This time, ChargerLAB got the latest Samsung S24 Ultra. The battery capacity is 5000mAh, and the charging power is still 45W, the same as the S23 Ultra. Compared with the previous generation, the appearance has not changed much. It supports many AI functions, such as real-time translation, image search, note-taking, etc. Next, let's test its charging performance.
The image of the phone and "Galaxy S24 Ultra" are printed on the box.
Some specs info are printed on the bottom of the box.
The box contains the phone, cable, and some documents.
It has a 6.8-inch display. And the display supports a refresh rate of 120Hz.
The camera module consists of four cameras.
The frame is made of titanium.
The USB-C port can support USB 3.2.
It also comes with a S-Pen.
You can write with it easily.
The length of the S Pen is about 110 mm (4.33 inches).
The length of the phone is about 162 mm (6.38 inches).
The width is about 79 mm (3.11 inches).
The thickness is about 9 mm (0.35 inches).
The weight is about 233 g (8.22 oz).
It comes with a 3A dual USB-C cable.
There are protective sleeves on both sides.
The connecter has special pins.
ChargerLAB POWER-Z KM003C shows it doesn't have an E-Marker chip.
The length of it is about 1 m (3' 3.4'').
Next, let’s see its charging compatibility.
Original Chargers
We use some Samsung chargers with original charging 3A cable test the real-time power.
Charge with the Samsung 25W charger (model: EP-TA800), the power is about 8.4V 2.45A 20.6W.
The power is about 9.15V 4.54A 41.6W when charging with the Samsung 45W charger (model: EP-TA845).
Charge with the Samsung 65W charger (model: EP-T6530), the power is about 9.26V 4.80A 44.46W.
We also used a variety of third-party chargers with a 5A cable during the test. Let’s take a look at the results.
The power is about 8.62V 2.59A 22.35W when charging with the Apple 140W charger.
There are no compatibility issues.
There are no compatibility issues. The power of third-party chargers is in the ranges of 15W, 25W, and 45W.
We use the Samsung 65W charger to fully charge the Samsung S24 Ultra. And put them into a 25°C (77℉) thermotank throughout the test.
At first, the voltage is 9.5V. And then, the voltage drops to about 9V until fully charged. The charging curve can be divided into five parts. In the first part, the power was around 46W for the first 1 min and 19 seconds. Then, the power gradually drops to 35W, 31W, and 22W in turn. The final part begins at 37 mins, and the power slowly drops to almost zero. It takes 1 hour and 18 mins to be fully charged.
From this chart, they can charge the Samsung S24 Ultra to 50% in 20 mins and 80% in 37 mins. It also reaches 100% in 1 hour and 18 mins. Its full charging time is not much different from the 1 hour and 14 minutes of the S23 Ultra.
We also recorded the highest temperature on the front and back after charging for 10 mins, 20 mins, and 30 mins.
10 Mins Charging
After 10 mins, the maximum temperature on the front is 32.5°C (90.5 ℉).
The back is 35.3°C (95.54 ℉).
20 Mins Charging
After 20 mins, the maximum temperature on the front slightly increases to 36°C (96.8 ℉).
And the back is 38.7°C (101.66 ℉).
30 Mins Charging
After 30 mins, the maximum temperature on the front drops to 33.8°C (97.52 ℉).
The back is 35.5℃ (95.9 ℉).
The temperature on the back is always higher than on the front. The maximum temperature is 38.7℃ at 20 minutes, and the power at this time is about 31W. After that, the temperature decreases as the power decreases. You won't feel hot to touch it after 30 minutes of charging.
The charging performance has not changed much compared to the previous generation.
The battery capacity is 5000mAh. It supports 45W wired charging and 15W wireless charging. It also supports wired or wireless reverse charging.
There are no compatibility issues. And the charging speed is almost the same as the S23 Ultra. It doesn't feel hot to the touch, even after 30 minutes of charging. However, we recommend switching to a 5A cable for faster charging.
1. Fully Charging Test of Samsung S24 Ultra with Samsung 65W Charger
2. 45W With PPS | Charging Review of Samsung Galaxy S23 Ultra
3. Up to 45W | Charging Review of Samsung Galaxy S23+
