Home › News › What's New › CUKTECH Launched No. 30 Power Bank at Hong Kong Electronics Show
From April 18-21, 2023, CUKTECH exhibited with ZMI at theHong Kong Global Sources Consumer Electronics Show, showcasing several new products for the first time. Founded in 2016, CUKTECH received investments from capital firms such as Xiaomi, ZMI, and SHUNWEI. In the charging market, CUKTECH has created multiple single-port, double-port, and multi-port GaN chargers for Xiaomi and ZMI, including the "ZMI PowerPack No. 20," a phenomenally high-performance power bank that has received acclaim from various media outlets and users. In 2022, the CUKTECH brand was upgraded through the addition of the core team from ZMI, continuing to develop high-performance fast charging accessories for users.
CUKTECH No. 30 Power Bank
CUKTECH Launched No. 30 Power Bank at Hong Kong Electronics Show-Chargerlab
One of the most impressive products at the electronics show was the CUKTECH No. 30 Power Bank, the fantastic super sequel to the high-performance power bank, ZMI PowerPack No. 20, with model number P01CT.
The CUKTECH No. 30 Power Bank features a square exterior design with a handle for easy carrying, a silver-black color scheme, and a transparent cover on top. Its product dimensions measure 86.8 x 88.6 x 106.5mm (3.42 x 3.49 x 4.19 inches) and it boasts a larger battery capacity, stronger output specifications, and a more intuitive digital display screen compared to the ZMI PowerPack No. 20.
Beneath the black translucent panel on the front, there is a large digital display screen that shows information such as remaining battery percentage, input power, and output power, making it easy to understand the device's charging status.
The CUKTECH No. 30 Power Bank also boasts impressive specs, with a transparent top panel that houses a built-in 20W wireless charging coil, a 2A2C USB fast charging module in the front, and a USB-C1 that supports the PD3.1 fast charging standard with a maximum output of 140W (28V 5A), USB-C2 that supports 100W fast charging, USB-A1 that supports 120W (20V 6A) fast charging, and USB-A2 that supports 22.5W fast charging. The number and specifications of its ports are incredibly powerful, supporting charging for up to five devices simultaneously with a maximum output power of 300W.
The USB-C port also serves as a full-featured port, allowing the CUKTECH No. 30 Power Bank to act as a USB hub for digital devices, expanding the device's capabilities by providing additional USB-A ports for connecting peripherals such as mice, keyboards, external hard drives, and flash drives.
On the side of the device, "40000mAh" is printed, revealing that it contains cylindrical steel shell battery cells that make up a total of 144Wh/40000mAh of energy storage. The battery cells use 21700-type batteries, which offer significant improvements in energy density and charge-discharge performance compared to the more common 18650-type batteries.
The back of the device features a grille design and built-in PWM adaptive fans that can adjust its speed as needed to maintain low temperatures and stability during long-term high-powered output.
Additionally, the CUKTECH No. 30 Power Bank was awarded the "EPDA European Product Design Award - The Best of Hong Kong Trade Shows."
P23 CUKTECH P Series 25000mAh 210W Power Bank
CUKTECH's official website also showcased a new product, the P23 CUKTECH P Series 25000mAh 210W Power Bank, located in the middle of the picture above. It features a long and slender columnar appearance design, a silver-black translucent body, and a three-port configuration that supports three independent fast charging ports. It also comes with an integrated color display screen that can show multiple electrical parameters. The battery has a capacity of 25,000mAh, built-in through-fan cooling, supports the PD3.1 fast charging standard, has a total output power of 210W, and supports high-speed self-charging of up to 120W in approximately two hours. The above specs are based on random news reports and may contain inaccuracies, so they should be used for reference only.
ZMI Products
In addition to the CUKTECH's new products, ZMI exhibited several quick charging products, including the ZMI power bank series, ZMI rainbow alkaline battery series, ZMI fast charging cable series, and ZMI GaN charger series.
In conclusion, CUKTECH exhibited several new and impressive products at the Hong Kong Global Sources Consumer Electronics Show in 2023. The CUKTECH No. 30 Power Bank, in particular, was a standout product with its larger battery capacity, stronger output specifications, and intuitive display screen. It also features a transparent front panel housing multiple powerful ports that allow for charging up to five devices simultaneously. Additionally, the P23 CUKTECH P Series 25000mAh 210W Power Bank and ZMI's quick charging products were also showcased. With its continued focus on high-performance fast charging accessories for users, CUKTECH proves itself to be a qualified player in the fast charging market.
1. Teardown of CukTech Lighter 65W GaN Charger AC65B
2. ChargerLAB at Hong Kong Global Sources Consumer Electronics
3. Teardown of Baseus 100W Slim Laptop Power Bank (Blade Series)
CUKTECH Power Bank
Charging Compatibility Test of OPPO Find X6 Pro
A Shot Above | Xiaomi 13 Ultra Launch Event
Anker Launches MagGo Wireless Charging Station (Foldable 3-in-1)
October 13, 2024
OnePlus Wireless Charging Phones Overview: Up to 50W Wireless Fast Charging
September 9, 2024
New Asus Adol 100W GaN Charger Enjoys Quite A Popularity
June 24, 2022
EcoFlow Launched GLACIER Portable Refrigerator & WAVE 2 Portable Air Conditioner
May 25, 2023
