current is 5A. So, it has the same performance as the Apple 240W cable we took apart before. It's just a piece of cake to charge your iPhone 15.
Its length is 1.5M (5FT).
And its diameter is about 4.3mm (0.17 inches). So it's longer and thicker than Apple original cable to bear higher current.
We tested all four models of iPhone 15 series. Thanks to the USB-C port, we can clearly see the voltage, current, power, and current direction without any adapters. We found it triggers 9V and the maximum current won't exceed 3A. So, the continuous charging power is around 20W. And the peak power won't exceed 25W.
As for charging compatibility, it not only supports Apple’s original chargers, but also most third-party chargers.
Except for the iPhone 15 series, you can also use it to test Android phones that support high charging power.
If you need a tester for professional purposes or have higher requirements for data accuracy, we strongly recommend you choose KM003C.
But if you just want to check the real-time charging speed of your USB-C devices, then we recommend you choose the more affordable option, like AK001, or C240.
From now on, AK001 is on our biggest discount of 33%. And the price dropped from $29.99 to $19.99. As quantities are limited, please seize the last chance. You can click on the buttons at the beginning or the end of the articles to get one!
PURCHASE
1. Everybody LOVES the POWER-Z AK001 | Check Out What ZDNET Has to Say About It
2. Unboxing of ChargerLAB POWER-Z AK001 240W Test Cable (1.5M/5FT)
3. Bang for the Buck | Introducing the Brand New POWER-Z AK001
AK001 Discount iPhone 15
For ROG Ally | Introduction of ROG 65W Gaming Charger Dock
Only $49.99 | Unboxing & How to Use ChargerLAB POWER-Z KT002 USB-A Tester
November 12, 2023
October 25, 2023
40% Off on Haycide 100W GaN Charger - Dual Circuit Design for Hassle-Free Charging!
December 14, 2023
29% OFF! | Unboxing of the ChargerLAB POWER-Z KT002
November 14, 2023
