Home › Reviews › Mobile Devices › Charging Review of OPPO Find X7 Ultra
This time, ChargerLAB got the latest OPPO Find X7 Ultra. The battery capacity is 5000mAh. And it can support 100W wired charging and 50W wireless charging. It also supports 10W reverse charging. Compared with the OPPO Find X6 Pro, the appearance has not changed much. Now let's do some tests to see its charging performance.
Charging Review of OPPO Find X7 Ultra-Chargerlab
The box is designed with silver and black splicing. The name of the phone "Find X7 Ultra" is printed on the top of it.
The box contains the OPPO Find X7 Ultra, a phone case, a 100W charger set, and some documents.
The OPPO Find X7 Ultra adopts a 6.82 inches display, that can support up to 2K. This display can automatically adjust brightness and color temperature to protect your eyes.
What we got this time is the “Ocean Blue” version. As you can see, the upper part is white and the lower part is the blue of the ocean. And the blue part is made of eco leather.
The speaker opening, microphone opening, and infrared opening are on the top of the phone.
The power button and volume button are on the right side.
The speaker opening, USB-C port, microphone opening, and SIM card slot are on the bottom.
The length of it is about 164 mm (6.46 inches).
The width is about 76 mm (2.99 inches).
The thickness is about 9 mm (0.35 inches).
The weight is about 223 g (7.87 oz).
It comes with a 100W USB-A charger and a USB-C to USB-A cable. It claims that the charger set can charge the phone to 50% in 10 minutes and 100% in 26 minutes.
The charger is white and made of flame-retardant PC material.
The specs info of the charger is printed on the input end. Model is VCBAOBCH. It can support input of 200-240V~ 50/60Hz 2.5A. And the maximum output is 5V-11V9.1A. The manufacturer is AOHi.
Here is the USB-A and USB-C connectors.
The USB-A has the independent pin and widened pins for high current.
The length of it is about 101 cm (3' 3.4'').
The length of the charger is about 55 mm (2.17 inches).
The height is about 54 mm (2.13 inches).
The width is about 31 mm (1.22 inches). The volume is about 93.7 cm³. So, the power density is about 1.07W/cm³.
And the weight is about 157 g (5.54 oz).
ChargerLAB POWER-Z KM003C shows it can support QC3.0, VOOC, SVOOC, and DCP charging protocols.
And it can support 3.4-5.5V3A and 5.5-11V3A of UFCS.
Use the 100W charger set to charge the phone, the real-time power is about 8.84V 9.08A 80.25W.
Charge the phone with the OPPO 50W wireless charging stand, the real-time charging power is about 10.90V 5.26A 57.35W.
It can also charge devices such as headphones through reverse charging.
We use some third-party chargers and cables to test the real-time charging power.
Use the OPPO 80W charger to charge the phone, the real-time charging power is about 8.63V 7.37A 63.55W.
The real-time charging power is about 7.91V 3.00A 23.73W when using the original 100W charger with a third-party 6A cable to charge the phone.
The real-time charging power is about 8.89V 1.91A 17.02W when charged with the AOHi 140W charger.
We know that when charged with the original charger set, the charging power ranges from 52W to 81W.
When using third-party chargers, the charging power is mainly in the range of 17W. In addition, when the third-party charger supports the UFCS protocol, the charging power can increase to about 24W.
We use the original 100W charger to fully charge the OPPO Find X7 Ultra. And put them into a 25°C (77℉) thermotank throughout the test.
The voltage is always about 9V but fluctuates. The charging curve can be divided into seven parts. In the first part, the power was about 73W for the first 1 min and 28 seconds. Then, the power gradually drops to 71W, 61W, 57W, 54W, and 46W in turn. The final part begins at 19 mins, and the power slowly drops to almost zero. It takes 29 mins to be fully charged.
From this chart, the OPPO Find X7 Ultra can reach 50% in 10 mins and 80% in 18 mins. It also reaches 100% in 29 mins.
We also recorded the highest temperature on the front and back after charging for 5 mins, 10 mins, and 20 mins.
5 Mins Charging
After 5 mins, the maximum temperature on the front is 35.6 °C (96.08 ℉).
The back is 38.1 ℃ (100.58 ℉).
10 Mins Charging
After 10 mins, the maximum temperature on the front increases to 38.7 °C (101.66 ℉).
And the back is 39.1 °C (102.38 ℉).
20 Mins Charging
After 20 mins, the maximum temperature on the front drops to 36 °C (96.8 ℉).
The back is also 36 °C (96.8 ℉).
We know from this chart, that the temperature on the back is higher than on the front. The temperature is highest at 10 minutes, and the power is about 54W at this time. After 20 minutes of charging, the temperature has dropped to 36°C. It's only warm to the touch at this time, so the temperature control is pretty good.
The charging performance continues OPPO's consistent level. After testing, it only needs 29 minutes to be fully charged with the large-capacity battery of 5000mAh.
With the original charger set, the charging power can reach up to 80W. However, after the charger set is replaced, the charging power will be greatly affected. Its maximum temperature during charging is 39.1°C.
It can be fully charged in a short time through the private protocol. So, we recommend using the original charger set to get a better charging experience.
1. Charging Review of Samsung S24 Ultra
2. Charging Review of Google Pixel 8 Pro
3. Charging Review of Infinix Note 30 Pro
OPPO
What OCuLink Products Can Be Used with External Graphics Cards? | ChargerLAB Analysis
Summary of PD3.1 Products: Laptops, Chargers, Power banks, and Power strips
Faster than iPhone? | Charging Review of Samsung Galaxy S23 Ultra
November 26, 2023
12
Charging Review of iPad Pro 11-inch (M4)
April 25, 2025
Testing iPhone 15 Compatibility with Android Phone Chargers
November 21, 2023
10
USB 3.2 | Charging Review of Samsung S24 Ultra
May 7, 2024
