Home › News › What's New › Baseus Launched 120W Car Charger With Expansion Port, Providing Additional Cigarette Lighters
In April, Baseus launched 100W 1A1C fast car charger, with multi-function power display, specifically for high-power digital devices. This week, Baseus launched another product, 120W car charger with expansion port. Compared with the traditional car charger, it provides an extra cigarette lighter port. Digital devices and other appliances do not need to interfere with each other.
Baseus Launched 120W Car Charger With Expansion Port, Providing Additional Cigarette Lighters-Chargerlab
Baseus 120W car charger with expansion port adopts three-stage appearance design. The main structure is made of aluminum alloy. The left side is the cigarette lighter expansion port, the middle is the 1A1C or 2C output port, and the right side is the power supply end. Gray and black match each other and blend well into the car interior atmosphere.
Baseus 120W car charger with expansion port has two models to choose from. The difference between the two models is the output specification. Firstly, USB-A port of the 1A1C model supports 5V3A / 9V2A / 10V2A / 12V2.5A four fixed voltage outputs, and Type-C supports 5V3A / 9V2A / 12V2.5A output, the maximum output power is 30W+30W. Secondly, two USB-A models’ every single port support four fixed voltage outputs of 5V3A / 9V2A / 10V2A / 12V2.5A, with a maximum output power of 30W+30W.
After the traditional car charger is plugged into the car’s cigarette lighter socket, other appliances that want to use the socket cannot be used. If necessary, the car charger needs to be plugged in and out for replacement, which is more troublesome. Baseus 120W car charger comes with a cigarette lighter expansion port on the top and comes with a silicone dust cover. It can provide a maximum of 60W output power. You can plug in other appliances in addition to using the car charger, without having to do multiple-choice questions.
Baseus 120W car charger with expansion port is developed based on the USB PD fast charging standard, supports PD3.0, PPS, QC4+, QC3.0, SCP and other fast charging protocols suitable for mainstream electronic products such as Huawei, Xiaomi, Samsung, and Apple.
In order to enable stable output of electricity, Baseus 120W car charger with expansion port adopts gold-plated contact to reduce impedance and make high-current transmission more stable. It adopts the long anti-slip design for elastic plates. Even if it encounters a bumpy road, it will not slide out. The car charger can keep working steadily.
At present, most of the cars on the market are running in the 12V voltage system, while the large trucks are running in the 24V voltage system. Baseus 120W car charger with expansion port adopts a wide input, suitable for 12V-24V voltage and almost all cars.
Compared with traditional car chargers, Baseus 120W car charger provides an additional expansion port. When using the car charger, other devices can also be used. The output power of the expansion port is 60W, output power of two USB ports is 30W+30W, and the total output power is 120W. Baseus 120W car charger with expansion port price is ¥79($12.5). If you’re interested, you can have a try.
Baseu Car Charger
Navitas Semiconductor, the Industry Leader in Gallium Nitride (GaN) Power ICs, to Go Public at an Enterprise Value of $1.04 Billion via Live Oak II SPAC Business Combination
Review of ​​Realme Mini Flash Charger, With 50W Power and Ultra-small Size
AVerMedia Unveils GC313 CORE GO and GC313Pro ELITE GO: All-in-One Charging and Video Transmission Solutions
December 18, 2024
Co-Brounding Product Internet Hostkey Power Band by SHARGE is Launched
December 4, 2023
Wall Charger Included | Meet the MOMAX 65W GaN Power Bank
March 26, 2023
Eco-Friendly Nimble Podium 3-in-1 Wireless AC Adapter: Solution for Apple Devices
December 15, 2024
