In the fiercely competitive consumer electronics market, AUKEY has established itself as a prominent brand dedicated to delivering innovative and high-quality technology products to consumers worldwide. With years of expertise in the electronics industry, AUKEY has built a strong foundation in research and development, offering a diverse range of products, including charging accessories and audio devices. Known for their outstanding performance and reliability, AUKEY’s products have earned the trust of countless users.
Recently, AUKEY introduced the MagFusion Pro series of active cooling wireless chargers, featuring the Omnia-Frez Active Cooling System, once again showcasing its innovation in charging technology. This lineup includes the MagFusion GameFrost, MagFusion Dash Pro, and MagFusion 3-in-1 Pro, each designed to cater to different usage scenarios and user needs. ChargerLAB has obtained all three products for an in-depth review, evaluating their performance, functionality, and design. Let’s dive in!
Unboxing
All three products are packaged in white and green. From left to right, they are AUKEY MagFusion GameFrost, AUKEY MagFusion Dash Pro, and AUKEY MagFusion 3-in-1 Pro. Next, we will introduce the three products in this series one by one.
Product Introduction
AUKEY MagFusion GameFrost uses metallic gray spray paint and has a matte feel and a high-end texture. The top integrates lighting, charging, cooling adjustment, and temperature display functions. It comes with a 150cm long dual USB-C cable. It is worth mentioning that its design also won the 2025 CES Innovation Award and iF Design Award.
Next, let’s take a look at its spec info.
Model: LC-G10
Input: 5V 3A/ 9V 3A
Output: 5W, 7.5w, 10w, 15W(Max)
Size: 25.1 x 63 x 63mm
Weight: 94g/3.320z
The AUKEY MagFusion GameFrost integrates AUKEY’s latest active cooling technology to deliver an optimized charging experience. It supports Qi2-certified that it can provide 15W fast wireless charging for iPhone 12 and newer models, while the Omnia-Frez Active Cooling System reduces charging temperatures by up to 20°C (68°F). This helps prevent overheating, ensuring a cooler, more efficient, and safer charging process while also protecting battery health. Users have manual control over both charging and cooling functions, allowing them to use the device as an independent cooler, a wireless charger, or both simultaneously. Additionally, a real-time temperature display provides instant feedback on temperature changes at a glance. To enhance the gaming atmosphere, the device also features adjustable lighting effects, making it an immersive accessory for mobile gamers. For those who demand the ultimate gaming and charging experience, the MagFusion GameFrost is the perfect choice.
This Qi2-certified wireless charger can deliver 15W fast wireless charging for devices running iOS 17.2, iPhone 16 series (excluding iPhone 16e), and all iPhone 12 and newer models. In a test with the lighting on and the cooling system set to maximum in Freezing Mode, the input power measured approximately 27.63W. Of this, the wireless charging transmission power is around 20W. The phone can receive 15W charging power, while the cooling system consumes about 7.63W.
Turn on the lights and cooling system, and use it to fully charge the iPhone 16 Pro Max.
The voltage is always around 9V. The charging curve can be divided into three parts. The power stays at 25W for the first 59 minutes. Then, the power drops to 17W. The final part begins at 1 hour and 24 minutes, and the power slowly drops to almost zero. It takes 2 hours and 31 minutes to fully charge the iPhone 16 Pro Max.
The MagFusion GameFrost sets itself apart from traditional wireless chargers with its advanced Omnia-Frez Active Cooling System, which features a thermoelectric cooling chip and a high-speed fan at its core. Compared to conventional wireless chargers, this innovative technology not only delivers exceptional cooling performance but also enables a faster and safer charging experience for devices.
Comparing the temperature test data between the AUKEY MagFusion GameFrost and Apple MagSafe charger, it’s evident that the GameFrost’s temperature curve consistently remains below ambient temperature throughout the test. In contrast to the MagSafe charger, the MagFusion GameFrost demonstrates a smoother and more stable temperature curve, with a peak temperature difference of up to 16°C.
Overall, the Omnia-Frez Cooling System gives the MagFusion GameFrost a significant thermal management advantage over traditional wireless chargers, ensuring better temperature control and a more efficient charging experience.
The AUKEY MagFusion GameFrost excels in both design and user experience, seamlessly combining cooling and wireless charging into a single device. It effectively dissipates heat while ensuring stable and efficient charging, making it a game-changer for users who demand high-performance smartphone usage.
For streamers and mobile gamers, the MagFusion GameFrost is truly a must-have accessory, delivering an all-in-one solution for heat management and fast charging.
The AUKEY MagFusion 3-in-1 Pro stands out with its unique and refined design, earning the prestigious 2024 Red Dot Design Award. It features the signature metallic gray finish of the MagFusion series, exuding a sleek and modern aesthetic.
Crafted with sustainability and durability in mind, its support pillar is made from recyclable aircraft-grade aluminum, while the charging panel is constructed from tempered glass. This minimalist yet futuristic design not only enhances its visual appeal but also ensures seamless integration into various environments. Beyond aesthetics, it offers practicality and convenience, making everyday charging both stylish and effortless.
It is Qi2 and MFW certified, ensuring seamless compatibility with Apple devices. It innovatively integrates the Omnia-Frez Active Cooling System into a 3-in-1 charging station, combining semiconductor cooling and fan technology to reduce charging temperatures by up to 20°C, enhancing overall efficiency.
For added convenience, the top of the device features a cooling switch button, allowing users to turn off the cooling system before bedtime for a quiet and uninterrupted sleep experience.
The wide base design provides enhanced stability, ensuring a secure setup on any surface. At the center of the base, the black module serves as the wireless charging pad for earphones.
AUKEY MagFusion 3-in-1 Pro has passed CE, Qi2, and other certifications. The spec info is as follows.
Model: LC-MC311A
USB-C In: 5V 3A/ 9V 3A/ 12V 3A
Phone magnetic wireless Out: 5W, 7.5w, 10w, 15W(Max)
Watch magnetic wireless Out: 5W Max
Earphone magnetic wireless Out: 5W Max
Size: 154 x 102 x 115.5mm
Weight: 360g / 12.70oz
This wireless charging station is specifically designed to cater to iPhone, AirPods, and Apple Watch users, providing an all-in-one solution that eliminates the hassle of managing multiple chargers and cables.
It is equipped with the Omnia-Frez Active Cooling System, with carefully designed intake and exhaust vents. The fan and cooling fins are arranged separately, ensuring sufficient airflow for heat dissipation while keeping noise levels low during charging, providing an optimal user experience.
By plotting the temperature curve of the phone's magnetic charging surface and comparing it with the Apple MagSafe charger, it is evident that the AUKEY MagFusion 3-in-1 Pro maintains a significantly lower temperature. The peak temperature with the MagFusion 3-in-1 Pro is around 27°C, whereas the MagSafe charger reaches approximately 42°C—a difference of nearly 15°C. Moreover, the MagFusion 3-in-1 Pro consistently keeps the temperature below 20°C, which is also well below the ambient temperature of 25°C. In terms of heat dissipation, the MagFusion 3-in-1 Pro delivers outstanding performance.
It is Qi2 certified. With the cooling system turned on to charge the iPhone 16 Pro Max, the total input power is about 24.81W. It can provide 15W fast wireless charging for iPhone 12 and subsequent models running iOS 17.2 or higher.
Next, use it to fully charge the iPhone 16 Pro Max.
At first, the voltage is around 12V. The charging curve can be divided into three parts. The power is around 25W for the first 57 minutes. Then, the power drops to 17W and remains at this level until 1 hour and 21 minutes. After that, the voltage drops from 12V to 9V. It takes 2 hours and 35 minutes to charge the iPhone 16 Pro Max fully.
The built-in watch charger is MFW (Made for Watch) certified, which ensures the best performance match and high compatibility with the Apple Watch. It can charge the Apple Watch Ultra and Apple Watch 7 and later models at 5W.
Use it to perform a full charging test on the Apple Watch Ultra.
The voltage is always around 9V. The power stays at 6W for the first 7 minutes. The power fluctuation of 0.4-5.5W occurred in the middle and lasted until 1 hour and 10 minutes. The power then stabilizes at 3.8W and continues charging until 1 hour and 27 minutes. It takes 1 hour and 38 minutes to fully charge.
We also turn it into another curve. The AUKEY MagFusion 3-in-1 Pro can charge the Apple Watch Ultra to 50% in 45 minutes. And it can reach 80% in 1 hour and 15 minutes, and 100% in 1 hour and 38 minutes.
It comes with a 45W charger and a 1.5m dual USB-C cable.
Here is the spec info of the 45W charger.
Model: PA-F4
In: 100-240V~1.2A 50/60Hz
USB Out: 3.3-11V5A(PPS)5V3A、9V3A、12V3A、15V3A、20V2.25A(45W)
Max Out: 45W
The AUKEY MagFusion 3-in-1 Pro stands out with its distinctive and well-crafted design, earning the prestigious 2024 Red Dot Design Award. Its versatile three-in-one functionality seamlessly integrates wireless charging for iPhone, AirPods, and Apple Watch, eliminating clutter and enhancing convenience. To further enhance the user experience, AUKEY thoughtfully includes a 45W charger and a 1.5m dual USB-C cable, providing Apple ecosystem users with a hassle-free, all-in-one charging solution.
The AUKEY MagFusion Dash Pro sets itself apart from traditional car mounts with its advanced Omnia-Frez Active Cooling System, featuring a thermoelectric cooling chip at its core. Compared to conventional wireless chargers, it delivers cooler performance, ensuring faster, safer charging while also helping to maintain battery health.
The AUKEY MagFusion Dash Pro features a flexible 360° adjustable ball joint, allowing users to effortlessly adjust their phone’s angle for optimal GPS navigation while driving. The MagFusion Dash Pro has been honored with the 2025 iF Design Award, further highlighting its excellence in both functionality and aesthetics.
After the cooling system is turned on, use AUKEY MagFusion Dash Pro to charge the iPhone 16 Pro Max, with an input power of 25.91W. Excluding the losses, it shows very good charging power. Its magnetic panel features foreign object detection and temperature control, ensuring safe and reliable charging.
The voltage is always around 9V. The charging curve can be divided into three parts. The power stays at 26W for the first 58 minutes. Then, the power drops to 18W. The final part begins at 1 hour and 22 minutes, and the power slowly drops to almost zero. It takes 2 hours and 23 minutes to fully charge the iPhone 16 Pro Max.
By plotting the temperature curve of the phone's magnetic charging surface and comparing it with the Apple MagSafe charger, it is evident that the AUKEY MagFusion Dash Pro maintains a significantly lower temperature. The Apple MagSafe charger runs 17–24°C hotter than the AUKEY MagFusion Dash Pro throughout the charging process. Thanks to the Omnia-Frez Active Cooling System, the MagFusion Dash Pro keeps temperatures below 19°C, even lower than the ambient temperature, ensuring a cool and efficient charging experience with outstanding heat dissipation.
Here is the spec info.
Model: HD-MC13A
In: 5V 3A / 9V 3A
Size: 100.4 x 63 x 63mm
Weight: 128g /4.520z
For drivers who rely on GPS navigation, device overheating, and inconvenient charging have long been frustrating issues. The AUKEY MagFusion Dash Pro solves these problems with its powerful combination of Omnia-Frez Active Cooling System and Qi2 wireless charging technology. Even on long road trips, it keeps your iPhone cool while providing continuous power. Additionally, its secure mounting system and strong magnetic attachment ensure that your phone stays firmly in place, even on rough and bumpy roads, eliminating any worries about it falling off.
The AUKEY MagFusion series features a sleek circular aesthetic with a metallic gray finish, creating a distinctive and premium look. Each product is designed with a sophisticated airflow system for efficient heat dissipation. Equipped with AUKEY’s advanced Omnia-Frez Active Cooling System and Qi2 wireless charging technology, these chargers deliver a cooler, quieter, and more stable charging experience compared to traditional wireless chargers.
Notably, the series comes with a two-year warranty, showcasing AUKEY’s confidence in its product quality. Whether at home, in the car, or on the go, the MagFusion series offers versatile and reliable charging solutions, making it a must-try for users seeking high-performance charging.
1. Review of Apple 25W MagSafe Charger
2. Review of Tesla Wireless Portable Charger
3. Review of UGREEN Qi2 Magnetic Wireless Charger
