Home › Guides › How to Buy › An Ultimate iPhone 15 Accessories Buying Guide: Chargers, Cables, and More
  • 3
It has been over two month since the release of the brand new iPhone 15 series. The first USB-C charging port of the iPhone series not only supports the vast number of existing related accessories, but also encourages manufacturers to launch new products to meet this new technology trend initiated by Apple.
However, navigating this vast array of accessories can be overwhelming. So this guide aims to simplify your accessory search by providing you with a curated selection of the best iPhone 15 accessories across various categories. Whether you're seeking to enhance your productivity, expand your storage capacity, or simply want a good old fashioned GaN charger. We've got you covered!
Chargers
Apple
Apple 35W Dual USB-C Traditional Power Adapter
Apple's 35W Dual USB-C Traditional Power Adapter (A2676) maintains the usual smooth and glossy white polycarbonate shell design, with rounded edges along the connection side for a warm touch. Apart from the port, its appearance and dimensions are identical to the original 30W single-port charger.
An Ultimate iPhone 15 Accessories Buying Guide: Chargers, Cables, and More-Chargerlab
In terms of performance, this Apple charger comes equipped with dual USB-C output ports. When used independently, it supports an output power of 35W and a voltage output of 20V. Overall, its design remains similar to the old 30W charger, with the new addition being the ability to fast charge from both ports simultaneously, and it continues to charge without interruptions when power adjustments are made.
PURCHASE
Apple 35W Dual USB-C Compact Power Adapter
Apple's new 35W compact power adapter (A2579) also features the traditional smooth and glossy white polycarbonate shell design, with rounded edges along the connection side. In terms of size, it is more compact than the original 30W charger. However, as a compact charger, its overall design language is different.
This Apple charger is equipped with dual USB-C output ports, with one USB-C port supporting an independent output power of 35W and a voltage output of 20V. In terms of temperature control, it performs quite well, and it remains stable even under full load for extended periods. Like its counterpart, it offers dual-port fast charging and maintains continuous charging during intelligent power adjustments.
PURCHASE
Nubia
Nubia 35W PD GaN Fast Charger
The Nubia 35W PD GaN Fast Charger is made of polycarbonate material with a matte finish on the surface, providing a delicate feel that doesn't leave fingerprints. It has a high aesthetic value, giving off a fresh and clean impression.
Utilizing the same Cypress PD chip as Apple, it automatically selects the optimal charging solution based on the device being charged, with a maximum output power of 35W. It supports multiple fast charging protocols, making it highly compatible. Overall, it is a compact and powerful fast charger.
PURCHASE
SHARGE
SHARGE Retro 35W GaN Charger
SHARGE incorporates Macintosh design elements into its fast charging accessory, creating the Retro 35 charger. It combines lightweight and compact design, with a unique LED display and exclusive fast charging indicator patent. Internally, it uses a third-generation GaN semiconductor power chip and a unique PCB design to improve charging efficiency while maintaining efficient passive cooling.
Developed based on the USB PD fast charging standard, it offers a maximum output power of 35W and is also compatible with common fast charging protocols on the market. Its compact size and excellent performance make it a rare find. Whether used as a desktop decoration when idle or in conjunction with other chargers, it is a stylish and practical charging accessory.
PURCHASE
TEGIC
TEGIC CRYSTAL 35W GaN Charger
The TEGIC CRYSTAL 35W GaN Charger breaks away from conventional design by incorporating a hidden touch switch on the top for convenient control of diamond-like light. Its side features a speckled design, reminiscent of a home-style pegboard.
It comes with a single USB-C port and supports PD 35W output and UFCS fusion fast charging protocols. With its compact size and innovative design, it is a solid choice among single-port chargers.
PURCHASE
MagSafe Chargers
Anker
Anker 3-in-1 MagSafe Charging Cube
The Anker 3-in-1 MagSafe Charging Cube has a distinctive appearance with a versatile cubic design that takes up minimal space. It offers magnetic wireless charging for your phone, headphone charging, and a dedicated area for charging your Apple Watch.
This accessory has received Apple's MFM certification and can simultaneously charge three devices. It provides a maximum of 15W of MagSafe wireless charging power for the iPhone and 5W power output for AirPods and Apple Watch.
Overall, it performs well in terms of compatibility, output performance, and appearance, making it a great choice for users looking to create a clean and minimalist desktop setup.
PURCHASE
Apple
Apple MagSafe Charger
The Apple MagSafe Charger comes with a built-in USB-C input cable. It features an aluminum alloy casing on the bottom and edges of the charging pad and a smooth plastic surface on top, providing a premium feel.
Its key features include magnetic alignment and 15W wireless charging, allowing users to charge their devices while using them, providing a new wireless charging experience.
PURCHASE
Apple MagSafe Duo Charger
The Apple MagSafe Duo Charger boasts an exquisite design with a compact size and excellent tactile feel. It strikes a balance between technology and aesthetics.
When paired with Apple's 20W charger, it can provide nearly 20W of output power for compatible iPhones and Apple Watches. However, the maximum power delivery time is relatively short, resulting in longer charging times.
PURCHASE
Belkin
Belkin BoostCharge Pro 2-in-1 Wireless Charging Stand
The Belkin BoostCharge Pro Wireless Charging Stand features a vertical design with a magnetic charging effect on the top, compatible with the MagSafe wireless charging of iPhone 12/13/14 series. It has also received MFM certification, offering up to 15W of wireless charging power for iPhones. The bottom area can charge AirPods.
Whether at home or on your office desk, this product allows for wireless charging of both your iPhone and AirPods without taking up too much space. It provides a better solution for keeping your desktop clean while charging your devices.
PURCHASE
Belkin BoostCharge Pro 3-in-1 Wireless Charging Stand
The Belkin BoostCharge Pro 3-in-1 Wireless Charging Stand, like the one mentioned above, belongs to the same series. It features a vertical, tree-like design with "branches" that house MagSafe charger for your devices. The base also includes a Qi pad for charging AirPods.
It uses Apple's original modules, certified with both MFM and MFW (Made For Watch), supporting fast wireless charging for iPhones (up to 15W) and Apple Watches (5W for S7 and above). Overall, it meets the wireless charging needs for multiple devices while minimizing cable clutter, offering a clean and organized desktop for users seeking quality.
PURCHASE
Belkin BoostCharge Pro 3-in-1 Wireless Charging Pad
The Belkin BoostCharge Pro 3-in-1 Wireless Charging Pad features a clean and understated design, suitable for both home and office environments.
Both the phone and watch sections (on the left and right sides) use Apple's original modules, certified with MFM and MFW, supporting up to 15W charging for iPhones, fast charging for Apple Watch S7/S8/Ultra, and wireless charging for AirPods in the middle area. For Apple enthusiasts, this three-in-one solution is a must-have for an organized desktop.
PURCHASE
MOMAX
MOMAX Folding MagSafe 2-in-1 Wireless Charger
The MOMAX Folding MagSafe 2-in-1 Wireless Charger features a fabric-textured PU leather material with a delicate touch. It has a foldable design for portability. The white magnetic core parts are all original Apple modules, boasting dual MFM and MFW certifications.
It can provide approximately 15W of fast wireless charging power for the iPhone and around 5W for Apple Watches from S7 onwards, making it suitable for everyday desktop charging. It also saves space for those looking to personalize their desktop setup.
PURCHASE
MOMAX Q.Mag Pro 2 2-in-1 MagSafe Wireless Charging Stand
The MOMAX Q.Mag Pro 2 2-in-1 MagSafe Wireless Charging Stand features an upright stand design with dual-zone wireless charging. Its overall design in white and silver is minimalist.
The base has a 5W wireless charging area for devices like AirPods, while the support arm holds the Apple-original MagSafe wireless charging module, certified with MFM, providing a maximum of 15W wireless charging power. It supports both vertical and horizontal orientations for convenience while charging your phone, making it suitable for various activities like messaging or watching videos.
PURCHASE
MOMAX Q.Mag Pro 3 3-in-1 MagSafe Wireless Charging Stand
The MOMAX Q.Mag Pro 3 3-in-1 MagSafe Wireless Charging Stand features an Apple-inspired design in milky white. It comes equipped with Apple's MagSafe charging module, certified with both MFM and MFW.
It can simultaneously charging three devices, with the iPhone supporting a maximum of 15W charging and AirPods and Apple Watch S7 or newer devices supporting up to 5W. The upright design also doubles as a magnetic stand for daily use, offering stability and convenience for tasks like messaging or watching videos. This three-in-one solution reduces cable clutter and keeps your desktop neat and tidy.
PURCHASE
Mophie
Mophie Snap+ Foldable Wireless Travel Charger
The Mophie Snap+ Foldable Wireless Travel Charger is a part of the traditional Mophie family design. When folded, it's compact and comes with an elegant storage box that matches the charger's aesthetics. It incorporates Apple's original magnetic charging module and holds the dual certifications of MFM and MFW, providing 15W, 5W, and 5W power outputs for your phone, watch, and headphones, respectively.
As a three-in-one magnetic charger designed specifically for Apple devices, it boasts an attractive design and convenient storage features, making it an excellent choice for both desktop and travel charging.
PURCHASE
Mophie Magnetic Vent Mount
The Mophie Magnetic Vent Mount utilizes Apple's official MagSafe wireless charging module, certified under Apple's Made For MagSafe program. It supports up to 15W magnetic wireless charging for iPhone 12/13/14 series and is also compatible with the Qi wireless charging standard. Thanks to its magnetic properties, your phone easily aligns with the coil and attaches when brought close, allowing for one-handed use and supporting both landscape and portrait orientations.
In terms of design, it offers various mounting options, including direct attachment to the air vent or an extended, swivel-arm setup to keep your phone away from the vent, ensuring it doesn't interfere with your air conditioning. With multiple ball joints for adjustment, its versatility is unmatched.
PURCHASE
UGREEN
UGREEN MagSafe Charger
The UGREEN MagSafe Charger features a robust aluminum alloy casing and a convenient 1.5-meter braided cable for everyday use, minimizing concerns about cable damage during use.
It utilizes Apple's original magnetic wireless charging module and holds the "MFM" certification. It supports 15W MagSafe wireless charging for iPhone 12, 13, 14, and the upcoming iPhone 15 series. Overall, this MFM-certified magnetic wireless charger offers increased durability and compatibility, providing a solid alternative to Apple's official MagSafe charger.
PURCHASE
UGREEN 3-in-1 MagSafe Wireless Charging Station
The UGREEN 3-in-1 MagSafe Wireless Charging Station features a clean and eye-catching white and silver metallic design. It comprises a base, a wireless charging module for phones, and a wireless charging module for watches.
With two Apple-approved magnetic wireless charging modules and certifications for MFM and MFW, it delivers up to 15W/5W/5W of charging power. Both the phone and watch wireless charging modules have adjustable designs, allowing you to choose the ideal angle during magnetic charging, enhancing the overall user experience.
PURCHASE
UGREEN Nexode 100W GaN Mini Power Station
The UGREEN Nexode 100W GaN Mini Power Station continues the space-gray color scheme, featuring a cubic design. It offers two USB-C and one USB-A ports on the side.
The top features a magnetic charging module certified under Apple's MFM, offering up to 15W MagSafe wireless charging for iPhone 12-14 series, along with support for charging other devices like AirPods. The USB-C port provides a maximum output of 100W using PD, and the USB-A port supports a maximum output of 22.5W. It's a great choice for users looking to create a minimalist and tidy desktop setup.
PURCHASE
ZIKE
ZIKE MagSafe Certified 2-In-1 Wireless Charging Stand
ZIKE's MagSafe Certified 2-In-1 Wireless Charging Stand departs from Apple's usual minimalistic white-gray design, opting for a glossy black base, matte white for phone charging, and matte black for headphone charging.
A "Boost Charging" button in the top-right corner of the charging pad can increase charging speed by 30%-45%. ZIKE has also addressed concerns about heat dissipation by incorporating a fan that automatically activates during accelerated charging. Performance-wise, this charging stand supports up to 15W MagSafe charging for iPhones, 5W charging for AirPods, and up to 10W wireless charging for Android smartphones.
PURCHASE
Charging Stations
Anker
Anker 525 GaN 67W Charging Station
The Anker 525 GaN 67W Charging Station features a minimalist design with a transparent matte finish created using ultra-nanometer vacuum coating technology. It offers three color options: Aurora White, Phantom Black, and Natural Green. This charging station uses a front-and-back partition design, with the most frequently used USB fast charging modules located at the front and AC power outlets at the back.
It has four USB output ports (2C2A), supporting a maximum of 67W PD fast charging, making it more than capable of charging the iPhone 15 series. On the AC side, it provides three AC outlets, supporting 250V10A AC power transmission specifications. This product is made using third-generation gallium nitride (GaN) technology, allowing multiple charging ports and a safe power strip to be combined in a compact design, significantly saving desktop space and making it more convenient for travel.
PURCHASE
Baseus
Baseus 100W GaN3 Pro Power Strip
The Baseus 100W GaN3 Pro Power Strip features a two-tone design with a matte and glossy finish. The power cord also includes a zip tie for cable management. In addition to the power station, it comes with a 1m-long USB-C to USB-C cable that supports a 5A high current.
This power strip has one AC outlet on the side and four USB ports (2C2A) on the front, with two USB-C ports supporting up to 100W charging and two USB-A ports supporting up to 60W charging. This excellent port configuration alleviates users' concerns about interface allocation, ensuring that fast charging is available regardless of how you connect your devices.
PURCHASE
CANDYSIGN
CANDYSIGN 120W Detachable 2-in-1 Charging Station
The CANDYSIGN 120W Detachable 2-in-1 Charging Station introduces a modular design, consisting of a desktop charging station and a power strip that can be separated to meet both home and travel needs in a compact form. The exterior features a gray-and-white design, exuding a vintage charm.
When used as a desktop charging station, it serves as a large charger with a 4C1A port configuration, meeting all your desktop charging needs. The USB-C1 port supports a maximum output of 100W PD, while USB-C2, C3, and C4 support up to 65W charging, with the single USB-A port offering 18W. The power strip module features two AC outlets, supporting a maximum of 2500W power. CANDYSIGN provides an advanced charging solution that meets the demands of home and travel scenarios, offering flexibility for a simplified lifestyle.
PURCHASE
Redow
Redow Wireless Charger Station (45W)
The Redow Wireless Charger Station (45W) is made of fire-resistant PC and features a design with an overall white color and a glossy black front panel. It includes a hidden LED digital display on the top to show power consumption. Despite its compact size, it's suitable for most home settings with its 1m power cord.
In terms of performance, it has four USB ports (2C2A), with the USB-C supporting 20W fast charging and the USB-A supporting 10W charging. Additionally, it has an area for wireless charging on top, allowing you to charge up to five devices simultaneously. Both sides of the charger feature an AC outlet, supporting a maximum of 1250W.
PURCHASE
UGREEN
UGREEN 100W DigiNest Pro 7-in-1 GaN Charging Station
The UGREEN 100W DigiNest Pro 7-in-1 GaN Charging Station continues the design of a radio, making it a sleek addition to your desktop. With a maximum AC power output of 2500W, it can meet the power needs of multiple devices.
In terms of performance, it offers two AC three-prong outlets and one two-prong outlet. On the front, there are three USB-C and one USB-A ports, supporting multiple charging protocols to accommodate both old and new devices. The USB-C port can deliver a maximum output of 100W, while the USB-A port provides 22.5W. When placed on your desktop, even with multiple cables, you can keep them neatly organized, creating a more comfortable workspace.
PURCHASE
Car Chargers
Anker
Anker 521 Car Charger (32W)
The Anker 521 Car Charger adopts the classic Anker design with Anker blue icons around the USB ports. It features a PC fireproof shell and a matte finish for a delicate feel. And the blue round icon on the top is actually an LED light. It's a great design for drivers to locate the charger during nighttime driving.
The USB-C and USB-A port can do 18W and 12W, respectively. It is compatible with most Android and Apple devices in the market. Since it's an Anker product. it surely got multiple charging protections to ensure safe charging. Of course, it's worth noting that its price will be relatively high.
PURCHASE
Baseus
Baseus 65W USB C Car Charger
This Baseus charger features an aluminum alloy shell for a smooth feel. The oxidation sandblasting technology makes it resistant to paint chipping and scratches, which is a common scenario encountered during driving. The charger's output panel has a surrounding LED ring light, similar to the previous Anker model, also making it convenient for users to locate the charger.
It comes with two USB-C ports and one USB-A port, with the first USB-C port supporting PD 65W fast charging and the other two supporting 22.5W. Besides providing fast charging for the iPhone 15 series, it's also compatible with mainstream smartphones, laptops, and notebooks. So, if you own a variety of electronic devices or frequently have family and friends riding in your car, this charger is an excellent choice for you.
PURCHASE
MOMAX
MOMAX MoVe 67W Dual-Port Car Charger
The MOMAX 67W one features a simple design with an all-metal shell, and both the input and output surfaces are covered in black matte plastic.
The USB-C and USB-A port can do 67W and 18W output, respectively. But the total output power is only 67W, supporting automatic power distribution. The USB-C port uses a voltage boosting solution, catering to the charging needs of most laptops, and it is also compatible with some Android smartphones thanks to PPS protocol.
PURCHASE
MOMAX MoVe 100W Triple Fast Charge Car Charger
This charger has a similar design to the previous one, also with an all-metal shell.
What sets it apart is its 100W total output power, with the first USB-C port supporting 100W, and the second USB-C and USB-A ports supporting 30W and 18W respectively. The charger's total output power is yet again, just 100W. So again, if you own a variety of electronic devices or frequently have family and friends riding in your car, and 65W Baceus one can not meet your power needs, this one is for you!
PURCHASE
mophie
mophie Dual (USB-C/USB-A) 32W PD Car Charger
This Mophie charger boasts a distinctive design. To be honest, at first glance, anyone would undoubtedly think this little gadget is expensive. The charger's top got a dense diamond-shaped texture that resembles something straight out of the renowned Tesla Cybertruck.
And the USB-C and USB-A port support 20W and 12W, respectively. So, if you don't have a multitude of electronic devices and don't mind the not-so-rapid 32W charging speed, it's worth considering purchasing it.
PURCHASE
mophie Dual USB-C 40W PD Car Charger
Compared to the previous one, this charger is a bit longer but maintains a similar design.
Unlike the previous model, both of its USB-C ports support 20W fast charging and are compatible with QC, PD, and PPS fast charging protocols. If you're a fan of the distinctive design of the previous model and find the 32W charging speed not quite satisfying, then this one is definitely suitable for you.
PURCHASE
UGREEN
UGREEN 40W USB-C Car Charger
This UGREEN 40W charger, much like the Baseus 65W model, showcases a moon silver aluminum shell crafted with an anodized sandblasting technology. Furthermore, you'll notice it has a soft, non-glaring LED indicator. For those who often drive in the dark on roads without streetlights, this design is quite appealing.
Each of its two USB-C ports can deliver 20W individually, and when used together, they can provide an impressive maximum output of 40W. In addition to supporting PD 3.0 fast charging for the iPhone 15 series, it also supports fast charging protocols like FCP, AFC, and QC3.0. So, with this charger, you no longer need to worry about the charging speed of your friends' Android phones. And the 30g weight making it compact and lightweight.
PURCHASE
UGREEN 69W USB-C Car Charger
The UGREEN 69W USB-C Car Charger features a frosted matte design and its standout feature is its symmetrical heat dissipation hole design, providing faster heat dissipation compared to traditional car chargers.
It comes with 2 USB-C and 1 USB-A port, catering to the charging needs of all your devices. The two USB-C ports support maximum output powers of 60W and 20W, supporting fast charging protocols such as PD, AFC, QC3.0, while the USB-A port supports Huawei SCP 22.5W fast charging; For those who are still loyal to using Huawei phones, this is good news.
PURCHASE
UGREEN 130W USB-C Car Charger
The 130W version has the same appearance, featuring a PC fireproof shell with a matte finish for a delicate feel.
 It also has a circular symmetrical heat dissipation hole design, and it's more densely arranged than the 69W version. The output panel has a circular LED light, indicating the working status, making it easy to locate the charging position at night.
The two USB-C ports support PD 30W and PD 100W outputs, making it compatible with mainstream smartphones, tablets, and laptops. The USB-A port also supports Huawei SCP 22.5W fast charging. So, if you have higher power requirements and still keep that Huawei phone you're dedicated to using, this 130W charger is a great fit for you.
PURCHASE
USB4 Cables
Anker
Anker 515 USB4 Cable
The first cable on our list is the Anker 515 USB4 cable. This all-black cable is crafted from high-quality materials and can withstand over 5,000 bends. Notably, it features the standard certification logo from the USB-IF association on its connector, visually representing its performance and appealing to consumers.
Specifically, it supports 40 Gbps data transfer rates, up to 8K@60Hz or 4K@144Hz video transmission, and power delivery of up to 240W. It is compatible with virtually any USB-C device, including smartphones, tablets, and laptops, making it truly versatile.
PURCHASE
Apple
Apple Thunderbolt 4 Pro Cable (1.8 m)
Apple's Thunderbolt 4 Pro Cable (1.8 m) breaks away from the company's traditional minimalist white-gray design, featuring an all-black braided cable that enhances durability and reduces tangling. The connector undergoes a matte treatment and bears the lightning logo representing Thunderbolt protocol compatibility. With a length of 1.8 meters, it suits most everyday cable needs.
Regarding charging, it supports up to 100W PD charging, data transfer rates of 40Gbps, and signal transmission for up to 8K video, allowing the iPhone 15 series' Thunderbolt/USB4 ports to unleash their full potential.
PURCHASE
Apple Thunderbolt 4 Pro Cable (3 m)
The 3-meter variant shares the same design and many advantages as the 1.8-meter cable, providing consistent performance.
It supports up to 100W power delivery, and real-world testing has achieved write speeds of 1470MB/s and read speeds of 2639.5MB/s in data transfer, making it exceptionally friendly for video and graphics professionals with high-quality requirements.
PURCHASE
Belkin
Belkin USB4 Cable
As a deep partner of Apple, Belkin's USB4 full-featured cable boasts USB-IF quality certification, ensuring reliability.
This cable integrates 40Gbps high-speed transmission, 8K display output, and 100W PD power delivery. It is not only a great companion for office work and productivity but also allows the iPhone 15 to unleash its full potential.
PURCHASE
Hagibis
Hagibis USB4 Cable
The Hagibis USB4 Cable features a high-density nylon cable body that enhances durability and prevents tangling. Both connectors are made of durable aluminum alloy. Additionally, its 4ft length strikes a balance between convenience and practicality.
In terms of performance, it supports single-screen 5K/60Hz or dual-screen 4K resolution for video transmission, up to 240W power delivery for charging, and 40Gbps bandwidth for data transmission, making it versatile for charging and transferring data for devices like smartphones, computers, and the Nintendo Switch.
PURCHASE
Kaiboer
Kaiboer Silver Plated USB4 Cable
The Kaiboer Silver Plated USB4 Cable is made with high-strength cotton braided wire, providing both flexibility and protection. Its connectors are wear-resistant and rust-proof due to anodized aluminum alloy.
This cable supports a 40Gbps bandwidth, up to 240W fast charging, and daisy-chain expansion, enabling connections to two 4K@60Hz displays, catering to multi-screen office and entertainment needs.
PURCHASE
ORICO
ORICO Liquid Silicone 240W USB4 Cable
ORICO's Liquid Silicone 240W USB4 Cable stands out with its unique material and appearance, offering four color options. It employs food-grade silicone material, offering both durability and comfort. TVS diodes are present at the connectors to effectively reduce damage from high currents to delicate devices.
In terms of performance, it supports up to 240W PD charging, 8K@60Hz or dual 4K@60Hz video transmission, and a high-speed data transfer rate of 40Gbps. Overall, this cable is a solid choice with robust materials, a unique appearance, and top-notch performance.
PURCHASE
ORICO USB4 Data Cable
ORICO's USB4 Data Cable features precision nylon braided wire with additional reinforcement at the connectors, ensuring durability and stable transmission. It comes in both straight and angled connector options.
This cable supports 100W PD, daisy-chaining for multi-screen sharing, up to 8K 60Hz single-screen transmission, dual 4K 60Hz display support, and compatibility with the DP1.4 protocol. It also boasts a high-speed 40Gbps data transfer rate, making it a versatile solution for charging, data, and video transmission needs.
PURCHASE
UGREEN
UGREEN Full-Featured USB4 Cable
The UGREEN Full-Featured USB4 Cable is constructed using FRPE (Fire Retardent Polyethylene) material, and its connectors are designed to resist breaking, ensuring enhanced durability.
The cable supports 100W PD fast charging and boasts a high-speed data transfer rate of 40Gbps. It also supports daisy-chaining, enabling dual 4K@60Hz displays, meeting the demands of multi-screen office setups.
PURCHASE
Zikko
Zikko Thunderbolt™ 4 Cable (0.8 M)
The Zikko Thunderbolt™ 4 Cable features an all-black design with a matte-finished connector, offering a sleek appearance. The cable is designed with a coaxial construction for added flexibility.
It not only delivers a stable 100W PD fast charge to your everyday electronic devices but also achieves data transfers at 40Gbps. Inside the cable, you'll find the Intel JHL5040D Redriver chip and the Infineon CYPD2105 E-marker chip, which enhance the cable's stability and reliability. While its name includes Thunderbolt™, don't worry, it's also compatible with USB4.
PURCHASE
Zikko Thunderbolt™ 4 Cable (2 M)
The 2-meter version shares the same black TPE material and flexible coaxial cable design as the 0.8-meter variant. The connector features a matte finish for easy insertion and removal.
At the cable ends, Redriver chips ensure stable signal transmission over long distances, and the multiple layers of coaxial cable shielding reduce interference and signal loss. Supported by various technologies, this cable can deliver 100W PD fast charging, Thunderbolt-standard data transfer speeds, and extend the use of high-definition displays.
PURCHASE
Cables with LED Display
AOHi
AOHI MAGLINE+ USB-C LED Display Cable (100W)
The AOHI MAGLINE+ USB-C LED Display Cable is wrapped in a braided exterior, offering higher wear resistance and flexibility. It can withstand up to 10,000 bends. It also contains aramid fiber for added strength and durability, protecting the internal wires from damage.
This cable is clearly a USB-C to USB-C type, which is currently the most widely used cable type. It features an E-marker chip, supporting a maximum power transmission specification of 20V5A, 100W. This cable can provide full-power fast charging for smartphones, tablets, and laptops. Its standout feature is the integrated LED display that shows the current device's charging power in real-time, providing users with accurate data reference and compatibility information.
PURCHASE
Baseus
Baseus 100W USB-C to USB-C Cable with LED Display
The Baseus 100W USB-C to USB-C Cable is made of nylon braided material, enhancing its tensile strength to withstand thousands of bends. The USB-C connector is made of high-purity zinc alloy, offering fast heat dissipation. The LED display shows real-time charging power, making charging speed visible and allowing users to check for compatibility with fast charging. It comes in two lengths, 1m and 2m.
In terms of performance, it supports 20V5A, 100W charging power and can transmit a 5A charging current. It is compatible with fast charging protocols from brands like Huawei and Xiaomi. Regarding data transfer, it adheres to USB 2.0 specifications.
PURCHASE
Mcdodo
Mcdodo Digital Pro USB-C to USB-C Cable 100W
The Mcdodo Digital Pro USB-C to USB-C Cable is a black nylon braided cable with a balance of flexibility and sturdiness. It includes a black fabric magic tape for convenient storage. The USB-C connector is made of high-purity zinc alloy, providing features like corrosion resistance, durability, and rapid heat dissipation. The connector and cable connection are thickened and injection-molded, making it more durable. The LED display shows real-time charging power, making charging speed visible. It comes in two color options, textured silver, and tech black.
In terms of performance, it supports 20V5A, 100W charging power and can transmit a 5A current. Data transfer follows USB 2.0 standards. Overall, the standout feature of this fast-charging cable is its ability to measure the real-time power when charging devices, making it user-friendly and easy to understand, especially for novice users.
PURCHASE
Mcdodo Digital HD Silicone USB-C to USB-C Cable 100W
The Mcdodo Digital HD Silicone USB-C to USB-C Cable is made entirely of soft liquid silicone, offering excellent flexibility and a comfortable feel. The USB-C connector is made of high-purity zinc alloy, providing efficient heat dissipation. It comes in three Macaron-inspired colors: blue, pink, and purple, with two length options, 1.2m and 1.8m.
In terms of performance, it supports 20V5A, 100W charging power. Its key feature is the ability to measure real-time charging power, allowing users to check for fast charging support. It is user-friendly and easy to understand, especially for novice users.
PURCHASE
POWER-Z
ChargerLAB POWER-Z AK001 Test Cable (240W)
Finally, there is the ChargerLAB POWER-Z AK001 Test Cable, a highly acclaimed cable produced by ourselves. It features a transparent matte design on its display, providing visibility into the internal PCB. It supports various functions like tapping, long-pressing, and double-tapping the back button, displaying different information screens, including cable specifications, current direction, protocol, voltage, current, power, and temperature.
In terms of practicality, it supports a fast charging power of 240W, which is currently the highest charging specification under the widespread adoption of USB PD 3.0. Coupled with USB 2.0 data transfer speeds, it is an excellent choice for users' daily needs. It is a great choice for those who want to understand charging information without the need for professional testing equipment, like the KM003C. Even for novice users, it is simple and easy to understand.
PURCHASE
MagSafe Power Banks
Anker
Anker 622 Magnetic Battery (MagGo)
The new MagGo power bank from Anker retains its classic style, with a redesigned layout for the USB-C port and indicator lights. It features a "notch" design on the edges for easy opening, making it convenient for users to open the stand for use. It comes in three colors: Interstellar Gray, Marble White, and Morning Mist Blue.
With a built-in 5000mAh battery and a single USB-C port, it supports charging the power bank itself and can also provide output through a cable for charging your phone. The power bank has a built-in magnetic wireless charging feature, allowing it to attach to the back of an iPhone for wireless charging. It features a patented stand design that can be opened to serve as a phone stand, supporting both vertical and horizontal orientations.
PURCHASE
Baseus
Baseus 20W Magnetic Power Bank 10000mAh
The Baseus 20W Magnetic Power Bank is made with a non-slip silicone material on the surface to provide a comfortable grip without scratching the phone. It offers four color options. It includes magnetic components that automatically align and securely attach to the back of an iPhone, activating wireless charging without the need to wake the power bank.
In terms of battery life, it features a 10000mAh battery, alleviating battery anxiety. It also integrates a USB-C bidirectional fast charging port on the side, providing up to 20W PD fast charging when there's a need for rapid replenishment.
PURCHASE
Benks
Benks MagClap On-Go Power Bank 10000mAh
The Benks MagClap On-Go Power Bank 10000mAh features a sleek white exterior with a matte finish and fingerprint resistance. The back is made of silicone material, providing a good grip and preventing the phone from slipping.
With a built-in 10000mAh battery, it supports magnetic wireless charging and can attach to the back of an iPhone for convenient wireless charging. The power bank has both USB-C and USB-A ports, supporting 20W wired output and 15W wireless charging, with good fast charging compatibility. It also has a side-mounted battery indicator for easy monitoring of the battery level.
PURCHASE
Benks MagClap On-Go Power Bank 5000mAh
Although the name is similar to the previous one, this model differs significantly. It shares the same appearance as the Apple MagSafe power bank but is much lighter, weighing only 122.9g. It comes in three colors: black, white, and blue.
The Apple MagSafe power bank provides 5W of wireless charging power to the iPhone 12-15 series, while this Benks model offers 7.5W of wireless charging and 12W of wired charging. They offer a similar magnetic charging experience, but the Benks model is available at less than a quarter of the Apple one. It only has one USB-C port, so that's something to keep in mind.
PURCHASE
IDMIX
IDMIX Q10 Pro 10000mAh Magnetic Power Bank
The IDMIX Q10 Pro power bank features a sleek and rounded design, with a white PC fireproof material on the front and a matte finish. The sides are made of metal and include a foldable stand, ensuring strength and durability while enhancing the user experience. When the stand is unfolded, it becomes a magnetic wireless charger, supporting both horizontal and vertical phone placement for convenient use while charging.
With a compact 10000mAh battery, a smooth feel, and magnetic attachment for wireless charging on the phone's back, the power bank offers 20W PD fast charging and excellent compatibility with both wired and wireless fast charging for Apple and Android devices. It also displays the battery percentage, providing precise information on the remaining charge.
PURCHASE
JOYROOM
JOYROOM 20W Magnetic Power Bank with Ring Holder 10000mAh
The JOYROOM power bank features a black PC material exterior with rounded corners. Its standout feature is the built-in collapsible ring holder. The wireless charging area has a slight elevation, creating a gap between the phone and the power bank, which helps with heat dissipation. Additionally, the magnetic area has adhesive pads to protect the phone from scratches and increase stability.
JOYROOM's magnetic power bank has a capacity of 10000mAh, combining both endurance and portability. It supports 15W wireless charging and 20W fast wired charging, meeting the needs of modern users. The ring holder can be used to secure the phone while charging and also functions as a stand, turning the power bank into a wireless charging stand for an improved video-watching experience.
PURCHASE
Mcdodo
Mcdodo 5000mAh Stand Magnet Power Bank
The Mcdodo power bank comes in white with a skin-friendly texture, offering a delicate touch. It features the Mcdodo logo on the front and a matte stand in gray, providing an exquisite appearance. There's a round button on the front that, when pressed, illuminates four indicator lights to display the current battery level.
With a built-in 5000mAh capacity battery and a single USB-C port, it supports 20W output and 18W input, with a maximum 15W wireless charging power, making it suitable for fast wireless charging for Android devices as well. The power bank cleverly integrates the stand into the frame, combining elegance and practicality, serving as both a power bank and a phone stand for on-the-go convenience.
PURCHASE
MOMAX
MOMAX Q.Mag Power 9 Magnetic Power Bank
The MOMAX Q.Mag Power 9 Magnetic Power Bank features a PC fireproof material exterior with a matte finish and fingerprint resistance. It includes a foldable leather-like stand on the back with the MOMAX logo. When unfolded, the stand transforms the magnetic power bank into a vertical wireless charger, allowing users to charge their phones while enjoying content or messaging. It comes in gray, purple, and blue.
With a built-in 5000mAh battery, this power bank supports magnetic charging on the back of Apple phones, 15W wireless fast charging, and 20W fast wired charging, making it highly compatible with common smartphones. The addition of a phone stand on the back allows for both horizontal and vertical phone placement, significantly enhancing usability.
PURCHASE
MOMAX Q.Mag Power 11 Magnetic Power Bank
The MOMAX Q.Mag Power 11 Magnetic Power Bank features a transparent punk-style shell design with a skin-like texture leather and a PU stand. The front has a full transparent tempered glass design, making the PCB visible and showcasing a futuristic mechanical technology aesthetic with a metallic magnetic module reflecting alloy luster.
With a 10000mAh battery capacity, it supports 20W PD fast charging through the USB-C port and a maximum of 15W wireless output power, catering to both iOS and Android users' charging needs while maintaining an attractive appearance. The stand is highly functional, allowing for horizontal charging with no screen obstruction. When paired with a MagSafe case, the magnetic force is further enhanced.
PURCHASE
MOMAX Q.Mag X 5000mAh Wireless Battery Pack
The MOMAX Q.Mag X 5000mAh Wireless Battery Pack features a sleek design with a full aluminum alloy body and an embedded glass panel. The metal surface has a matte finish, giving it an exquisite look. The embedded glass panel is designed to be smooth and elegant, enhancing the overall comfort and minimalist aesthetic. Additionally, this power bank boasts an incredibly slim profile at just 8.3mm, making it comparable to the iPhone 15 Pro Max in terms of thickness.
It comes with a built-in 5000mAh battery and supports multiple power outputs through its USB-C port, as well as a maximum wireless output of 15W. Whether you're in the iOS or Android camp, this power bank provides an ideal charging power for outdoor activities. It combines high efficiency, low-temperature fast charging, and excellent charging compatibility, offering users a superior outdoor charging experience.
PURCHASE
MOMAX Q.Mag X 10000mAh Wireless Battery Pack
This is essentially an upgraded version of the previous model, maintaining the full aluminum alloy body and embedded glass panel design that gives it both a premium feel and an elegant appearance. Despite its ultra-slim 13mm profile, it packs a substantial 10000mAh battery, ensuring worry-free power backup for users on the go.
It supports PD 20W wired output and a maximum wireless output of 15W. In compatibility tests, it has demonstrated excellent charging performance with mainstream mobile devices, providing a superior charging experience for users with devices from both phone ecosystems. Its compact design makes it easy to carry during travel and is more than capable of handling the iPhone 15 series with ease.
PURCHASE
MOMAX Q.MAG Minimal 5000mAh Magnetic Battery Pack
The MOMAX Q.MAG Minimal 5000mAh Magnetic Battery Pack features a fire-resistant PC shell with a matte sandblasted surface for a delicate touch. Its compact design makes it suitable for air travel and on-the-go use.
With a built-in 5000mAh battery, it offers multiple power outputs through its USB-C port and a maximum wireless output of 15W. Its overall performance, including physical compatibility and charging compatibility, remains outstanding. It continues MOMAX's pursuit of high-performance power banks, combining high efficiency conversion rates, PD fast charging, and portability to provide users with an excellent outdoor charging experience, even when facing the iPhone 15 series.
PURCHASE
mophie
mophie Snap+ Juice Pack Mini Power Bank
This power bank features mophie's fabric-covered design, offering a comfortable and scratch-resistant experience when held. Its compact and flat design allows it to seamlessly attach to the back of your phone. With a 5000mAh battery capacity, it supports both MagSafe wireless charging and USB-C wired charging, providing 7.5W wireless output and 12W wired output.
It perfectly adapts to the MagSafe wireless charging of iPhone 12-15 series, attaching securely to the back of your phone with a simple touch. Weighing around 136g, it's similar in weight to an iPhone 13 mini and provides ample battery backup for daily commuters. It easily fits in your bag and can serve as a secondary battery for your iPhone.
PURCHASE
mophie Powerstation Wireless Stand with MagSafe
This power bank features a skin-like material for an improved overall feel. It houses a 10000mAh battery and supports 20W dual-way wired charging and wireless charging, perfectly compatible with the MagSafe charging of iPhone 12-15 series. The package also includes magnetic stickers and positioning rulers to allow non-MagSafe phone models to enjoy magnetic wireless charging.
Apart from serving as a MagSafe wireless charger, this product comes with a stand feature, making it convenient for video calls and watching short videos while your phone charges wirelessly on your desk. In addition to MagSafe wireless charging and the stand function, mophie has equipped it with a third feature: a built-in screw hole at the bottom, suitable for attaching to a tripod for recording videos, outdoor live streaming, and other scenarios.
PURCHASE
SUIDDY
SUIDDY 15W Magsafe Power Bank
This power bank is extremely slim and has a metal and plastic construction. The metal shell has a matte edge and corner design with LED indicator lights on the edges, emitting a bright white light. The plastic shell area covered with skin-friendly material corresponds to the internal magnetic layout, making it easy for users to align their devices.
With a capacity of 5000mAh and a thickness of only 9mm, it is exceptionally thin, making it easy to carry and attach to the back of your phone for wireless charging. It features a dual-direction USB-C port, supporting 18W fast charging output, as well as compatibility with QC and other fast charging protocols. The power bank can seamlessly attach to the back of your phone without obstructing the camera, allowing users to charge and take photos simultaneously.
PURCHASE
UGREEN
UGREEN Foldable Kickstand Magnetic Battery | 10000mAh
The UGREEN Foldable Kickstand Magnetic Battery | 10000mAh is a versatile power bank designed for iPhones. It has nine strong magnets forming a magnetic ring, making it compatible with the iPhone MagSafe charging system. It automatically aligns and attaches for charging when placed near the device. With a battery capacity of 10000mAh, it provides an extended battery life.
It offers both magnetic wireless and wired charging options, with a maximum 15W magnetic wireless charging capability, supporting 7.5W for iPhones. On the wired charging front, it provides 1A1C dual fast charging ports, with USB-C supporting 20W PD bi-directional fast charging and USB-A supporting 22.5W multi-protocol fast charging output. Besides charging your phone, it can also be used as a stand. The power bank has a retractable support rod on its body, allowing it to be tilted for more convenient charging while using your device.
PURCHASE
ZMI
ZMI 5000mAh MagSafe Power Bank
The ZMI 5000mAh MagSafe Power Bank features a front panel with a faux leather texture, offering a comfortable grip and a premium feel. Its gray-white branding resembles the MagSafe charging symbol found on official Apple phone cases.
With a built-in 5000mAh battery and a super-slim thickness of 12.3mm, it doesn't require any buttons; it simply attaches to your phone for wireless charging, making it extremely convenient for both use and carrying. The power bank has a single USB-C port, supporting 20W fast charging input. It charges itself quickly and simultaneously charges your phone wirelessly, serving as a wireless charging pad.
PURCHASE
Flash Drives
Kingston
Kingston DataTraveler microDuo 3C USB Flash Drive
One of the standout features of this USB drive from Kingston is its compact and delicate design, appearing as if the drive contains only two ports and nothing else. The colorful cap resembles the classic iMac G3 and can rotate to protect the USB connector. Moreover, the cap has a top hole for a lanyard, making it convenient to carry and less likely to get lost – especially useful for such a tiny drive. It offers various capacity options from 64GB to 256GB and comes with a 5-year warranty and free technical support.
In terms of performance, its USB-A and USB-C ports not only support phones and MacBook models, including the iPhone 15 series, but also common devices like PCs, smart TVs, and speakers. However, it's essential to note that its transfer specifications are USB 3.2 Gen1, with a read speed of 200MB/s, which is far from the 10Gb/s of the USB-C port on the iPhone 15 Pro series. Nevertheless, this level of performance is considered average for a USB drive, not too shabby.
PURCHASE
MOVESPEED
MOVESPEED Solid State Flash Drive USB 3.2
As shown in the images, this drive from MOVESPEED features a sleek, streamlined design resembling a sports car. Its matte metal casing is highly durable and comfortable to the touch. The caps at the front and rear, resembling car engine hoods, provide excellent protection against impacts and dust. It is available in four capacities: 128GB, 256GB, 512GB, and 1TB, and, similar to Kingston, offers a five-year warranty.
Its performance takes a step further, reaching the level of USB 3.2 Gen2 with a maximum read speed of 520MB/s and a maximum write speed of 450MB/s. User tests in the comments section have shown write speeds of around 350MB/s. So, if you're a tech enthusiast like me, with a substantial collection of photos and videos to store, and you don't mind trying out a lesser-known brand, this USB drive is a solid choice.
PURCHASE
Samsung
Samsung Type-C USB 3.1 Flash Drive
If you have concerns about unknown brands, consider this Type-C USB 3.1 Flash Drive from Samsung. Its streamlined body design features a cap that separates from the main body, with both parts having lanyard holes to prevent any loss. Weighing 3.4 grams, its size falls between the MOVESPEED and Kingston drives. It is available in three capacities: 64GB, 128GB, and 256GB, and offers a 5-year limited warranty.
Its transfer specifications are USB 3.1, with a maximum read speed of 400MB/s. However, it's important to note that on Amazon's official website, it claims write speeds of up to 300MB/s, but many user tests have achieved only about 60MB/s. Therefore, if you're purchasing for an iPhone 15 or 15 Plus, and you're a fan of the Samsung brand, this drive's performance should suffice.
PURCHASE
SanDisk
SanDisk Ultra Dual Drive Luxe USB Drive
This SanDisk USB drive has a size that's more similar to typical USB drives. Its rotating cap design can only protect one side of the port at a time. The lanyard hole on top is the largest among these drives, making it very user-friendly. The product offers six options ranging from 32GB to 1TB and also comes with a 5-year limited warranty.
In terms of performance, it offers read speeds of up to 150MB/s, with lower write speeds that vary depending on capacity. So, if you need either 32GB or 1TB, two less common storage options, and don't mind waiting a bit longer when copying files, then this drive is suitable for you.
PURCHASE
SanDisk iXpand Flash Drive Luxe
This drive is somewhat unique. If you only have an iPhone 15 series phone, this drive is not recommended. It belongs to SanDisk's iXpand series, specifically designed for Lightning devices. One of its models is even available at the Apple Store. It features both a rotating cap and a removable cap, and the removable cap can be fitted onto either side, making it very user-friendly. It only offers a 2-Year Limited Warranty.
In terms of specifications, it has a USB-C and a Lightning port, with no specified read/write performance on Amazon and the official website. According to user tests, it achieves write speeds of not higher than 100MB/s. The advantage of this drive is its port configuration, which is very convenient for users who own both older and newer iPhones for easy file backup. Of course, the prerequisite for purchasing it is that you don't intend to use it on a computer that doesn't have USB-C port .
PURCHASE
Portable SSDs
Crucial
Crucial X8 Portable SSD
First, we have an SSD from Crucial, which is one of the best-selling products among Amazon's portable SSDs. This little gadget has a simple appearance with rounded edges for a comfortable grip. It's lightweight at 100g and can withstand a 7.5ft drop – a remarkable feat that places it first in our buying guide! It comes in 1TB, 2TB, and 4TB capacities and offers a 3-year limited warranty worldwide.
In terms of performance, it supports the USB 3.2 Gen-2 (10Gb/s) standard, with official sequential read speeds of around 1000MB/s and user-tested sequential write speeds of about 500MB/s, which should meet the requirements of the iPhone 15 Pro series. It also includes a dual USB-C (10Gb/s) cable and a 5Gb/s adapter, making it suitable for most ordinary users.
PURCHASE
LaCie
LaCie Portable SSD with USB 3.2 Gen 2
This LaCie portable SSD resembles a power bank with its distinctive slanted design on the top and bottom, which provides high recognition and protection for the USB-C port in case of falls. It is very lightweight at 45g and is even available on the Apple official website, a testament to its quality. The product is available in 500GB, 1TB, 2TB, and 4TB capacities and includes a three-year limited warranty and data recovery services.
In terms of performance, as the name suggests, it has USB 3.2 Gen2 transfer specifications, with maximum read and write speeds of around 1000MB/s. And you can easily connect it to Windows, Mac, and iPad right away with USB-C for quick compatibility. That means it's compatible with your iPhone 15 series.
PURCHASE
SanDisk
SanDisk Portable SSD
Next is a product from SanDisk, a leader in the flash memory industry. This SSD has a surface with numerous small holes, presumably for heat dissipation, and a lanyard attachment for easy portability. It weighs less than 40g and comes in 480GB, 1TB, and 2TB capacities, along with a three-year limited warranty.
In terms of performance, it supports the USB 3.2 Gen 2 standard, with a maximum read speed of 800MB/s. It also incorporates 256-bit AES encryption, providing protection against security threats while you're traveling. Additionally, it's designed to withstand one of the most common types of damage for portable SSDs – impact, as it can endure drops of up to 6.6 feet, not too shabby. Whether you look at Amazon reviews or consult the customer service, it's clear that this SSD is compatible with the iPhone 15 series.
PURCHASE
SanDisk Extreme Portable SSD
This model, as the name suggests, appears to be an upgraded version of the previous one. It also features the dense small hole design, and the embedded lanyard attachment in the upper right corner appears to integrate the previous red lanyard into the case, maintaining a consistent design. It weighs around 40g. What sets it apart is the availability of super-high capacities, including 500GB, 1TB, 2TB, and 4TB, offering a range of options. Furthermore, it provides a five-year limited warranty. Notably, it ranked first on Amazon's sales charts in October, the reliability just speak for itself.
It boasts NVMe technology for read and write speeds of around 1000MB/s. It also has features like drop resistance of up to 6.6 ft, 256-bit AES encryption, and IP55 water and dust resistance, making it suitable for outdoor activities. It naturally supports the iPhone 15 series and is ideal for users with high demands, such as professional photographers.
PURCHASE
Samsung
Samsung T7 Portable External SSD Series
This Samsung SSD comes in three variants: the base model, touch, and shield. The shield model is suitable for travelers and campers, with IP65 dust and water resistance and the ability to withstand drops of up to 9.8ft. The touch variant features a fingerprint unlock function for added privacy. The base model is suitable for general use. They come in capacities of 1TB, 2TB, and 4TB for the shield model, and 500GB, 1TB, and 2TB for the other two, with a three-year limited warranty.
The drive itself is capable of reaching speeds of up to 1,000MB/s for both reading and writing data. It comes with both dual USB-C and USB-C to USB-A cables included in the box, making it versatile and compatible with various devices. This means it not only meets the high requirements of the iPhone 15 Pro series but can also connect to PCs, Macs, and more. User reviews on major shopping websites confirm its seamless compatibility with the iPhone 15 series, highlighting its reliability and performance.
PURCHASE
Samsung T9 Portable External SSD Series
Apart from the special textured surface designed for slip resistance, there is minimal visual difference between the T9 and T7 models, which is why both models can only withstand drops of up to 6 feet. Additionally, the T9 model is equipped with the Dynamic Thermal Guard feature, which efficiently minimizes performance reduction during extended workloads, ensuring optimal performance even under heavy usage. It is available in three capacities: 1TB, 2TB, and 4TB, and comes with a five-year limited warranty.
Where the T9 truly shines is its performance. It supports the USB 3.2 Gen2x2 standard, delivering a whopping read and write speeds of around 2000MB/s, which is double the highest transfer performance of the iPhone 15 Pro. With this SSD, you can meet your iPhone storage needs for at least the next three years. It also comes with dual USB-C and USB-C to USB-A cables.
PURCHASE
Western Digital
Western Digital My Passport Portable SSD
The Western Digital SSD features a smooth, metallic front and an unexpected plastic back, likely for weight reduction or cost-saving. It weighs 45g and is available in capacities of 500GB, 1TB, 2TB, and 4TB, with a five-year limited warranty.
It uses NVMe technology along with the USB 3.2 Gen2 standard, offering read and write speeds of around 1000MB/s. It comes with a USB-C cable and USB-A adapter, making it environmentally friendly.
PURCHASE
Phone Coolers
Magnetic Phone Cooler
Benks
Benks Whirlwind Phone Cooler
This cooler from Benks immediately catches the eye with its cool circular design. The edges of its circular stand are chamfered for improved grip and comfort. Despite its weight of 70.9g, it's lighter than the MagSafe Battery Pack by around 40g. Plus, its built-in silent fan ensures that it won't disrupt your gaming or voice chat with noise.
It uses a USB-C port, which means you can share a cable with your iPhone 15. ChargerLAB measured its power consumption at around 7W, and in just ten seconds, you can feel a noticeable drop in temperature, meeting the official claim of "rapid cooling in 5 seconds." Besides cooling, it can also serve as a phone stand. When not in use, you can even stick it to the refrigerator for storage – a common scenario for such gadgets that often end up sitting idle.
PURCHASE
Black Shark
Black Shark Magnetic Phone Cooler
While Benks, an experienced mobile accessory manufacturer, is certainly trustworthy, if you're interested in a magnetic phone cooler designed by a phone manufacturer, take a look at this Black Shark product. It shares a similar circular design with a weight of about 73g, and a green LED indicator lights up when you plug in the USB-C cable. Additionally, it has an input power of 10W.
It features a built-in 5-blade fan with a maximum speed of 7200rpm, complemented by multiple metal columns for efficient heat dissipation. To accommodate phones and tablets that lack a magnetic area, Black Shark includes a special magnetic sticker with each cooler. Simply attach it to the back of your other electronic devices like applying a screen protector, and you can use the cooler without a hitch.
PURCHASE
Black Shark Magnetic Cooler 3Pro
Just as the name suggests, it's the advanced model in the Black Shark phone cooler series. It appears more refined and stylish on the outside, with a manual switch on the side. Additionally, the circular ring on the top is actually an RGB light that offers 11 optical colors. It also comes with a magnetic sticker.
In terms of performance, it has a power output of 20W and features seven fan blades with a speed of 6500rpm. According to our tests, it provides good cooling. Moreover, it can be connected to the specially designed Black Shark app for controlling fan speed, scheduling shutdowns, and managing the mentioned RGB light effects.
PURCHASE
Flydigi
Flydigi B6X Magnetic Phone Cooler
The Flydigi B6X is actually their fifth-generation cooler. It incorporates overclocking cooling and intelligent variable frequency technologies, effectively preventing internal condensation and significantly enhancing cooling. It also has RGB lighting on top, which changes to warm colors during demanding gaming sessions and reverts to normal in other situations.
In terms of performance, it also has a maximum power output of 20W and comes with a magnetic sheet for Android phones and tablets. It can be connected to the Flydigi Game Center app to control fan speed and RGB lighting. However, it's worth noting that it weighs 93g, which might be a concern for users who play games for extended periods.
PURCHASE
Razer
Razer Phone Cooler Chroma
While many products have RGB lighting, few are experts in this field. Who is the professional in the RGB arena? The answer is clear - Razer. Their Razer Phone Cooler Chroma comes with 12 built-in RGB LED lights, offering up to 16.8 million custom lighting effects. For those who don't know, Razer Chroma RGB is a lighting technology that allows users to customize and synchronize RGB lighting on their Razer products, such as keyboards, mice, headsets, and mousepads.
In terms of performance, it features a seven-blade fan with a speed of 6400rpm and a maximum noise level of 30dB. It uses a thermoelectric cooler and an aluminum heatsink to dissipate heat. Like Black Shark and Flydigi, users can adjust the fan speed through Razer's own app.
PURCHASE
Magnetic Phone Cooler with Charging Capabilities
Magnetic coolers are great, but they can be inconvenient in practice. High-performance gaming can drain your battery quickly, and traditional phone coolers, which occupy the back of the phone, leave you with only wired charging as an option. Adding the Magnetic Phone Cooler's own power cable can make things messy. That's where coolers with charging capabilities come in!
Benks
Benks MagClap Biliz Cooling Wireless Charger
This Benks cooler, which we've actually took apart before, looks somewhat like Iron Man's energy source – the arc reactor. It's constructed from PC+ABS+aluminum alloy materials and features a combination of three colors: purple, silver, and black. It weighs 89.2g, but considering it can wirelessly charge, that's acceptable.
An Ultimate iPhone 15 Accessories Buying Guide: Chargers, Cables, and More-Chargerlab
In our tests, without the cooler, the phone's temperature increased by 15.8°C, but with Benks' product, it only increased by 1.6°C, demonstrating excellent cooling. TEC semiconductor cooling technology and a 6900rpm cooling fan combine to achieve this remarkable effect.
PURCHASE
MOMAX
MOMAX Play Magnetic Wireless Phone Cooler
The standout feature of the MOMAX cooler is its semi-transparent design, allowing you to see the internal wireless charging coil and magnetic components, similar to our AK001.
It can reach a maximum speed of 6000rpm. The bottom features a 6W semiconductor cooling module and a 15W Qi wireless charging module, which is sufficient for iPhone 15 series users. Additionally, it can switch between "cooling mode" and "charging+cooling mode" with a single button, making it user-friendly.
PURCHASE
OnePlus
OnePlus 45W Liquid Cooler
Next up is a product from another familiar smartphone manufacturer, OnePlus. What sets it apart from the previous products using thermoelectric cooling technology is that it employs liquid cooling. This approach has two significant advantages. Firstly, the fan module can be placed in the cooling pump, reducing noise levels. Secondly, it significantly reduces the weight on the phone, reducing strain on the wrist.
As the name suggests, it has a maximum power output of 45W, and it offers four power levels for cooling. The magnetic end is compatible with the iPhone 12-15 series and various Android models.
In our tests, without the cooler, the phone's temperature increased by 14.9°C, but with OnePlus' cooler, the temperature actually decreased by 7.3°C, delivering outstanding results. Overall, this cooler is a great choice for hardcore gamers, game streamers, and similar users.
PURCHASE
This basically covers all the accessories that we know of that have excellent build quality, good reviews, and are compatible with the iPhone 15 series. We will also update this buying guide from time to time in the future. Stay tuned for more!
1. An Ultimate PD3.1 Product Buying Guide: Chargers, Cables, Chips, and More
2. The Era of High-Power Charging | A PD3.1 Cable Buying Guide
3. 30 PD3.1 Protocol Chips and Their 11 Manufacturers: A ChargerLAB Analysis
cable Charger iPhone 15
Ultra-thin | Teardown of AOHi 65W Translucent GaN+ Charger
Best-Selling Wireless Chargers on Amazon India in November 2023
Innovative Gadgets by MOMAX: Exploring What's New
February 11, 2024
Nice PD3.1 Chargers for Your Laptop and Phone
August 12, 2023
Discount Applies | Introducing Corsair 60W PD USB-C Cable
January 11, 2024
Ultimate Power: Navigating These High-Capacity Portable Power Stations
January 29, 2024
