Home › News › Computer Case With 60W Fast Charging: Meet the ROG Hyperion GR701
$489.29 on Amazon US
Have you ever wondered what makes a $500 computer case special? Well, in early 2023, ASUS released a truly remarkable product - the ROG Hyperion GR701 EATX Full-Tower Computer Case. This computer case boasts a range of impressive features and highlights, from its unique X-shaped aluminum alloy frame and spacious interior, to its lightning-fast USB4 40Gbps high-speed port and support for 60W PD fast charging. Essentially, this computer case brings full-featured USB-C ports directly to your PC. As for the price, you guess it, $499.99.
Computer Case With 60W Fast Charging: Meet the ROG Hyperion GR701-Chargerlab
The ROG Hyperion GR701 EATX Full-Tower Computer Case's special X-shaped aluminum alloy frame is constructed using high-precision CNC milling technology and anodizing processes, resulting in an ultra-sturdy structure that can bear up to 80kg. Its double air channel on both sides ensures quick and efficient heat dissipation, while magnetic and rotation combination make opening the two sides convenient and tool-free. Additionally, the front panel and internal light board support AURA SYNC RGB lighting effects.
Perhaps one of the most impressive aspects of this computer case is its top-front port, which includes not only common features such as a power button and reset button, but also a light control button. Furthermore, it is equipped with a 3.5mm headphone jack and a four USB-A, two USB-C ports, along with support for ultra-fast data transmission of 40Gbps and 60W fast charging - impressive features indeed.
The ROG Hyperion GR701 EATX Full-Tower Computer Case's USB-C1 uses a USB4 ultra-high-speed spec, while USB-C2 uses a USB3.2 Gen2x2 20Gbps high-speed spec. According to ASUS, the USB-C port also has a 60W fast charging output, supporting PD and QC4+ fast charging protocols (requires a motherboard with a special TB4 interface, such as the ROG MAXIMUS Z790 EXTREME). The four USB-A ports are USB3.0, with a speed of 5Gbps.
Thanks to its spacious and reasonable internal layout, the ROG Hyperion GR701 EATX Full-Tower Computer Case can easily accommodate powerful performance hardware. It supports E-ATX motherboards, graphics cards with a length limit of 460mm, which means you can easily put a monster in it such as the RTX 4090 flagship graphics card, and a CPU cooling height limit of 190mm. No longer need not worry about size limitations for water cooling systems, as the computer case supports dual 420mm radiators, an aluminum alloy dual-mode supported graphics card bracket, and comes pre-installed with ARGB and PWM fan HUB with four 140mm fans. Additionally, the bottom of the computer case comes equipped with an embedded functional compartment for storing accessories.
Overall, the ROG Hyperion GR701 EATX Full-Tower Computer Case from ASUS is a truly impressive product that boasts a range of advanced and innovative features. Its X-shaped aluminum alloy frame, spacious interior, lightning-fast USB4 40Gbps high-speed interface, and 60W PD fast charging support make it stand out from other computer cases on the market. Additionally, its top-front interface and spacious internal layout make it easy to use and install even with powerful performance hardware. Overall, the ROG Hyperion GR701 EATX Full-Tower Computer Case offers unparalleled functionality and performance, making it an excellent choice for serious gamers and PC enthusiasts.
As mentioned earlier, the ROG Hyperion GR701 EATX Full-Tower Computer Case is priced at a whopping $500, but that's not all! It also requires the ROG MAXIMUS Z790 EXTREME motherboard priced at a jaw-dropping $1000 to unlock its full potential. You can click the button at the beginning or the end of the article to get this outstanding computer case.
1. New Gamer on the Block | ASUS Launched the Rog Ally Handheld Gaming Console
2. Unleashing the Power of Gaming | ASUS Launched ROG Phone 7 Series
3. Teardown of ASUS ROG Thor 1600W Titanium Power Supply
ASUS ROG
Transformers Inside | Anker Launched 65W GaNPrime 733 Power Bank
Charging Compatibility Test of OPPO Find X6 Pro
Innosicence Launches 100V GaN Device, Redefining AI and 48V Power Applications
March 28, 2025
CXW’s CX8831CA, The
June 9, 2026
How to Replace Your Damaged MacBook Battery (MacBook Air 2017)
August 20, 2022
May 29, 2026
