“BPS has officially launched the BPD93136 – a 16-phase multi-phase buck digital PWM controller designed in compliance with NVIDIA OpenVReg 16 for dual-rail applications, and the BPD93204 – a 4-phase multiphase buck PWMVID digital controller designed in compliance with NVIDIA OVR4-22 and the BPD80350E – BPS highly reliable DrMOS. These products provide an efficient, flexible and reliable power system management solution for applications such as AI servers, graphics cards, laptops and high-performance computing requirements.”
Driven by the growing demands of artificial intelligence (AI) and high-performance computing (HPC), power management systems are playing an increasing important role in modern electronic systems. BPS has launched a series of high-performance power management products, including the 16 phases dual-rail digital PWM controller (BPD93136), the 4-phase PWMVID digital controller (BPD93204) and smart integrated DrMOS (BPD80350E), which are designed to meet the requirements of NIVIDIA OpenVReg power specifications (OVR16 and OVR4-22). These latest offerings significantly improve the efficiency, stability and design flexibility of the power system with multiple functions.
16 Phase Digital PWM Controller - BPD93136
The BPD93136 is an up to 16 phases multi-phase buck digital controller, designed for 2-rail applications, specifically in compliance with NVIDIA OVR-16 Power. The part supports PWMVID interface for NVIDIA processors and is compatible for PMBus Rev 1.3 with AVSBus for output control and telemetry.
01 Core Advantages
· Highly Integrated and Flexible: Supports DrMOS-IMON/DCR/LS Ron Current Sense and features an easy-to-use multi-config (MCFG) function, which offers pin-level configurations to expand the digital IC’s application coverage without requiring register code changes.
· Highly Efficient Transient response: Internal CFV3M (Constant Frequency Voltage Cube Modulation) auto-loop compensation significantly improves system stability and transient response.
· Comprehensive Protection: Supports smart temperature sensing, programmable UVLO/OCP/OVP/UVP/OTP/VINOV/OVW/VRHOT/DrMOS fault protection, ensuring the safe operation of the system
· Compact Package: 7mm x 7mm QFN Package for high-density power supply designs
02 Applications
The BPD93136 is applied in AI servers, high-performance graphic cards and telecom, especially in scenarios that require high current and power density.
4 Phase Digital PWM Controller – BPD93204
The BPD93204 is a 4 phase multi-phase buck digital controller designed in compliance with NVIDIA OVR4-22. It supports PWMVID interface for NVIDIA processors and is compatible for PMBus Rev 1.3 with AVSBus for output control and telemetry.
01 Core Advantages
· Smart Current Sense: DCR/LS Ron/DrMOS Current Sense
· Flexible Configuration: Features a user-friendly group multi-config function (MCFG) to expand the digital IC’s application coverage without the need for firmware modifications
· Rapid Transient Response: Internal CFV3M (Constant Frequency Voltage Cube Modulation) achieves fast transient response with optimized passive components
· Comprehensive Protection: Supports OVP/UVP/OTP/VINOV Protection with variable configurations
· Compact Package: 4mm x 4mm TQFN package
02 Applications
The BPD93204 is applied in AI servers, high-performance graphic cards and telecom, especially in scenarios that require high efficiency and reliability.
16V/50A Integrated Smart Power Stage – BPD80350E
The BPD80350E smart power stage fully integrates high speed drivers and low resistance half-bridge power switches. It supports up to 1.5MHz high frequency operation and offers comprehensive thermal monitoring and protection circuitry in an electrically and thermally optimized package.
01 Core Advantages
· High Frequency Operation: Zero-crossing Detection (ZCD) Control and parasitic optimized package technology achieves high switching frequency operation, enabling higher efficiency performance
· Comprehensive Protection: Including over-temperature protection, cycle-by-cycle over-current protection and high-side MOSFET short protection, promising system operation safety
· Flexible Configuration: Supports Fault Indication Output (FLT) and Pin Programable Over-Current Limit (CLM)
02 Applications
The BPD80350E is suitable for High-Frequency, High-Current and Low-Profile DC/DC Converters and Multiphase Voltage Regulators for CPUs, GPUs and Memory Arrays.
BPD93136 Technical Features
· In compliance with NVIDIA OpenVReg 16 specification with PWMVID interface
· Supports up to 16 phases dual rail multi-phase controller, which can be flexibly configured as X+(16-X)
· Supports PWMVID/PMBUS/AVSBUS
· Built-in NVM Configuration, enabling multiple sets of file configurations
· DrMOS-IMON/DCR/LS Ron Current Sense with power MOS in different modes
· Pin-programmable MCFG Function for Easy Register Code Management
· Switching Frequency: 250kHz to 2MHz
· Interleaving+/TLVR/Phase Double, Interleaving mode can effectively reduce input ripple and supports the use of TLVR inductors and the phase double function.
· Constant Frequency Lock Technology improves the stability of output voltage
· SSC (Spread Spectrum Clock) function, which has a significant effect on EMI suppression
· Fast transient response, which can meet the requirement of large current changes, effectively reducing output capacitors and increasing power supply design density
· Digital current balance gain can quickly adjust current balance through a DCR detection resistor, reducing peripheral BOM costs
· Auto tune loop compensation keeps the system in a stable operating state under various conditions
· Smart temperature sensing can detect real-time temperature and displaying it through GUI interface
· BP star GUI user interface, a user - friendly interface that is easy to use, can be used to detect operating status and optimize performance, and can be updated online
· Differential remote sensing, combined with differential remote sensing mode, and the digital PWMVID can achieve regulation with 0.5% accuracy
· Programmable load line
· Programmable UVLO/OCP/OVP/UVP/OTP/VINOV/OCW/VRHOT/DrMOS Fault protection, Multiple types of protection measures safeguard the system
· 7mm x 7mm QFN package
Summary
The efficient and reliable multiphase digital controllers and DrMOS power management solution launched by BPS fully comply with NVIDIA's latest OpenVReg power specifications OVR16 and OVR4 - 22. The solution supports intelligent PWMVID control and a comprehensive protection mechanism, significantly improving the efficiency of the power system and the transient response. They can perfectly meet the requirements of high - current and high - power - density applications. In addition, the flexible configuration and compact package help users achieve more flexible design at a lower cost. In the future, BPS will provide customers with more innovative power management solutions.
