Home › POWER-Z › KM003C/KM002C › Cable Simulation | Introducing the Cool Feature of ChargerLAB POWER-Z KM003C
  • 4
The USB PD 3.1 protocol was officially released in May 2021, and it has been two years since then. There is now a wide variety of chargers available on the market that support this protocol. ChargerLAB previously conducted a survey on the top chargers recommended for the PD 3.1 standard, you can click here to take a look.
Cable Simulation | Introducing the Cool Feature of ChargerLAB POWER-Z KM003C-Chargerlab
To cater to the demanding 240W EPR (Extended Power Range) standard, our cutting-edge tester, ChargerLAB POWER-Z KM003C, incorporates a comprehensive selection of four simulation options, including a faithful representation of a 50V 5A EPR cable. In this article, we will take this particular option as an example to elucidate the cable simulation feature of our tester. Furthermore, you can click here to learn more about the other three options and the "scan VOOC/MTK" feature.
First and foremost, it's important to note that when you don't select "be ready" at the charging protocol page, KM003C does not perform any simulation. It only receives PD data, so normal charging will not be affected. The cable simulation feature can be divided into the following three ways:
When the USB-C male plug is plugged into the charger, and the female receptacle is not in use, the male plug of the KM003C simulates a 50V 5A EPR cable, effectively functioning as a 50V 5A cable.
The captured protocol packet reveals a spec of 50V5A.
Then, when the USB-C male plug is plugged into the charger and the female receptacle is connected to another cable with an E-Marker chip (20V 5A), the simulation feature is not triggered, and the SOP1 data is provided by the cable directly.
The spec is now provided by this cable, at 20V 5A.
Finally, when the female receptacle is connected to the charger via this cable, and the USB-C male plug is not in use, no cable simulation occurs, and the SOP1 data is provided by the cable too.
Since there is no change of cable, the spec remains at 20V 5A.
In conclusion, by incorporating the cable emulation feature, testers can conveniently and efficiently simulate high-power charging scenarios by directly engaging the male plug. It provides a seamless and convenient solution for evaluating charging capabilities, ensuring a smoother user experience.
1. E-Marker Chip Detection | The New Update of POWER-Z KM003C
2. Cable Simulation & Scan VOOC/MTK | The New Update of POWER-Z KM002C/3C
3. Cable Matters! | Use the POWER-Z KM003C to See if Your Phone Is Fast Charging
KM003C
How Fast Does Tesla Model Y Charge Your Devices - ChargerLAB Compatibility 100
Best-Selling Chargers on Amazon India in May 2023
A Comparison of the ChargerLAB POWER-Z USB Testers (V8.0)
July 3, 2019
July 19, 2022
POWER-Z KM001 Technical Support
June 6, 2019
30
How to Record Charging Data Offline with ChargerLAB POWER-Z KM003C
May 22, 2024
