Home › Reviews › Charging Compatibility › Compatibility Test of Huawei MatePad Pro 13.2 (UFCS Chargers)
You might have come across mentions of UFCS (Universal Fast Charging Specification) in our previous articles. This is a new fast-charging technology gaining traction in China, which is a next-generation fast charging protocol jointly developed by Huawei, OPPO, Vivo, Xiaomi, and several chip companies.
While UFCS-compatible devices are increasing, few support truly high power, i'm talking about nearly 80W. The Huawei MatePad Pro stands out, supporting UFCS 88W charging. So today, let's explore its compatibility with various UFCS chargers.
Compatibility Test of Huawei MatePad Pro 13.2 (UFCS Chargers)-Chargerlab
UFCS Chargers
USB-A
Starting with USB-A chargers, Huawei 100W charger's USB-A port successfully triggers the UFCS fusion fast charging protocol on the Huawei MatePad Pro. ChargerLAB POWER-Z KM003C shows a power output of 17.28V 4.97A 85.84W, an impressive result.
Next, the OPPO 33W charger's USB-A port delivers 7.97V 2.91A 23.19W of power to the Huawei MatePad Pro using UFCS.
Summarizing the tested products in a table, we can see that all chargers triggered the 8V, 15V, and 18V voltage levels, indicating full compatibility with the Huawei MatePad Pro.
A bar chart shows that the tested chargers provide power to the Huawei MatePad Pro ranging from 21W to 86W. The Huawei 100W charger tops the list with an output of 85.07W.
USB-C
Moving on to USB-C ports, the Huawei 100W charger's USB-C port delivers 17.28V 4.97A 85.84W of power to the Huawei MatePad Pro, slightly better than its USB-A counterpart.
The Huawei 88W car charger's USB-C port outputs 17.67V 4.34A 76.64W.
Similar to the USB-A section, the chargers trigger the 8V, 15V, and 18V voltage levels.
A bar chart reveals that USB-C ports provide power to the Huawei MatePad Pro ranging from 22W to 89W. Again, the Huawei 100W charger reigns supreme, delivering 88.62W.
UFCS fusion fast charging envisions a future where proprietary charging protocols are no longer incompatible, replaced by a universal standard that streamlines the fast-charging landscape. While still in its early stages, this protocol is rapidly gaining traction.
In terms of compatibility testing, the Huawei MatePad Pro supports 88W fast charging. Using high-power UFCS fast chargers, the maximum charging power can indeed reach 88W. For lower-power UFCS chargers, compatibility is also excellent, with charging power maintained between 21W and 30W.
1. Single or Dual Ports? | Teardown of HUAWEI 88W Fast Charger (P60 Series)
2. How Fast HUAWEI Mate 60 Pro Is Charged? - ChargerLAB Compatibility 100
3. How Fast Is Huawei MatePad Pro Charged? - ChargerLAB Compatibility 100
ChargerLAB Huawei
V1.8.8 | The New Software Version of POWER-Z KM003C
20W | Review of Durex 10000mAh Magnetic Power Bank
Charging Compatibility Test of Nintendo Switch TV mode (20-100W)
October 25, 2021
Charging Compatibility Test of REDMAGIC 7S
August 28, 2022
How Fast Is iQOO Neo9 Pro Charged? - ChargerLAB Compatibility 100
March 15, 2024
Charging Compatibility Test of realme GT Neo 3
May 28, 2022
