Home › News › What's New › Baseus Launches 100W 1A1C Fast Car Charger, With Multi-function Power Display
  • 9
The most popular accessory for cars is the car charger. After picking up the car, most drivers will buy a car charger to charge the digital products while driving. There are Various car chargers on the market, from the most common 5W to 20W PD fast chargers. At the same time, the technology of car chargers is slowly developing. Recently, Baseus, which focuses on electronic accessories, has launched a top-level car charger with up to 100W output power. It has the most common 1A1C ports and a built-in multi-function voltage & power meter to create a multi-function super high-power car charger for users.
Baseus Launches 100W 1A1C Fast Car Charger, With Multi-function Power Display-Chargerlab
The full name of the Baseus 100W Car Charger is "100W Dual Fast Car Charger with Digital Display," and the model is "CCZX-100C". It is an all-round car charger specially developed by Baseus for high-end users. The streamlined body is made of dark gray matting process, with gold-plated contacts, creating a special high-level texture.
Baseus 100W Car Charger adopts 1A1C dual ports. USB-C supports 5V3A / 9V3A / 12V3A / 15V3A / 20V5A five complete PDO voltage output, and the maximum output power is up to 100W. USB-A supports 5V4.5A / 4.5V5A / 5V3A / 9V3A / 12V2.5A / 20V1.5A six voltage output, supports PD3.0, PPS, QC3.0, SCP, FCP, AFC and other fast charging protocols.
To achieve a stable performance of the ultra-high power output capacity of up to 100W, Baseus 100W Car Charger adoptsbrand-new SGT component, which has a larger heat conduction area and lower power loss. The external gold-plated contact points are used to reduce the impedance and have the anti-oxidation ability after long-term use. The extended non-slip contact points will not come out and stop charging even if it encounters bumpy road conditions.
In addition to the powerful performance of the Baseus 100W Car Charger, it also integrates a multi-function digital display in the middle of the output panel, which displays the charger input voltage (car power supply voltage), USB-C output voltage, USB-C output power, USB-A output voltage, and USB-A output power one by one. It allows users to know the charging status of each device in real-time and quickly judge whether it is in fast charging, output power and other status.
In addition, based on the charger’s input voltage display function, the car’s battery voltage can be known when the car is turned off, and the car’s battery life can be judged. The car is running under a 12V voltage. So the battery voltage should be between 11.6V-12.8V when it is turned off. If it is lower than 11V, the battery is about to end, and the user needs to replace it to avoid breakdown.
Baseus 100W Car Charger has dual output ports, and the maximum output can reach 100W when using a single USB-C port, which can meet the needs of mainstream electronic products such as laptops, tablets, and mobile phones. The USB-A port supports a variety of fast charging protocols, and can provide SCP low-voltage direct charging to Huawei devices, which can be charged quickly and cold. It supports dual-port simultaneous output, which can be adjusted to 65W and30W output through intelligent power distribution, and two devices can enjoy fast charging at the same time.
Baseus 100W Car Charger has 100W super high power output and has reached the top of the USB PD standard. The 1A1C is suitable for new and old devices. It supports fast charging protocols, such as PD3.0, PPS, QC3.0, SCP, FCP, AFC, etc., making it suitable for notebooks, tablets, mobile phones and other devices. Both large and small cars can use it, cause its voltage range is 12V-24V. Also, it has a built-in multi-function voltage and power display, allowing users to know the fast charging status of each device. It can also judge the battery’s health, which is convenient for replacing the battery in advance to avoid breakdown. Baseus 100W Car Charger will go on sale soon, priced at ¥129($20), and if youplan to buy a high-power car charger, you can get one.
Baseus Car Charger
9
Teardown Report - UGREEN 40W Dual Type-c Port Fast Car Charger
ACASIS Launches Multi-bay Thunderbolt 3 Hard Drive Hub, Which Supports RAID Arrays
November 13, 2025
Apple Vision Pro Battery: Unlock Your Mixed Reality for $199 with USB-C
January 31, 2024
CUKTECH 6th Gen 65W GaN Power Card: Ultra-Compact Dual Type-C Charger for Fast, Reliable Charging
November 9, 2024
Introducing the ACEFAST 15W Qi Fast Charging Auto-Align Car Phone Charger
July 18, 2021
