As electronic devices become more and more important in our daily lives, traditional power strip manufacturers also began to add USB-A ports to their products. But most of them are not fast charging, and most of them are not Baseus. Recently, Baseus launched powercombo pro 6-in-1 40W GaN power strip on Amazon US with GaN technology, completely solving this problem.
It supports an AC socket and USB fast charging, the cable length is 1.5m, and as you can see the overall design is very stylish.
It has a three prong AC outlet on both sides and a two prong AC outlet on the top, which can be used at the same time. The inlets are designed to prevent children from inserting fingers, and to prevent foreign object from accidentally getting inside. As for the DC side, one USB-A and two USB-C ports are vertically arranged on the front output panel, and the total output power is 40W.
It has a power button with an ice blue halo LED light which can control the power with a single press. The LED light can show three states of the strip - solid blue between 1W-650W, slow pulse between 650-1625W, quick pulse when over 1625W and will automatically cut off.
Its USB module has a maximum output of 40W, which can charge up to three devices at the same time. And it supports fast charging for two devices simultaneously at the same power. Your iPhone and iPad can share fast charging without waiting around.
It adopts Baseus Digital Intelligent Power. The chip actively detects abnormalities in digital circuits. With ultra-sensitive digital control technology, the master chip monitors and detects malfunctions like overload, overvoltage, undervoltage, overcurrent, short circuit and more, then actively cuts off the power in 0.1 seconds. This advanced technology keeps you safe from potential dangers.
The Baseuspowercombo pro 6-in-1 40W GaN power strip creatively combines GaN and power strip, bringing consumers a completely different high-quality experience unlike other traditional manufacturers.
This product starts at $39.99 on Amazon US, you can click the button to buy one if you're intrested.
1. Adorable Capsule丨Anker Launches New 615 USB Power Strip (GaNPrime 65W)
2. Huntkey Launches New SSH608C Power Strip with A One-handed Intelligent Control Plug
3. Revolutionary Safety Upgrade丨Baseus Released PowerCombo Digital Power Strip 65W
