Home › News › What's New › Adorable Capsule丨Anker Launches New 615 USB Power Strip (GaNPrime 65W)
Jeffrey
August 11, 2022
Recently, Anker held a new event and released several new fast charging products. In addition to chargers, Anker also applied its new GaNPrime technology to other product lines. It has launched the new Anker 615 USB Power Strip (GaNPrime 65W) in two colors.
Adorable Capsule丨Anker Launches New 615 USB Power Strip (GaNPrime 65W)-Chargerlab
The 65W 2C1A power strip is high-performance and portable with a unique design. It is completely different from the flat and wide power strips, for it looks just like a big capsule. Moreover, the plug can also be inserted into the receptacle, making it neater.
It adopts Anker's new GaNPrime multi-device fast charging system with a high-performance 2C1A 65W PD fast charging module. Either USB-C1/C2 can support up to 65W output separately, and the USB-A supports 12W output. As for multi-port output, it supports 45W+18W, 45W+12W, 30W+20W+12W and other power distribution strategies, charging up to three devices without a charger.
The two AC outlets support up to 250V10A (2500W), which allows you to plug in computers, induction cookers, electric kettles, displays, televisions, fans and other devices.
The Anker 65W 2C1A power strip has a 3ft (0.9m) extension cord. And the unique design of the shell makes it easy to hide the cord.
The new Anker 615 USB Power Strip (GaNPrime 65W) in two colors is high-performance and portable with a unique design. It is completely different from the flat and wide power strips, for it looks just like a big capsule. Moreover, the plug can also be inserted into the receptacle, making it neater.
1. Teardown of Anker 120W GaN Charger (GaNPrime 737)
2. Anker Announced Its New 737 Charger (GaNPrime 120W)
3. First Look of New Anker 767 Portable Power Station (GaNPrime PowerHouse 2048Wh)
65W ANKER GaN power strip
WELTREND Partnered with Anker to Debut An Exclusive PD 3.1 Protocol Chip
Teardown of Mcdodo 65W Mini GaN Charger (2C1A) CH-152
TEGIC Launched the NIO Edition 210W GaN Power Station
March 10, 2023
The New Magnetic Magic Case Charger Folds, Holds And Charges 3 Devices
August 25, 2022
EcoFlow Launched River Max Plus Portable Power Station Limited Edition
March 22, 2023
Mcdodo Launched 67W Crystal Series GaN Charger
February 25, 2023
Jeffrey
