Home › News › What's New › Active Cooling System | ZIKE Launched MagSafe Certified 2-In-1 Wireless Charging Stand
As we all know, every iPhone has supported MagSafe charging since the iPhone 12 series. Although MagSafe is a very convenient charging method, in theory, it actually generates a lot of heat when charging. ZIKE recently launched a wireless charging stand that fundamentally solves this problem. How did they do it? Let's find out.
Active Cooling System | ZIKE Launched MagSafe Certified 2-In-1 Wireless Charging Stand-Chargerlab
The ZIKE MagSafe certified 2-In-1 wireless charging stand is made of aluminum alloy, stainless steel, Polycarbonate, and other materials, with a high input power of 15V3A. In terms of structure, this is a bracket-type 2-in-1 charging stand. The magnetic wireless charger suspended at the top is made of Apple's original MagSafe magnetic wireless charging module. It has passed Apple's "Made For MagSafe" certification and has good compatibility, efficiency, and safety.
The module is supported by a column. The magnetic part of the module and the magnetic part on the back of the iPhone attract each other and start charging. It supports any iPhone newer than the 12 series. It can provide up to 15W MagSafe magnetic wireless charging and can Turn on ZIKE's innovatively developed "accelerated charging" mode.
There is a button in the upper right corner of the base. After pressing it, it will enter the "charging acceleration" mode. ZIKE's comparison test shows that the charging speed in the "charging acceleration" mode can be increased by 30%-45% compared with the standard charging mode, and your iPhone can be charged in a short time, making magnetic wireless charging become more useful.
When the "charging acceleration" mode is activated, the air cooling system at the back of the module will also be activated, thus taking away the heat from the mobile phone, making the wireless charging last longer, and completely solving the problem of overheating and power reduction. The "charging acceleration" mode can also be switched off manually to reduce noise.
In order to adapt to different scenarios, it can support 40 degrees viewing angle adjustment. Thanks to the vertical and horizontal magnetic attraction mode of the module, it's super easy to watch TV while charging.
The base is made of high-quality aluminum alloy with a silicone anti-skid pad. The base surface is equipped with a 10W Qi wireless charging module, which is the most widely used universal wireless charging protocol on the market. It supports iPhone (7.5W), AirPods (5W), Android phones (up to 10W), smart wearable devices, and other devices compatible with Qi wireless charging protocol.
The entire wireless charging base is equipped with three ice-blue indicator lights. The round hole indicator in front of the base is the working indicator, the ring indicator at the bottom of the column support rod is the fast charging indicator, and the button on the upper right corner of the base is the air duct system indicator. As you can see, this is very concise for users.
The ZIKE MagSafe certified 2-In-1 wireless charging stand's top wireless charging area is made of Apple's original MagSafe magnetic wireless charging module, which is perfectly suitable for Apple's products and supports 40-degree viewing angle adjustment. The second wireless charging area at the bottom supports 10W Qi wireless charging output.
Its biggest advantage is the innovative development of an easy-to-use "charge acceleration" mode of air duct cooling technology. Support dual-zone support for simultaneous charging.
Feel free to check www.ziketech.com for more information about ziketech.
1. 10000mAh Power Bank丨 MOMAX Released Upgraded Magnetic Wireless Battery Pack with Stand
2. New MOMAX 100W 6-Port Wireless Desktop GaN Charger Supports Simultaneous Charging of 7 Devices
3. Transparent | MOMAX Launched Dual Magnetic Wireless Charging Stand
MagSafe Wireless Charging ZIKE
Baseus Launched Megattach Series 20W Kickstand Magnetic Fast Wireless Charging Power Bank on Amazon
Teardown of Original Nintendo Switch OLED Model Charging Dock
ChargerLAB Got the Leaked Pics of Apple First 35W Dual USB-C Charger
April 11, 2022
8
Navitas is All-In with Affordable and Multiport GaNFast Chargers at USB-PD Asia 2019
August 26, 2019
First Batch of Thunderbolt 5 Devices Launched: Includes Laptops, Docking Stations, Hard Drives, and Cables
August 30, 2024
Affordable Power | MOVESPEED 140W PD3.1 Charger Hits the Market
February 17, 2024
